#226 |
Re: No Limit Trailing Arm Rear Suspension
Thanks for the compliment. I had them made from oil-impregnated bronze in an effort to make them "self-lubricating". I also put some synthetic grease on them during assembly for good measure and to help hold them in place. I am not expecting them to be a wear item based on the truck's limited use (i.e. not a daily driver), but I will keep on eye on them when I go to grease the trailing arm end joint.
#227 |
So I measured the brackets from No Limit I have and they are 2-5/8" (plus or minus 25 thousandths) wide from inside edge to inside edge.
#228 |
![]() Join Date: Jul 2010
Please give me a call with dimensions. If we sent you incorrect brackets we will send new ones. 865-940-1503
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#229 |
Hey @robnolimit it was no big deal. I had a friend with a porto-power help me spread them the 1/16 or 1/8 inch I needed to get them in. I appreciate it though!
#230 | |
#231 |
@robnolimit
So, the rest of the kit went on fine,and looks great. I went ahead and ordered your C-notch kit so that will be the next step for me,as I installed 2inch blocks with the kit,just like you guys did on your shop Truck. One more question though. Did you guys have to add a shim or use angled lowering blocks? I'm really not digging the driveshaft angle coming from the rear... |
#232 |
@robnolimit nothing on using angled shims?
#233 |
Hello guys,
We've updated some of our instructions for some of our kits to make all of our products more understandable and user friendly. In addition to the Trailing Arm Kit we also offer the 63-72 Panhard Bar kit and 63-72 Shock Relocation Kit separately to fit the original trailing arms and frame. For those interested here they are, they will also be available on the website shortly. |
#234 |
continued...
#235 |
Continued again....
#236 |
![]() Join Date: Jun 2014
NoLimitCody,
I feel special you guys used my pictures in your instructions. lol |
#237 |
17 5/16" measurement from rear of frame on the No Limit shock relocation kit looks like it's for a short bed. Anyone know the measurement for a longbed? Unfortunately my '71 seems to be one of the few without the 5/8" hole punched from the factory. And the given measurement puts it way too far back.
Posted via Mobile Device |
#238 |
A guy with a truck
Long beds are 20” longer, 12” in front of wheels, 8” behind. Based on that, 25 5/16” should put you where you need to be
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#239 |
#240 |
The thread that never dies!!! I installed the trailing arm kit on my 71 Blazer. What do you do about the coil over spring being loose when you jack up the vehicle?
#241 | |
A guy with a truck
- add a lowering block between the trailing arm and axle - move the upper coilover mount up - use a shorter coilover shock body - haul a couple hundred pounds of gravel ![]()
#242 |
Gringoloco, you have had some nice rides! This is what I have so far. I think that a shorter shock is the best option. I plan on lowering it as far as I can without floor/frame interference.
#243 |
I recommend that you wait until the body is on. Looks good. BTW, kinda odd to see a SBC in a build now a days. Like it!
#244 |
Sad statement right there. I'm all about the technological advancements of the LS platform, but the SBC is always a solid choice.
#245 |
on the rear coilover setup is the shock vertical?
#246 |
and on gringo locko picture the shocks are in front of the axle, yet in your digram they are behind
#247 |
Gringoloco is using a Porterbuilt rear set-up which is why the C/O's are behind the axle.
#248 |
The body is on the frame now. Sadly, I've been doing this project for 28 years. When I started, dropped spindles from a 73 and cut coils was the best you could do! I'm glad I waited. Today I would have done a LS motor. The SBC should get the job done though, especially with a 4 speed tranny.
#249 |
#250 |
The images above from NoLimit are the shock relocation kit which places the shocks behind the axle when using the stock Truck Arms & coil springs. The No Limit coil-over set-up puts the C/O's in front of the axle about where the factory coils would be but outboard of the frame & T/A.
