Old 07-19-2018, 07:47 PM   #26
racecougar
racecougar's Avatar
Re: PCM is not grounding fans properly
So then you're only going to run one fan speed?
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 07-19-2018, 07:48 PM   #27
jrpontiac
jrpontiac's Avatar
Yes. Instead of one kicking on at 195 and the other kicking on at 205 they will both kick on at 205. I suspect it will be fine. Is a manual tranny with no A/C.
1977 Chevy C10 SB, Turbo 5.3ls, TH400
jrpontiac is offline   Reply With Quote
Old 10-24-2018, 11:15 AM   #28
barbl52
Same problem here. One fan works great 2nd fan pulses and relay clicks. 2000 5.3 4L60E swapped into a 72 C10. Don't have ac hooked up but that is why I bought a 2 fan set up. I will update post if I figure it out.
67 c20 68 c10 72 c10 69 GMC 72 short step
barbl52 is offline   Reply With Quote
Old 10-24-2018, 11:29 AM   #29
jrpontiac
jrpontiac's Avatar
deleted response
Old 10-24-2018, 02:17 PM   #30
racecougar
racecougar's Avatar
See posts #21 and #23 in this thread on how to correct the issue in the tune file.
