08-25-2018, 02:35 PM | #51 |
Re: 72 Swb starting from the bottom
Can't wait to see it finished. Keep up the good work.
08-31-2018, 07:14 PM | #52 |
Got ridetech lower strongarms to help level out the truck. The rear was sitting A lot lower. Now the inside of the fender is sitting on the tires and it has lowered an inch and a quarter or so. Still has a lot more to go down but I’m going to set it up so it sits level with the rear.
09-01-2018, 09:28 PM | #53 |
this is an awesome build, i"m piecing together a turbo setup right now for mine, so this is getting me stoked.
09-02-2018, 09:56 AM | #54 |
True imaginary thinking you have. The dash idea is awesome to suit your taste. I like how you say the "original dash never did anything for you" so you just simply change it to your liking. Nice!
09-10-2018, 09:17 AM | #55 |
Thanks! Although I can't take all the credit as a few other forum members have also done this dash swap.
09-10-2018, 08:40 PM | #56 |
With the ridetech control arms in the first thing that became very obvious was these inner fenders aren’t going to work. I found frizzle fry’s inner fender post and kind of worked off of that.
09-13-2018, 09:28 PM | #57 |
Ended up remaking the intercooler mount so I could get a set of filler panels for between the grill and core support. Also, have a pair of viair gen 2 air compressors on the way.
09-18-2018, 08:33 PM | #58 |
Got a 9” tuff stuff booster and got it flush mounted... for the most part. Going to have to modify the steering column bracket a little bit. Also knocked out the studs from the brake pedal bracket so I could mount to this booster. Going to get a rhd s10 master. Hopefully that will be enough for the Brembos. Read about this combo over on the pro-touring forums.
09-21-2018, 11:02 AM | #59 |
Worked on the coldside piping last night. I think I have it pretty much figured out and found a 4” piece for the intake that I think will work out perfect. Also got a dual pack of viair 485c gen 2 compressors. Just need to make the brackets to hold them and the tanks.
09-23-2018, 08:56 PM | #60 |
Got the intercooler piping where I think it needs to be. Still needs welded though.
09-29-2018, 05:19 PM | #61 |
Pushed the truck out of the garage today to clean had to get a picture of it with the c7.
09-29-2018, 10:10 PM | #62 |
The 2 very best choices that a man could want. You've got all bases covered.
09-30-2018, 02:10 PM | #63 |
09-30-2018, 03:13 PM | #64 |
09-30-2018, 03:13 PM | #65 | |
09-30-2018, 10:44 PM | #66 |
I think your dog thinks you're crazy. LMAO!
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
10-01-2018, 06:58 PM | #67 |
Great work.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
10-02-2018, 11:42 AM | #68 |
10-02-2018, 08:07 PM | #69 |
Got the tank and compressor brackets made and mounted. Two 3 gallon tanks and 2 485c compressors
10-04-2018, 10:41 PM | #70 |
Was going back and forth on the shock location and ultimately decided on keeping them in the stock location mainly so that I can run the exhaust out the back. Still have to finish the mounts but here is the rough idea.
10-16-2018, 08:43 PM | #71 |
Got the shock brackets tacked on and the cab pulled off and started working on the exhaust. Splitting the 4” downpipe to a dual 3”
10-18-2018, 09:22 PM | #72 |
Made some more progress on the exhaust. Need to get a driveshaft to make sure I’ll have enough clearance between it and the exhaust. After calling the local driveshaft place and getting a quote on a 2 piece I’m leaning towards 1 piece. I took out the carrier bearing mount and mocked up what a 3.5” driveshaft would be and it looks like it’ll work with a little clearancing on the crossmember.
10-20-2018, 08:36 AM | #73 |
Awesome build!
Curent build:http://67-72chevytrucks.com/vboard/s...d.php?t=764984 |
10-21-2018, 11:34 AM | #74 |
10-25-2018, 12:22 PM | #75 |
Got the passenger side exhaust tacked up back to the axle. Now to get it under the driveshaft without hanging down low.
