Old 10-19-2018, 05:50 AM   #1
72farmer
What can i do with vent on Boyd's fuel tank
I am in the middle of installing my Boyd's EFI under bed tank. I did not buy a roll over valve for the tank. I am planning on just running my vent with 3/8" hose and secure it above the tank somewhere. Kinda like the rearend vent hose. What can I put on the end of the 3/8" hose vent pipe to keep dirt/dirtdobbers etc. out and still vent?
72farmer is offline   Reply With Quote
Old 10-19-2018, 06:20 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: What can i do with vent on Boyd's fuel tank
https://www.iimuch.com/collections/f...erential-vents
Rich
1972 K5 Blazer CST Click HERE
Old 10-19-2018, 06:24 AM   #3
notsolo
notsolo's Avatar
...in answer to your question, years ago I used a cheap fuel filter on the end of my vent lint to keep dirt and bugs out.....On my Boyd tank I used a Coyote roll over vent, bought off Ebay..$10.00
notsolo is online now   Reply With Quote
Old 10-19-2018, 07:08 AM   #4
72farmer
Man that is cheap enough on the Coyote valve. Do you still have to use a hose and mount it above the tank? And still worry about stuff getting into the end of the hose?
Old 10-19-2018, 07:15 AM   #5
GMCPaul
Check out roll over vent valves. Here's 1 from summit.
https://www.summitracing.com/parts/t...hoCgaAQAvD_BwE
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 10-19-2018, 01:10 PM   #6
68is4me
68is4me's Avatar
I am using the roller valve, into a fuel hose and attached to fuel filter at the end. I figured that the fuel filter would help catch any dust or dirt. I mounted the filter (or the top of the vent) above the fill hose. I figured that if was mounted at higher point that it might keep the fuel from coming out the vent on fill up. Maybe the roller valve would stop it too.
The only problem I have is the fill up is kind slow, but that maybe the way I have the side fill tank and hose's mounted.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 10-19-2018, 01:50 PM   #7
pappy 2
what I did.
pappy 2 is offline   Reply With Quote
Old 10-19-2018, 07:59 PM   #8
zicc1835
zicc1835's Avatar
Originally Posted by pappy 2 View Post
what I did.
thanks for this pic...mine just laying on the frame i bought it from another board member a couple years ago looking to do the sniper EFI may get back with you to pick your brain ....
zicc1835 is offline   Reply With Quote
Old 10-21-2018, 08:35 AM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What can i do with vent on Boyd's fuel tank
The longer the hose the faster it will fill up. Take and run the hose up to the charcoal canister under the battery. That's what it's for.Try and get the hose up off the tank even a few inches is worth it.
https://www.marinedepotdirect.com/fu...aight-5-8.html
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
