10-20-2018, 03:39 PM | #26 |
Re: 1970 c10 distributor upgrade recommendations
I've read the difference is the Skip White stuff uses cheap electronics. That seems to be the case with the one I bought. It couldn't even fire the engine.
72 C10 lwb fleetside -stock 350/350 combo |
10-20-2018, 04:04 PM | #27 | |
Clears the firewall no prob on install and works great 2 years now
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
10-20-2018, 04:28 PM | #28 |
Do your research. If you are basing your opinion on the price and haven't seen or held his HEI you are uninformed. Skip White's HEI is vacuum advance and it's NOT cheap crap!! It even comes with a lifetime warranty. Look at the reviews and Youtube on it. Or don't, freedom of choice.
1969 CST/10 396 |
10-20-2018, 05:34 PM | #29 |
I picked up a brand new gm heI that came out of a new crate motor. Craigs list for 75.00. I use it every day no problems.
10-20-2018, 06:22 PM | #30 |
If your set on HEI then I would get a Factory GM unit and have it rebuilt and curved by a competent rebuilder. The factory units are good just not as shiney and none of the aftermarket ones will come curved for you truck. So new or used you would still want to have the unit's advance curve dialed in for your combination. I've bought dozens of used HEI's for between 5 and 40 bucks.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-20-2018, 06:42 PM | #31 |
Moderator
Before you buy a new distributor, you should determine if the new 350 engine you are installing has a flat tappet or roller cam installed....
Roller cam engines, require a melonised distributor gear be installed on the distributor shaft. Sure, you can buy any distributor and install a melonised gear, but why not buy the correct unit first up... So may be a good idea to decide on the engine first, then worry about the incidentials.... IMO, unless I am performing a true back to factory original build, I usually go with a later model Vortec style engine...roller cam, one piece rear main seal, and less wear generally. Anyhoo....have fun...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
10-20-2018, 06:46 PM | #32 |
Here's another find, any experience with proform?
https://pitstopusa.com/i-5080822-gm-...e-red-cap.html |
10-20-2018, 07:38 PM | #33 | |
10-20-2018, 07:45 PM | #34 |
This!
10-20-2018, 07:58 PM | #35 | |
btw, I've been using a Skip White hei in our daily driver for nearly 2 years now with zero issues - fwiw.
My Chevy Truck Project Build Thread '62 Ranchero - 200 I6, 3-on-the-tree, power nothing. '71 LeSabre - 455 Stage 1, power everything. |
10-20-2018, 08:12 PM | #36 | |
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
10-20-2018, 09:12 PM | #37 |
I spent more than twice as much on my plug wires than my skip white ready to run. HEI distributors for stock applications... can you say appliance. Skip White Ready to run, a simple appliance. It burns the gas.
My two cents, worth the price paid. j
White K20 |
10-20-2018, 09:17 PM | #38 |
1972 GMC K2500 Super Custom Matt |
10-20-2018, 09:23 PM | #39 |
10-20-2018, 11:45 PM | #40 |
I found this. Doesn't say a lot tho. https://www.jasperengines.com/crate-engines
10-21-2018, 09:36 AM | #41 |
Old member
Just go to any junkyard and pull a HEI off any small block GM product and install it. It's that simple. When I did my TPI motor I pulled one out cleaned it up and reinstalled in my 305 TPI. 325,000 miles later when I sold it, it was still working with only one module swap.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-21-2018, 11:06 AM | #42 |
Not quite. I advocate pulling a stock GM HEI distributor from the junkyard (especially since its CHEAP), but not just stabbing it in there. It needs to be setup correctly first before installng it. GM used a wide variety of internals in the smog area so you never know what you're gonna find. So if you go the junkyard route, you're probably gonna need a new cap & rotor at least, and need to get the #375 centerplate and #41 weights to give you 22 degrees mechanical advance. You'll have to scour junkyard distributors to find these. Or rob them from an aftermarket distributor since they use this combo of weights and centerplate as well. You'll also need an adjustable vacuum advance because a lot of those GM units provide way too many degrees of vac advance. Buy the Crane 99600-1 vac advance kit, it comes with an adjustable vac can, a travel limiter, and 3 sets of advance springs. Install 1 blue/1 silver spring so the advance will be all in at 2800 rpm, limit vac can to 10-15 degrees advance, and adjust vac can to 2-4 turns out from bottomed out for your vacuum level. Or you could save yourself the time and talk to this guy: https://www.davessmallbodyheis.com. He's the HEI master and will make a custom curved dist for you doing all the stuff I mentioned and more.
10-22-2018, 03:54 PM | #43 |
Is anyone out there using using a small cap HEI or electronic distributor? My K1500 has an MSD streetfire distributor that works OK except that the vacumn advance is not working. I want to switch to a small cap as the Streetfire (same size as GM HEI) sits about an eighth of an inch from the firewall. This clearance issue may only occur on the K trucks. Any small cap reccomendations?
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
10-22-2018, 04:15 PM | #44 | |
10-22-2018, 04:19 PM | #45 | |
