Originally Posted by Missyblue
Hey are you using the Ford sending unit from the kit? If so how are you adapting it to the gauges I heard they have different ohms and wouldn't work but I figured there might be an option.
And did you have to mess with the crossmember at all?
I can't say which sending unit we used, but we used Dolphin gauges so we matched the sending unit to the gauge. Once you know which gauge set (fuel gauge) you are using you can find a sending unit with the correct ohms. Cross member (large one) was removed.
