Old 08-29-2018, 11:58 AM   #1
colgad
colgad's Avatar
Who makes a Fuel Injection tank for Blazers
I have searched but can't seem to find a tank I can put a Fuel Injection pump in for my 72 Blazer.
I am doing a 5.3 swap and I do not want to run a frame mounted pump.
If there is a way to adapt my stock tank I am open for that suggestion also.
I searched the TANKS web site but all they seem to have is for 73-91 Blazers!
Thanks guys!
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 08-29-2018, 01:10 PM   #2
Droolguy
Re: Who makes a Fuel Injection tank for Blazers
https://fitechefi.com/products/40004/
Probably one of the coolest fuel injection parts made these days. Just put it in the engine bay and then you don't need to run wires and build new fuel lines for EFI.
Droolguy is offline   Reply With Quote
Old 08-29-2018, 01:17 PM   #3
colgad
colgad's Avatar
Thanks but I have read many bad stories on the FiTech Forum about these units and they have been nothing but trouble. I think they are on version 2 or 3 so they may have some of the issues ironed out but I am looking for a Tank with a big enough hole to use the Blazer/Burb sending unit that has the pump built on it. You just have to change the pump to a 60 Psi unit and done. I got a tank from TANKS for a 67 Camaro project that was perfect but they done seem to make one for our Blazers. Thanks for the tip, just not what I am looking for.
Old 08-29-2018, 01:31 PM   #4
Droolguy
My best recommendation to you would be to have a local fabrication shop just weld you up a tank then, they are dirt simple and can be built to any capacity you want. Nice thing about the Blazers is the tank is just a square in between the frame rails so a fab shop can whip one out quick because there's no complicated geometry.
Can even have them build it out of SS (although more expensive) and never have to worry about it again.
Speaking of "it's just a box", you might want to look into fuel cells. Universal ones come in "box" shape of all kinds of different dimensions. Would just need to make some brackets for it, costs is about the same as a fuel tank.
Old 08-29-2018, 02:27 PM   #5
A1971Blazer
A1971Blazer's Avatar
you'll have to do some fabrication...... but a 87-91 Blazer or Suburban EFI tank can be used for an in tank set-up...search the Blazer build section...there are a few threads on it...
the tank will be around $100 or so....
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 08-29-2018, 07:38 PM   #6
jondancer
Boyd welding
jondancer is offline   Reply With Quote
Old 08-29-2018, 07:58 PM   #7
HARDCORECASH
Yes Boyd Welding. Call AZ Pro Performance and tell them you want the Boyd Blazer Tank. It has the fill neck the right size and moved to make it easier to use the stock fill hose. I just got mine last week but haven’t had a chance to mount it yet. If you are a member of C10 Addiction on Facebook you get a discount.....
HARDCORECASH is offline   Reply With Quote
Old 08-29-2018, 08:32 PM   #8
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Got mine from Fuel Cell Guy.
He is on the forum.
low'n slow is offline   Reply With Quote
Old 08-29-2018, 08:37 PM   #9
A1971Blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=670191
1967 C10 Step side
1968 C10 Step side
Old 08-29-2018, 09:17 PM   #10
hemi43
hemi43's Avatar
I also converted to a 5.3, but made my own tank. Converting an original tank is fairly straight forward if you have some fabricating capabilities. My best advice is to use as much OEM stuff as possible because it will be much easier getting parts later on if a problem should arise. I used a factory 2003 pump and assembly and have no regrets. In fact, I've used these assemblies on a few builds. They are cheap and are self contained including fuel sender, roll over valve and return line. Another bonus is that the assembly will adjust to different depth tanks so it's an easy install. While you're at it, cut an access hole in your floor so that you won't need to drop the tank for any future pump servicing. One last thing I would recommend is plastic (nylon) fuel lines front to back. Once you use these, you will never go back to the old steel lines.
hemi43 is offline   Reply With Quote
Old 08-29-2018, 11:11 PM   #11
colgad
colgad's Avatar
Thanks guys, exactly what I was looking for!!!!!!!!!!
Old 08-29-2018, 11:12 PM   #12
colgad
colgad's Avatar
How did you mount the new pump assembly in the old tank?
Old 08-30-2018, 12:12 AM   #13
Blazerowner
Blazerowner's Avatar
I’ll 2nd Boyd from AZ Performance. I have one sitting in my shop for my build. It’s a top notch tank and fits in the stock position. You can also have them move the filler neck if you don’t like the position. Mine is behind the mount to the rear of the truck. Just need to snake a hose to it. I think it was about 4-500 with shipping if I remember right.
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 08-30-2018, 09:07 AM   #14
hemi43
hemi43's Avatar
I didn't. I mentioned I built my own tank, but converting an old tank is the same process. I machined a ring and retainer then welded it to the new tank.
Old 08-30-2018, 02:53 PM   #15
K5 MAX
K5 MAX's Avatar
Goin through putting the 87-91 tank in mine right now. This is the best thread that I've found on it. http://67-72chevytrucks.com/vboard/s...d.php?t=670191 More pics and fuel line AN fitting part numbers here http://67-72chevytrucks.com/vboard/s...=663780&page=2 might be on page 2 or 3. With a 4.5" angle grinder and a drill you can do the swap. With the tank in this location the filler neck shouldn't need to be modified or turned, it'll be just in front of the second from the rear body mount.
1972 K5 Blazer
350/350/PS/PB
From GA but live in Panama City, FL
K5 MAX is offline   Reply With Quote
Old 08-30-2018, 05:14 PM   #16
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Another vote for boyd welding... i have pics and install info if you need it...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 09-04-2018, 03:28 PM   #17
vancelot69
vancelot69's Avatar
Page 60 of the current LMC catalog looks like Holley has one that fits in the stock tank. http://www.lmctruck.com/icatalog/cb/full.aspx?Page=60
My toys:
1971 GMC Jimmy
2008 Hummer H3 Adventure
2003 HD Road King
vancelot69 is offline   Reply With Quote
Old 09-04-2018, 09:06 PM   #18
Haggar
My Jimmy came from the previous owner with a nice new Poly replacement gas tank. I had a tall version of the areomotive phantom 340 fuel system laying around. I didn't need that much pump, so swapped it for a Walbro 255. It's been working for me nicely so far. I've had it down to 2-3 gallons in the tank, and no stumbles.
Not necessarily what I would have done from scratch, but I had the phantom setup on the shelf from another project..
Haggar is offline   Reply With Quote
Old 09-07-2018, 06:49 AM   #19
mcmlxix
Collector of Projects
mcmlxix's Avatar
www.vaporworx.com or www.rickstanks.com
Rich
1972 K5 Blazer CST Click HERE
Old 09-07-2018, 08:51 AM   #20
jhrusk
Not so much tank related but avoid fitech like the plague as mentioned above.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 09-13-2018, 10:42 PM   #21
scf100
scf100's Avatar
What’s the problem with Fitech?
I did a Google search and all the threads are from 2016-17 so old
Anyone have recent experience with the newer command center pump?
Been considering for the 454 in my 70 2WD Blazer
1970 2WD Blazer 454
1972 C-10 Extended Cab 350 SBC
scf100 is offline   Reply With Quote
Old 11-01-2019, 04:42 PM   #22
BIG BLOCK JIMMY
BIG BLOCK JIMMY's Avatar
Did I read correctly that the Boyds tanks have the correct/complete filler neck for the Blazer/Jimmy?
72' JIMMY 454
BIG BLOCK JIMMY is offline   Reply With Quote
Old 11-06-2019, 11:31 AM   #23
DemkoG
97 2 door Blazer fuel tank fits nicely in replacement of the stock tank. and you can drop in a fuel pump and sending unit.
DemkoG is offline   Reply With Quote
Old 11-06-2019, 07:07 PM   #24
BIG BLOCK JIMMY
Thank you, but I already ordered a Boyds from AZ Performance.
72' JIMMY 454
Old 01-02-2021, 11:58 AM   #25
jjzepplin
jjzepplin's Avatar
Ricks Tanks makes an adapter for the original tank to use a 2010 Camaro style pump but it's expensive and on B/O for about four months right now. Nice part but JEEZ!
https://rickstanks.com/tech/bolt-in-kit-27000/
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
