Closed Thread
Old 10-01-2018, 12:57 AM   #7301
68 SWB
68 SWB's Avatar
Re: What did you do to your truck today? Chapter II
Put the bumper on and headlights back in.
68 SWB is offline
Old 10-01-2018, 11:48 AM   #7302
rustytruck50
rustytruck50's Avatar
Did a much needed tune up on the '98 Silverado Xcab...drives much more better!!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline
Old 10-02-2018, 06:38 AM   #7303
66clow
66clow's Avatar
Originally Posted by FL71C10 View Post
Bled the brakes and installed the motor in the truck. Making progress!
Looking good! Could you shoot me a photo of where the ebrake cable little brackets go thru frame? Just a little further back from your photo. Trying to get my brake hooked up correctly. Your photo almost shows them. thanks
66clow is offline
Old 10-02-2018, 02:05 PM   #7304
NoStopN
NoStopN's Avatar
I got the bed put on a couple of weeks ago, but it's not 100% bolted together or bolted to the frame. But, with a bed on it, I can let it help me around the house. The water heater was leaking bad, so I chucked it into the bed.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 10-02-2018, 02:16 PM   #7305
OregonNed
OregonNed's Avatar
I put in a new headlight relay harness upgrade - still need to dress up the wiring at the battery side, though
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 10-02-2018, 03:01 PM   #7306
Metaldoc
Metaldoc's Avatar
It made a huge difference when I put that system in, now I have head lights that are brighter than the park lights.
Do it, Do it right, Do it right the first time
Metaldoc is offline
Old 10-03-2018, 06:35 PM   #7307
VWNate1
VWNate1's Avatar
Post Easy Brighter Headlights
NAPA's Echlin line used to sell a nifty dual headlight booster relay, it takes the headlight switch out of the load carrying and so brightens up any headlights, even those old GM/DELCO ones from 1964.....
I'm sure there are many headlight by pass relays OnLine .
Another simple thing I do to every single GM product I buy is : take the light switch apart and hand polish (not abrade !) the copper contacts inside it ~ they're always dirty and this simple thing will make any headlights noticeably brighter and not co$t you anything but time and metal polish....
Old DELCO switches are usually pretty well made, I take apart the blower switches too, the improvement is instant .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is online now
Old 10-03-2018, 07:38 PM   #7308
72c20customcamper
72c20customcamper's Avatar
Loaded it up for Carlisle.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is offline
Old 10-03-2018, 07:44 PM   #7309
Slowguy
Don’t know if I’ll ever get to start reassembly because Of the endless cleaning
Slowguy is offline
Old 10-03-2018, 07:54 PM   #7310
Grumpy old man
Grumpy old man's Avatar
All new brakes ,All new parking brake cables, new wheel cylinders, new brake lines, new shocks, cut cross member and welded in 4" tube for tucked exhaust,new 4" drop springs ,New shocks , It's always more fun when they start going back together
Grumpy old man is offline
Old 10-03-2018, 09:19 PM   #7311
VWNate1
VWNate1's Avatar
Exclamation Cleaning
WOW ! you got all that rust off using just a HAMMER ?!? .
Silly me, I did it the hard way .
-Nate
Old 10-03-2018, 09:33 PM   #7312
Slowguy
Re: Cleaning
-Nate
Nope. It took a pipe nipple as well
After I posted, I knew that was coming! Sent the pic to a buddy previously and he says, “oh yeah. I forgot you have no tools.”
I tend to grab whatever is nearby and go to town on it. Sometimes regret it but sometimes it just works out. Waiting on the ball joints and weld-in drop cups to arrive. Then I get to paint. Can’t wait to see that progress and do before-and-afters. I think they may most favorite part of any project; the before and after.
Slowguy is offline
Old 10-03-2018, 09:37 PM   #7313
Slowguy
One more with an “almost” after. Not today but last week. What I was talking about when I said never ending cleaning!
Slowguy is offline
Old 10-03-2018, 10:55 PM   #7314
VWNate1
VWNate1's Avatar
Question Re: What did you do to your truck today? Chapter II
? Are you soda blasting dry or wet there ? .
TIA,
-Nate
Geezer
Old 10-03-2018, 11:00 PM   #7315
Slowguy
TIA,
It’s just sand but also wet blast. Nice finish, clumps up occasionally, uses a lot of sand and makes a mess. Ran out of sand so I didint get to finish completely that day. Next bout will finish for sure.
Slowguy is offline
Old 10-03-2018, 11:03 PM   #7316
VWNate1
VWNate1's Avatar
Thumbs up Rust Blasting
Thank you .
I live in town and so cannot sand/bead blast .
I'm pondering buying a soda blasting nozzle from Harbor Freight for some smaller items .
-Nate
Geezer
Old 10-03-2018, 11:06 PM   #7317
Slowguy
Soda would be nice for delicate stuff and may even work for the frame but I think you’d need much more volume to do rusty old steel like this. When the sand flowed well it peels back the years like nothing. Wet is actually messy but kinda nice. If one was to better control the environment (like I did not) I would imagine it would be much less of a mess. A tarp my have been nice to place beneath.
Slowguy is offline
Old 10-04-2018, 10:23 AM   #7318
70CHEVYBB
70CHEVYBB's Avatar
My nights have been a mess so i have been getting up at 5 a.m. and putting a little time in on the truck. installed both doors fenders and grille the last two mmornings
70CHEVYBB is offline
Old 10-04-2018, 11:14 AM   #7319
UNEASYRIDER
UNEASYRIDER's Avatar
Made a cab cover for when she sleeps outside.
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 10-04-2018, 12:55 PM   #7320
weq92f
weq92f's Avatar
Ahhh, morning brew!
Love it!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline
Old 10-04-2018, 08:26 PM   #7321
Slowguy
Man that’s a nice body.
Slowguy is offline
Old 10-04-2018, 09:14 PM   #7322
Metaldoc
Metaldoc's Avatar
The frame was the only piece of my truck I had someone else do and only because it soda blasted. Such a nice job to go over with primer. I blasted about 1000lbs of sand and put tarps down but wasn't very successful at recovering product. As you blast you blow away the sand on the tarp. Good work thou.
Metaldoc is offline
Old 10-04-2018, 09:16 PM   #7323
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
A little wiring tonight. I re did the wires on my markers and got all of them working again!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 10-05-2018, 09:25 AM   #7324
paul blair
Looking good Andy, can't have too many lights. Spot light next? Gotta have a spot light!
paul blair is offline
Old 10-05-2018, 03:29 PM   #7325
Andy4639
Old member
Andy4639's Avatar
Yes I agree. I have it sitting in the garage just haven't took the time to mount it yet!
Andy4639 is offline
Closed Thread
