#26 | |
Re: Jackstands + no wheels = heavy vibration?
I haven't rotated the shaft 180 since installing it yet no. But as I mentioned in my last post, the raising of the rear end seems to be fixing it or at least masking it.
1968 C10 |
#27 |
Have you changed the driveshaft recently? It doesn't look like that yoke is far enough up in the trans to me.
____________________________________________ My build thread: Project Moonshiner Bagged & Z Frame 63 http://67-72chevytrucks.com/vboard/s...d.php?t=659205 "I love the smell of grinding metal" |
#28 |
![]() Join Date: May 2012
OK, ya. It's a tough one. I like the idea of the wood blocks for a test to see if there is change. What's your angles before and after. Turn the shaft to shut me up! It's possible the yoke fixed the problem and caused another one. I've seen more annoying stuff. Do the shaft twice. Once 180. And once only turning the rear yoke 180. See what happens. Will only take less than a half hour maybe fifteen minutes. It's free! That's what I would do next. I am cheap and lazy. I do the easy stuff and free stuff first. Plus these exercises get you to thinking. Then keep on going.
![]() j
White K20 |
#29 | |
No I haven't but there's no telling what the previous owner did to it.
1968 C10 |
#30 |
My guess would be that stiffer springs (like my wood blocks) would amplify an imbalance as there would be less absorption by the springs so I'm inclined to think that the changing of my angles are what's causing me to not feel any vibrations anymore. I could be wrong though.
1968 C10 |
#31 | |
![]() j
White K20 |
#32 |
I've been thinking about it and putting the wood in my springs would only be increasing the driveshaft angle right? Can too little angle even cause vibrations? Oh and is it possible to install a one piece drive shaft backwards?
1968 C10 Last edited by bob8619; 03-30-2018 at 05:32 PM. |
#33 |
Also this is my transmission mount which looks worn but not sure if that can lend to the underlying problem or not.
1968 C10 |
#34 |
I spy my little eye,,,input shaft not in far enough on trans
#35 |
You have a long bed with th350 and one piece drive shaft and the yoke goes in further?
1968 C10 |
#36 |
There is 2-3/8" that goes inside into the housing. Thats not sufficient? Thats a whole new can of worms if not.
EDIT: And thats not taking into consideration that the tail shaft actually sticks out 1/2'' beyond the hosing so thats just short of 3'' of spline contact vs the 1.25'' of exposed yoke on the outside.
1968 C10 Last edited by bob8619; 03-30-2018 at 07:43 PM. |
#37 |
I went and bought an angle finder and the different between the two angles is 2 degrees. Isn't it ok to be within 3?
1968 C10 |
#38 |
Yea, that's what I told him earlier.
#39 |
Should only be roughly 1/2" showing. You may have 2-3/8" inside, but too much outside makes it unbalanced.
#40 |
How could that be? That section of yoke spins regardless, if it's unbalanced outside then it would be unbalanced inside too.
1968 C10 |
#41 |
Error post. removed.
1968 C10 Last edited by bob8619; 03-30-2018 at 09:50 PM. |
#42 |
Removed
1968 C10 |
#43 |
![]() Join Date: Oct 2013
I'm having similar vibrations in my 72 lwb c10 with 2 piece driveshaft. New carrier bearing, all three u joints new. Haven't thought to check out the slip joint between the front and rear driveshaft, or the pinion nut.
Were you able to get the vibration figured out?
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
#44 |
Moderator
![]() Join Date: Jun 2017
Couple of observations...
The yoke, as mentioned by a couple of others, appears to be way too far out of the trans...I have always been told by driveshaft guys when ordering a new shaft... "Push the yoke all the way into the trans then pull it out 3/4"...this yoke appears to be out at least two and half inches... If the truck has been run with the yoke out this far, it is possible the bush in the extension housing has been chopped up... Can you move the yoke up and down inside the end of the trans extension housing? The trans can be damaged if that rear bush is damaged...I have personally witnessed the rear bush actually walk out of the housing and end up sitting on the output shaft... That trans mount is TOAST ! and it looks like the metal part of the mount is touching the cross member... ![]() ![]() ![]() |
