Old 08-20-2018, 07:54 AM   #1
Bret B
Brake pedal return spring
Been a bit since I've had time for the truck. In the time lapse, memory has lapsed as well. The memory lapse is the fact, I cannot locate the original brake pedal return spring which indicates I've misplaced it very very well. Trying to locate a new one. I've done a search here and at my local parts stores with no joy to be had. So the question is, does anyone know if an aftermarket spring is made for a 64-66 C10, or will a 67-72 brake pedal return spring work? Is there another spring which will work?
1965 Chevy short-step side, work in progress....
............................____
..................______l/___\____
.................|_/(0)\_ll____/(0)_l.
Bret B is offline   Reply With Quote
Old 08-20-2018, 08:50 AM   #2
PGSigns
PGSigns's Avatar
Re: Brake pedal return spring
I should have one. Your welcome to it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-20-2018, 11:40 AM   #3
Bret B
I might have to take you up on that, especially if there isn't any others that will work. I'll hit you up by PM to work out the details if there isn't any other options.
Old 08-20-2018, 12:36 PM   #4
62bagger
62bagger's Avatar
I had a hard time finding one for my 62. I ended up getting a generic spring from the hardware store and cutting it down to make it fit.
62bagger is offline   Reply With Quote
Old 08-21-2018, 07:32 AM   #5
Bret B
A thought popped into my head a few minutes ago, so I better put it out before it is lost pinging around in the cranial cavity. Are the clutch pedal return and the brake pedal spring the same, or nearly the same length? Clutch pedal return springs might still be available as well. If anyone has both, can you post the lengths please?
Old 08-21-2018, 09:00 PM   #6
grndcont
that damn spring is a pain to get back on there.
grndcont is offline   Reply With Quote
Old 08-22-2018, 01:27 AM   #7
62bagger
62bagger's Avatar
The springs on my 62 were different. The brake spring on hooks through a slotted opening in he top of the pedal box so it needed a long hook so it wouldn't bind. I bought a clutch spring for a 62 c10 but it was too long so I had to find a generic replacement for both springs. I hope these photos help.
Old 08-22-2018, 06:23 AM   #8
PGSigns
PGSigns's Avatar
The springs on the 4-6 look to be the same spring. I looked last night and pulled two from the same pedal assembly and they are what appears to be an exact match.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 08-22-2018, 07:41 AM   #9
Bret B
Jimmy
Sounds like that is a winner. Even if the clutch is slightly longer, one could cut and then bend a new hook to make it work. Good information PGSigns.
Thanks for the photos 62bagger.
