Closed Thread
Old 09-30-2018, 02:42 AM   #4976
3757chevy
3757chevy's Avatar
Re: Post Your Craigslist Finds
This bus load aren't scary looking at all .
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline
Old 09-30-2018, 06:49 PM   #4977
FirstOwner69
FirstOwner69's Avatar
Hmm... This is "interesting"... and unique.
https://appleton.craigslist.org/cto/...711500374.html
_____________________________________________________________
For sale is my 68 Chevy C50. It was originally a fire truck with 6,500 original miles. It has a custom built 1 ton independant front suspension based off of a GM 2000-2007 1 ton suspension. The lower control arms are 1 3/4 DOM. .250 wall tube and the uppers are 1 1/2 DOM. .120 wall tube. The steering is a stock style setup with the center link narrowed to meet the new suspention geomatry, massive Alligator Performance inner ball joints , 1" cromolly tie rods and 3/4" hiem joints for the outers. All front componets are brand new Moog or ACdelco. Hydroboost brake booster with front and rear disk brakes. The rear alxe is from an 03 Chevy 1 ton and has 3.73 gears. The frame is the stock 3 ton frame from the back of the cab forward , and the rear of the frame is custom built to acomadate the new ride height. It has a 4 link in the rear with 1 3/4 .250 wall DOM. link bars and panhard bar. The frame is 9" by 3" 1/4" thick C channel boxed in with 1/4" thick formed C channel from the front to the back of the cab. The rear frame is 6" by 3" .250 wall rec. tube. All brackets and parts were designed on CAD and cut out on a CNC water jet. Everything is built heavy duty and made from 3/8 plate and uses 3/4" grade 8 hardware. The air bags are Contitech 2800# bags with 3/8 line and a Little Larrys manual air swich block. The air compressor is gear driven off the engine and the system has two 8 gal. tanks and one 5 gal. tanks with an accesory air line hook up in the rear to air up tires or run air tools. The wheels are 22.5" Alcoa semi wheels that were machined to alow the use of a low prifile passenger car tires with 8 to 10 lug wheel adapters. The engine is a Cummins 12v 190hp P-pump from a school bus with 150,000 miles and the trans is a NV4500 5 speed with about the same milage. It has a South Bend 400hp clutch , pressure plate and master cyliner. The only engine mods are 4k governor springs , boost elbow , and AFC tuning. Exhaust is a 3 1/2" down pipe to 5" staight pipe. Its has a air to water intercooler system with a radiator for the water under the cab with three 10" fans and a Meziere water pump. It has a huge Mishimoto aluminium radiator with two Spal 14" 1900cfm cooling fans to cool the engine. ( ive never seen this thing run over 190 degrees) The gauges are from New Vintage USA and are replicas of the stock gauge cluster. Dakota Digital air gauge pod and for boost and EGT gauges im running Glow Shift gauges. Other then gauges the intirior has not been touched and is it almost perofect condition. The body is completely rust free but oblviously has a few dings and scratchs. The paint is 50 years old bit still has a shine. It has hand painted lettering on the side from the fire department but can be buffed off with and agressive compound if you would like your own lettering on the side. The bed is framed with 2" by 4" .120 wall rec. tube with 3/16 thick tread plate on top. It also has a hole in the top for a gooseneck trailer hitch. Sides are 1/8" sheet designed on CAD , cut out on the water jet and formed on a press brake. For paint and body the bed was metal finished , body filler was applied and it was primed and blocked twice. All seams on the underside were calked , epoxy primer was applied and the sprayed with single stage paint. The outer body was sprayed with a Sikkens semi gloss black. The top was sprayed with LineX bed liner. The chassis and underside of the cab was sprayed with and industrial 2 part expoxy semi gloss black. It has a 7way trailer plug in the rear and a Tekonsha trailer brake controler.
Call/text for price or any other questions. NO EMAILS 7one5.three60.58five0
FirstOwner69 is offline
Old 10-01-2018, 09:41 AM   #4978
Bones72Super
Bones72Super's Avatar
Nice 3/4 ton GMC Camper Special
Needs a little rust repair and someone cut dash for a modern radio
https://pullman.craigslist.org/cto/d...711660577.html
WTB 71-72 Original paint Medium Red hood
WTB 1972 Very nice original Parchment seat belt set
Bones72Super is offline
Old 10-01-2018, 12:59 PM   #4979
swb4me
1969 c20 long stepside.
https://eastidaho.craigslist.org/cto...700575439.html
swb4me is offline
Old 10-01-2018, 01:41 PM   #4980
3757chevy
3757chevy's Avatar
Here is a c50 cab some one needs to revive. https://denver.craigslist.org/pts/d/...694099280.html
MIKE
Old 10-02-2018, 08:17 PM   #4981
Bones72Super
Cheyenne Super 30 Custom Camper!!!
https://denver.craigslist.org/rvs/d/...708878626.html
Old 10-03-2018, 07:42 PM   #4982
Cali72K20
Cali72K20's Avatar
Chevy 5 on 5 Pickup Ralley Wheels, 8 " wide X 15 " - $80
https://visalia.craigslist.org/wto/d...708596694.html
Cali72K20 is offline
Old 10-03-2018, 07:45 PM   #4983
Cali72K20
Cali72K20's Avatar
Hub Caps 'GMC' - $15
https://ventura.craigslist.org/wto/d...702854056.html
Old 10-03-2018, 07:54 PM   #4984
Cali72K20
Cali72K20's Avatar
16x6 Ford 8 Lug - $80
https://slo.craigslist.org/wto/d/16x...700144109.html
Old 10-04-2018, 06:41 AM   #4985
1972 Chevrolet K10 Super Cheyenne 4x4 Pickup $$$
https://dallas.craigslist.org/dal/ct...707875432.html
Not sure what to say about this...1969 chevy 1 ton dually duramax /c10 $$$$$$$
https://dallas.craigslist.org/dal/ct...698423258.html
57NAPCO is offline
Old 10-04-2018, 10:32 AM   #4986
jocko
jocko's Avatar
That K10 is extremely nice - and the price has come down - it’s been for sale for a long time.
jocko is online now
Old 10-04-2018, 10:44 AM   #4987
35boulder
35boulder's Avatar
It does look like a nice truck. Last I saw it was in the low $40k.
35boulder is offline
Old 10-04-2018, 11:23 AM   #4988
davischevy
davischevy's Avatar
The first time I saw it was 6 or 7 years ago with rallys and sans the camper.
It was in the low 20's then. I told the SIL we should go look at it then because it had no way to go but up.
Damn I'm smart.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline
Old 10-04-2018, 12:43 PM   #4989
Lokin4AReason
Lokin4AReason's Avatar
1967-1972 Chevy and GMC Truck Parts
https://knoxville.craigslist.org/pts...695339905.html
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline
Old 10-04-2018, 12:45 PM   #4990
Lokin4AReason
68 chevy c10 1200.00
https://chattanooga.craigslist.org/c...704156310.html
Old 10-04-2018, 12:46 PM   #4991
Lokin4AReason
1967-1972 Chevy/ GMC Pick Up Parts Trucks C10, C20 - $500
https://terrehaute.craigslist.org/pt...689792992.html
Old 10-04-2018, 12:47 PM   #4992
Lokin4AReason
1966 Chevy C10 Short Step - $4500
https://chattanooga.craigslist.org/c...701607298.html
Old 10-04-2018, 12:48 PM   #4993
Lokin4AReason
66 c10 ( project ) - $350
https://jacksontn.craigslist.org/cto...692547352.html
Old 10-04-2018, 12:51 PM   #4994
Lokin4AReason
1964 Chevrolet C-10
https://dallas.craigslist.org/ndf/ct...711789290.html
Old 10-04-2018, 12:52 PM   #4995
Lokin4AReason
1965 gmc short bed fleetside - $5450
https://dallas.craigslist.org/dal/ct...712204286.html
Old 10-04-2018, 12:55 PM   #4996
Lokin4AReason
!!! 1966 CHEVROLET C10 LWB PICKUP !!! PETINA RAT ROD - $4900
https://houston.craigslist.org/cto/d...703919779.html
Old 10-04-2018, 12:56 PM   #4997
Lokin4AReason
1965 Chevy C10 Fleet side SB Big Window Truck front Disc Brake - $2900
https://houston.craigslist.org/cto/d...705684125.html
Old 10-04-2018, 12:56 PM   #4998
Lokin4AReason
Old 10-04-2018, 12:58 PM   #4999
Lokin4AReason
1964 Chevy C10 - $3000
https://mcallen.craigslist.org/cto/d...712089424.html
Old 10-04-2018, 01:00 PM   #5000
Lokin4AReason
76 Chevy k10 - $2500
https://atlanta.craigslist.org/eat/c...714545788.html
Closed Thread
