Build Sheet Thread
Please upload your Build Sheet to this thread.
I thought it would be cool to see lots of build sheets in one thread. I'll start with mine. FYI, mine is a combination of 2 sheets that had crumbled into pieces and I sort of put it back together. Both out of the seat, one from the back and one from the bottom.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
Live life and be happy.
Re: Build Sheet Thread
Here is a build sheet from my 1969 C10 short bed. Man I miss that truck. I cannot make the pic larger for some reason when I try to edit it.
![]() Join Date: Oct 2013
Here's mine for my '72 C/10 that was special ordered. The original owner ordered the truck as part of his "retirement plan". Him and his wife travelled around the U.S. in the truck towing a 5th wheel. Hence The factory leaf spring suspension with H/D leaf springs. The truck had an auxiliary bed mounted tank and C/B radio before I owned it. I also have the protecto plate, owners manual, and emissions maintenance booklet.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
Found mine. It was behind the gas tank. Pulled it when I did my seat ,tank was as new but I replaced the rubber lines. My Chevelle's was in the back seat
