Old 10-14-2018, 05:55 PM   #1
Dan-K
Block I.D. ?
Just picked up a used 350 . Casting # on the rear of the block is 3970010 . The casting # on the pad on the passenger side front block is V0302TJA . Do I have anything special here ?
Dan-K is offline   Reply With Quote
Old 10-14-2018, 06:31 PM   #2
Chevyrestorerman
Re: Block I.D. ?
All depends on the nickel content of the block, anyone can stamp letters on the deck of the block to make it what they want. Thousands of 010 blocks were made, so when you ask if its special, it only can be special because its yours.
Chevyrestorerman is offline   Reply With Quote
Old 10-15-2018, 01:14 AM   #3
Captainfab
60-66 Nut
Re: Block I.D. ?
No nothing special. It's either a '73 or a '79 350 from a truck. It could be a 4 bolt.
http://www.nastyz28.com/gm-chevy-cod...s-suffix-7.php
Old 10-16-2018, 06:23 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Block I.D. ?
3970010 was the most common 4" bore block GM ever made. All this "high Nickle" stuff isn't gonna make anything more valuable with these blocks. They are good sturdy blocks and will be 2 or 4 bolt main.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 10-18-2018, 08:43 AM   #5
Chevyrestorerman
Re: Block I.D. ?
Yea, the nickel content is most likely a myth but I was hoping someone would jump in and add valuable information on how someone would know the tin/nickel content of a GM 010 casting. What does the 010 020 on the front of the block represent, that maybe a myth as well.
Old 10-25-2018, 08:02 PM   #6
hjewell2
hjewell2's Avatar
Re: Block I.D. ?
20% tin10% nickel
hjewell2 is offline   Reply With Quote
Old 10-26-2018, 04:52 PM   #7
Myself
Re: Block I.D. ?
Actually it's an extra 1% tin and 2% nickel.
Myself is offline   Reply With Quote
Old 10-26-2018, 06:16 PM   #8
crazy longhorn
Fabricate till you "puke"
Re: Block I.D. ?
What I have seen on the 10/20 blocks, is less wear on the ridge....they tend to clean up, on a .030 bore after 100 to 125 tho? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
