Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 08-30-2018, 09:42 PM   #1
Warrens69GMC
Warrens69GMC's Avatar
What carrier is this
I'm new to id-ing the carriers, what carrier is this??
Yes, I know its a LS differential
Old 09-08-2018, 01:21 PM   #2
GRADYS Performance
GRADYS Performance's Avatar
Re: What carrier is this
Looks aftermarket, Based on the shape it may be an Auburn unit. If you are trying to tell the series then need to know the teeth counts of both ring & pinion.
GRADYS Performance is offline   Reply With Quote
Old 09-08-2018, 03:33 PM   #3
Warrens69GMC
Thank you. Its 13:41 so a 3.23. The car was a 2.73 and G80, so I was surprised when I took the cover off.
Old 09-09-2018, 11:30 AM   #4
GRADYS Performance
They had to change the carrier with the gear ratio change. The 3.23 won't fit on the 2.73 carrier.
Old 09-15-2018, 07:16 AM   #5
Bigdav160
Bigdav160's Avatar
Is that a 7.5" gear? Camaro's had auburn units.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-15-2018, 09:12 AM   #6
Warrens69GMC
Yes, from a 1995 Z28. The code is a G80, which means usually a Gov-lock.
Old 09-17-2018, 10:46 AM   #7
GRADYS Performance
The Unit pictured is Not a Gov-Loc.
Old 09-24-2018, 09:19 AM   #8
Myself
I'd guess the Gov-loc blew into a million little pieces and was replaced with that unit. As stated, probably Auburn.
Myself is offline   Reply With Quote
