Need help adding Clutch Pedal
Anyone have advice on converting my brake pedal assembly to a clutch/brake pedal assembly with hydraulic clutch. Is there a aftermarket setup that works well or should I try and convert the assembly I have by adding a clutch pedal ? I'm not sure if it's even possible. Lokar offers a direct fit assembly but looks like the clutch push rod is on the right of the brake pedal? I've seen photos where the the clutch slave cylinder is mounted on the right side of master cylinder on the firewall. I'm not sure how that's being done.
