Closed Thread
Old 09-21-2018, 06:53 PM   #7276
1968aj
Re: What did you do to your truck today? Chapter II
got new tires and wheels.
1968aj is offline
Old 09-22-2018, 04:43 PM   #7277
66clow
66clow's Avatar
Test fitted my new door and kick panels. Finally covered the dreaded speaker hole.
66clow is offline
Old 09-23-2018, 10:54 AM   #7278
weq92f
weq92f's Avatar
Actually yesterday but...
Installed the water pump, intake, throttle body, accessories and belt system, valve covers, headers, and fan relays and harness.
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline
Old 09-23-2018, 04:25 PM   #7279
KQQL IT
At the body shop.
KQQL IT's Avatar
Drivers training days.
My daughter has claimed old blue and wants to get her license in it.
Except she's getting the Sonoma 1st.
KQQL IT is offline
Old 09-23-2018, 06:29 PM   #7280
weq92f
weq92f's Avatar
Fired it up after top end refresh and retrofit roller cam completion... open headers, no O2 sensor to get it to run right -EFI on top-
https://youtu.be/7W148nXt60A
-klb
weq92f is offline
Old 09-23-2018, 08:20 PM   #7281
nlped
nlped's Avatar
-klb
Sounds AMAZING!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 09-24-2018, 12:16 AM   #7282
lil hoodlum
lil hoodlum's Avatar
-klb
Oh man, that sounds great. Nice truck by the way!
I live not too far from Fort Worth.
lil hoodlum is offline
Old 09-25-2018, 12:08 AM   #7283
Steeveedee
Who Changed This?
Steeveedee's Avatar
Got the new Cold Case radiator delivered today. I was at the care facility where my MiL is for rehab after falling last Tuesday, so one of my sons brought it into the house. He'll be the one putting it in with "parental supervision", because I still have "candy hands" after carpal tunnel surgery, over a year ago.
~Steven
Simi Valley, CA
Steeveedee is offline
Old 09-25-2018, 01:54 PM   #7284
Ken O.
Put in a new axle in the 67 GMC over the weekend. Took out the old 12 bolt with a bad pinion bearing and replaced it with a 14 bolt, 6 lug, 3/4 ton axle from a 91 chevy. No more grinding noise! yay! New headlights with led halos from Octane lighting just showed up the other day that will be installed shortly. So then I can actually see at night.
Ken O. is offline
Old 09-26-2018, 08:39 PM   #7285
Barnfind46
Barnfind46's Avatar
My truck "Gene" got new shoes!
68' with no bells or whistles unless I add'em.
Barnfind46 is offline
Old 09-26-2018, 09:14 PM   #7286
tommy3horse
tommy3horse's Avatar
Hi, I chased a nasty miss on the “new” crate motor, now with 7k miles. I replaced the hei cap and rotor, pulled the carb, completely dissassembled it and cleaned it. I didnt find the issue until I pulled the plugs and found #6 fouled terribly. Yikes. The wire had been rubbing on the dipstick tube and sure enough there was gray “tracks” on the tube.
I replaced the wires and 8 fresh R45TS plugs and that wire. Now she runs on all 8 and goes like the wind....
Day well spent!
Tom
1972 GMC C1500 350/350
1965 Mustang 2+2 289 4spd, show-car
1965 Mustang Coupe 289 4spd, stoplight racer
1/2 dozen Wheelhorse Tractors
tommy3horse is offline
Old 09-26-2018, 11:10 PM   #7287
weq92f
weq92f's Avatar
Thanks! I'm going to try to make the Good guys event this coming weekend at Texas Motor Speedway if the rain stays away! Come by and say hello!
-klb
Originally Posted by nlped View Post
Sounds AMAZING!
weq92f is offline
Old 09-27-2018, 08:01 PM   #7288
TIMCHNE
Got my new license plates
TIMCHNE is offline
Old 09-28-2018, 09:15 AM   #7289
72c20customcamper
72c20customcamper's Avatar
Replaced the trans cooler lines. Po used gas line to fix rusted areas. Needless to say it turned to a mushy black piece of penne pasta like consistancy. All new steel with the proper oil cooler hose.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is offline
Old 09-28-2018, 11:16 PM   #7290
cornerstone
cornerstone's Avatar
Love the plates! It really is like getting into a time machine when i get in one of these old trucks....
cornerstone is offline
Old 09-28-2018, 11:54 PM   #7291
weq92f
weq92f's Avatar
It's not so much what I did as what She did...
weq92f is offline
Old 09-29-2018, 07:43 AM   #7292
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I hope everyone is ok.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Ol Blue K20 is offline
Old 09-29-2018, 09:17 AM   #7293
Barnfind46
Barnfind46's Avatar
I live in DFW. This is not an unusual occurrence.So sorry about your truck!
Old 09-29-2018, 09:08 PM   #7294
Ken O.
got the new headlights installed. Wired the LED Halos up for daytime running lights.
Ken O. is offline
Old 09-30-2018, 01:41 PM   #7295
tdangle
tdangle's Avatar
Temp sender for gauge quit working. Since I had to drain the cooling system, I decided to change out the intake manifold gasket as who ever installed it used the rubber end pieces and of course leaking. Last oil leak fixed. Had an issue with an air pocket causing the gauge to peg, but got it sorted out. Next up is the headlight relay update since its getting dark earlier now.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline
Old 09-30-2018, 04:48 PM   #7296
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
Nothing big but I fixed my exhaust leak at the flange. The flange had cracked so I welded it up. I stuck a small bolt in the crack to fill it up .
No more leak are loudness!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 09-30-2018, 08:44 PM   #7297
Jramirez67c10
Wet sand and some wax. Cleaned up nicely.
Jramirez67c10 is offline
Old 09-30-2018, 08:58 PM   #7298
weq92f
weq92f's Avatar
It's also lower and with darker wheels/trim pieces.... looks real good!
-klb
weq92f is offline
Old 09-30-2018, 11:03 PM   #7299
FL71C10
Bled the brakes and installed the motor in the truck. Making progress!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline
Old 09-30-2018, 11:53 PM   #7300
3757chevy
3757chevy's Avatar
-klb
Lowered the mirror on the door also.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline
Closed Thread
