09-08-2018, 08:25 PM | #7226 | |
Proprietor of Dale's Corner
Re: What did you do to your truck today? Chapter II
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
09-08-2018, 09:55 PM | #7227 |
Just did some bearing work and hoping someone sees that I'm in need of a HO52 rear carrier with a 4.10 gear set...
09-09-2018, 02:42 AM | #7228 |
3757chevy, the second half of the driveline is short do too the yoke to axle centerline being longer than the 12bolt,but yes I have herd of those.
Ol bluek20, the trans is a 4spd manual doesn't have a pan. I thought it might be an sm420 or sm465 but doesn't look like any identifing features match with one of those
2008 GMC 2500HD 6.6l Duramax Diesel 67 GMC long bed 2wd my "main squeeze" 85 Toyota project, SBC, TH350, D60 front, D70 Rear, 3 linked Front, 4 link Rear. 43 Willys, family heirloom |
09-09-2018, 12:20 PM | #7229 | |
Strongman Garage
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
09-09-2018, 05:48 PM | #7230 |
...I see...
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
09-09-2018, 07:11 PM | #7231 |
Put on new finned diff cover
1970 Jimmy 4x4 IL6 1971 Jimmy 4x4 350ci v8 1971 SWB 327ci v8 1972 Short Stepside 305ci v8 1972 Blazer 2WD CST LS9 350ci 4sp 1999 4 Door LB 1 Ton Old Body Style 5.7 v8 |
09-09-2018, 07:24 PM | #7232 |
Now the trucks running I could catch up on needed repairs on the Woodshed. Burning all the repair scrap wood. I did have it out to local show on Fri. and to do a full detailing on it. All the glass and the dash.
Do it, Do it right, Do it right the first time |
09-09-2018, 08:24 PM | #7233 |
Added digital gauges to my truck a couple weeks ago.
__________________ Jeff |
09-09-2018, 08:29 PM | #7234 |
Finally got time to recover my seat and get it back in the truck this weekend. It sure is a lot more comfortable to drive with the seat recovered.
09-09-2018, 08:36 PM | #7235 |
Trouble shooting the fact that I have zero rear braking with a new master cylinder and proportioning valve. Have a hard petal even with the left rear bleeder cracked open, and no flow. Think I must have a bad proportioning valve. Got another one ordered, and that doesn't fix it I will look at the rear rubber hose next. The valve trip rod is in the middle and the light is not on, and I have verified that the brake light works. Going to charge the ac tomorrow while I wait on brake parts.
1968 SWB Step Side, Big Block, 4L80E , Running! |
09-09-2018, 08:43 PM | #7236 |
09-09-2018, 08:46 PM | #7237 | |
Strongman Garage
09-09-2018, 09:29 PM | #7238 |
Leroy got some new wheels and tires.....
09-09-2018, 09:39 PM | #7239 |
Leroy was my grandpa's name. I love it........
09-11-2018, 09:00 AM | #7241 |
Was a bad proportioning valve. Changed it out.
09-11-2018, 12:28 PM | #7242 |
Painted my front hubs today. I know I need new rotors but this will at least makes it look good till I can get some
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
09-11-2018, 04:20 PM | #7243 |
I am with you there! I recently painted my daily driver's drums and those look so much better. *I very nearly painted the hubs also but figured I needed high temp paint. I did paint the center of the rotors, just to allow the alloy wheels to not have "dissimilar metal corrosion" as much.
09-11-2018, 04:33 PM | #7244 |
Almost Satisfied
Painted my engine today.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
09-12-2018, 01:16 AM | #7245 |
Active Member
Haven't posted progress in awhile because I've just been slowly taking it apart. But I'm planning to finally get the frame fixed and the body media blasted tomorrow, so I got the bed onto a dolly this past weekend, and tonight I got the doors disassembled and taken off, and the windshield and rear window off. I tried to do Lockdoc's old method where you stuff the garden hose under to kind of hold the seal out, but my seal is rock hard so it wasn't happening. Had to cut it. But I got it all out! Now it's ready for blasting and then I'll be painting for a week or so!
David Larsen 1970 Chevrolet C-10 |
09-12-2018, 10:28 AM | #7246 |
I can see the gauges now. Upgraded to led lights
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
09-12-2018, 01:05 PM | #7247 |
WOW looks good.
09-12-2018, 02:03 PM | #7248 |
been driving my pickup around as much as possible. turned over 500 miles today so-far-so-good nothing has come flying through the hood yet....that's a good thing. peeled-out at a stop light today too....hahahahah i can only imagine my little 250 saying, "WTF was that for???"
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
09-12-2018, 02:06 PM | #7249 |
looks very nice!!
09-12-2018, 04:04 PM | #7250 |
....CAUSE IT COULD
