Old 10-19-2018, 05:46 PM   #1
elorenzof
Front tires "scrub" when turning after disc brake conversion
Hi all, I have just completed a front end disc brake conversion on my 1970 c10 using classic performance front end steering and spindle kit.(2/12" drop). It has changed the angle of the tires when i turn into or have to turn sharp to back into spaces. the tires "scrub" i guess i could call it they dont roll smooth anymore and it's quite annoying as when they are doing this it creates resistance to the rolling. How can i fix this? I have had it aligned and i saw the specs they are good and there is no alignment issue while going down the road. Any help would be appreciated it's really bothering me.
elorenzof is offline   Reply With Quote
Old 10-19-2018, 06:06 PM   #2
geezer#99
geezer#99's Avatar
Re: Front tires "scrub" when turning after disc brake conversion
Are the tires scrubbing the fender lip or the inner wheel Well?
Old 10-19-2018, 06:44 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Do you have 15” wheels?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 10-20-2018, 10:52 AM   #4
elorenzof
[QUOTE=geezer#99;8367795]Are the tires scrubbing the fender lip or the inner wheel Well?[/QUOTE
No, the tires are not touching anything but the ground, it's just that the tires now angle when turning
Old 10-20-2018, 11:04 AM   #5
elorenzof
275/60R15 Cooper Evolution tires. I bought the truck and it already had this size in BFG's but they were severely dry rotted. So I bought these. I have rallye wheels 6 lug
Old 10-20-2018, 11:06 AM   #6
Boog
laying low
Boog's Avatar
Have a look at the inside lip of the wheels. They may be rubbing the lower control arm when turned. Common issue with drop spindles and 15” wheels. Easy fix.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-20-2018, 12:03 PM   #7
geezer#99
geezer#99's Avatar
[quote=elorenzof;8368154]
Ah!
Tire scrub, not rub!
Clearly you’ve changed your ‘Ackerman’!
Look here for info on that.
https://en.m.wikipedia.org/wiki/Acke...ering_geometry
Wider tires and offset spindles will do that.
Old 10-20-2018, 01:20 PM   #8
elorenzof
Ok thank you i will look at that. I have it at the shop right now im goona go in and lower the rear tomorrow. I'll look then. thank you. what is the fix would you put spacers in?
Old 10-21-2018, 08:54 AM   #9
Boog
laying low
Boog's Avatar
If upon inspection you see evidence of the wheel rubbing the lower control arm when turned it usually will contact the outer lip area around the lower ball joint. This is a common issue for us using stock offset 8x15" wheels with lowered spindles.Many of us have gained the needed clearance by grinding the lip in that area back a couple of inches. If the wheel is rubbing there will be witness marks on the wheel and control arm. You may be able to add a 1/4" wheel spacer to get enough clearance. Many of us chose to grind the lca.
Look it over good first and see if this is the case with yours then use the forum search button to see numerous threads on it.
Boog
primer is finer
disc brake conversion, scrubbing
