Old 08-02-2018, 01:56 PM   #1
Notes
Vent Windows
72 C10. I rebuilt the vent windows years ago - so long ago that I can’t remember what I did. Duh. It’s so difficult to close them that I just leave them shut for fear of breaking the glass. Is there an adjustment someplace? Thanks
Notes is offline   Reply With Quote
Old 08-02-2018, 02:19 PM   #2
68is4me
68is4me's Avatar
Re: Vent Windows
I am also interested in what you come up with. The ones I rebuilt pivot fine but the front bottom corners will not pop in to the weather strip very easily. Is that the same problem that you have?
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 08-02-2018, 03:17 PM   #3
Grumpy old man
Grumpy old man's Avatar
Re: Vent Windows
The only adjustment on vent windows is the spring tension on the bottom pivot shaft , Too tight they won't open and close easily ,Too loose and they'll flop around and not stay where you want them . use cation it's easy to twist the shaft right off the vent window frame .They have to come back out to adjust .
Old 08-02-2018, 03:53 PM   #4
Notes
Re: Vent Windows
Thanks for the replies. After checking closer, I think the problem is the stiff weatherstripping in the front corners. They definitely don't leak! I'm going to soak them up with some silicone spray for a few days and see if that helps. Maybe a touch of dielectric grease too.
Old 08-03-2018, 12:26 PM   #5
Notes
Re: Vent Windows
Problem is that the back of the vent windows don’t line up with the rear vertical support (the front track of the side windows). They’re tipped, so the top of the vent window and the front curved corner don’t want to go into the weather stripping. Not sure how to fix that. Can I bend the tab that has the rivet?
Old 08-03-2018, 12:33 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Re: Vent Windows
Read this thread. It is three pages long but you pretty much have to read the whole thread to get all of the useful information.
http://67-72chevytrucks.com/vboard/s...d.php?t=660294
All vent window gaskets are not created equal.....
LockDoc
Leon
Old 08-04-2018, 12:16 AM   #7
el_fantasma
el_fantasma's Avatar
Re: Vent Windows
Mine are closed and don’t leak, I’m afraid to touch ‘em
72 White Cheyenne, The Ghost
el_fantasma is offline   Reply With Quote
