Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-02-2018, 09:06 PM   #1
NJKelly
Replacing the flexplate on a 350 1972 what else should I do while I'm there
Title says it all I figure if I have it open maybe it would be good idea to replace the rear main seal. Engine is leaking oil I'm not sure from where I thought about just wiping the whole thing down so I can identify where it's leaking from. it's an inexpensive part and with the transmission out should be able to see get it done easily, even if it's not leaking just to have it be one less thing to worry about. I'll probably regret saying that last part LOL
NJKelly is offline   Reply With Quote
Old 11-03-2018, 08:29 AM   #2
82C10step
Re: Replacing the flexplate on a 350 1972 what else should I do while I'm there
Well you would have to take the oil pan, oil pump, and rear main cap off to change the seal. Are you up for that too?
82C10step is offline   Reply With Quote
Old 11-06-2018, 11:24 AM   #3
NJKelly
I'm up for whatever has to get done. I've been reading up on how to diagnose that the rear main seal is the problem and if it's not leaking there I'll leave it alone but there is no pointing putting a flexplate back on until I dealt with that.
Old 11-06-2018, 12:02 PM   #4
rpmerf
rpmerf's Avatar
I replaced the flexplate on my truck back in May. Not sure what your plan is, but I was able to replace the trans bolts with 6"-8" bolts, and move the trans back just far enough to get a socket between the torque converter and flex plate. It makes it a little bit easier as you don't need to remove the trans from the truck.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 11-06-2018, 12:32 PM   #5
NJKelly
I read up on that very thing posted by someone else and actually shared it with the board here. It's different for a K5 versus a pickup truck. I'm going to try to do that but I picked up a transmission jack pretty cheap just in case. I hope to just keep transmission in the general vicinity if not with the bolts with a Jack and do as you say. Having said that I might need more room to get at the rear main seal in which case transmission comes completely out.
Old 11-06-2018, 03:50 PM   #6
truckster
truckster's Avatar
2WD vs 4WD is a lot different, because the transfer case is in the way. And they're not very light.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
