11-03-2018, 01:04 PM | #26 | |
Re: Best fuel line thread sealant?
If you look inside the carb fitting, some of the inverted seats in the inlet nuts were smaller than one would think. I believe (as others have stated...) that the taper on the fitting you installed, and inverted seat are not touching to make a seal. You MIGHT be able to grind the end of the threads down (make the end flat)some to make those 2 pieces meet...the might part is some what iffy. I believe your new fitting is made of steel ( a magnet will tell). It may not mate together with the inverted seat in the carb fitting....... The steel tubing works better because the flared end inside the nut is some what soft and pliable, allowing the inverted seal...so thatm,ight be your only way to go, for a while. Using 2 clamps is a good idea, I usually always use 2 clamps. if possible... |
11-03-2018, 01:51 PM | #27 | |
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
11-05-2018, 09:22 AM | #28 | |
LOL, I think the race car person needs to come over and bend up a piece of steel line!!! |
11-05-2018, 10:31 AM | #29 | |
11-05-2018, 10:35 AM | #30 | |
You might be correct about how YOU use use, but it's still properly called PTFE Thread Seal Tape. I've been calling myself a plumber for over 40 years and selling sealants longer than that! The tape is intended to seal in SPECIFIC applications, though in reality most applications people try to use it on here wind up being a flare or compression seal that the threads have no role in doing anything except clamping anyway. So you're right that people here shouldn't call it thread seal the way they use it, but it still is called that, and particularly in LPNG, it's meant to seal in some cases.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
11-05-2018, 10:54 AM | #31 | |
11-05-2018, 11:22 AM | #32 |
Give me an RO number you order it under at NASA. What's it called, Willie? Sealant.
11-05-2018, 11:27 AM | #33 | |
You can take a close measurement and get a piece that is slightly long thatn what you need. You can generally make the bends work to make connections on both ends. Not particularly easy, might buy 2 pieces (I usually do, and I have done this too many times, experience wise...). Mr race car might be able to gitterdone easily! Then I would place the inline fuel filter in the hose feeding the pump... Did you ever find center caps for your aluminum wheels??? Those look to be Western (Brand name) turbine wheels. Might have to measure the hole size and go from there. Not sure if Western still makes aftermarket wheels. An internet search might do the job...I prefer rally wheels...although those turbine wheels would look better with some TLC, and polishing the smooth surfaces. THere are folks that restore wheels, your's wouldn't need much, but some of those companies don't know when to stop charging for their services... |
11-05-2018, 11:30 AM | #34 |
NASA doesn't use RO numbers, sorry. But I can tell you that I just did a quick search and out of about 60-65 line item descriptions for TEFLON TAPE or PTFE, the word SEAL or SEALANT was not in any of them.
11-05-2018, 12:16 PM | #35 |
If you won't be specific I can't help you. There is a ptfe film tape used as a thread lubricant, but it's different from the thread sealing tape pictured here.
As for the stuff in this thread, https://en.wikipedia.org/wiki/Thread_seal_tape
11-05-2018, 12:43 PM | #36 | |
11-05-2018, 12:56 PM | #37 |
Alright, I sure don't want to hop in this or see it continue on. But in the quote above it sure looks like a contradiction. Ok, so it's a component used in creating a seal. Is the tape a seal? No. Are the treads a seal? No. But Teflon tape used on threads creates a seal. The fact is it doesn't hurt to use it in this case, even if it's belts & suspenders. What is really needed is a correct fuel line.
11-05-2018, 01:04 PM | #38 | |
I'll just leave this exerpt from 3M Part Number 48, their teflon thread sealant tape, which explains how it should be used. Reader can decide if what you're saying jives with the manufacturer: "Scotch® Thread Sealant and Lubricant 48 is a white unfused plastic film made of polytetrafluoroethylene (PTFE). This fluorocarbon resin film tape designed to provide a leak-resistance seal when used as a pipe thread sealant." I can guess the next steps, so I'll leave them to the reader as an exercise and take my leave... I don't personally use any of the stuff in fuel applications, for what its worth. Maybe on bushings and other tapered-thread stuff. Can't think of anywhere its under pressure through, in stock form I think it's all taper or clamp.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible Last edited by davepl; 11-05-2018 at 01:09 PM. |
11-05-2018, 01:47 PM | #39 |
ok bud. you win, you got the last word.
11-05-2018, 02:38 PM | #40 | |
I just sold my Rally wheels to a board member!
11-06-2018, 04:39 PM | #41 |
Teflon tape does serve to lubricate threads. But not made for sealing? That is a new one. It is designed and used for that very purpose millions of times every day. Grades depending on application. Red for larger joints. Yellow for fuels, Green for sealing oxygen systems, and so on.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
11-07-2018, 12:24 PM | #42 |
There are several types, as you note. It's quite possible that Willie is using a style intended only to prevent galling, and that has nothing to do with sealing. That's why I asked for the RO or part number early on to look it up instead of guessing.
I think the best answer is "it does both" but there are only certain applications where it's is appropriate as a sealant. 95% of the people using it on the threads have no idea that the seal is from a 45 or 37 degree tapered flange and not the threads anyway! Other than where your pipe nipple screws into the intake manifold for your heater hose... not many places.
11-07-2018, 12:30 PM | #43 |
Good info Dave!
Far too many people believe that if it has threads it needs sealer. And the same people use a whole tube of silicone sealant where a thin bead is all you need. |
11-07-2018, 12:34 PM | #44 |
Hey, Google, Western wheels center caps, you may find an answer to your center cap situation....
11-07-2018, 04:18 PM | #45 |
OK, shouldn't need to use any sealant, as it is a single fare. I mean how long has these trucks been on the road with out a fuel leak, you would think there would be a recall by now.
Pulled a old carb off the shelf, to take the fitting apart, first wrench (pipe) started to round out the nut, so I grabbed one of my new wrenches, and it grabbed the shoulder much better, had to tap it with a wooden handle. That sucker was on there!!!! [url=https://flic.kr/p/QALDQS]20181107_145137 After both the adapter and fuel line were off, there is no obvious reason why this fitting should leak, unless the flair is cracked. The PO did use teflon tape, as there is still remnants of it on the fuel line [url=https://flic.kr/p/29XW22d]20181107_145056 JMHO, but there should be no reason to use any sort of teflon with fuel as I believe the fuel breaks it down.....use it on your kitchen faucet
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-07-2018 at 04:28 PM. |
02-04-2019, 04:06 AM | #46 |
In case this is still up for discussion. Try "lapping" the inverted flare portion of that brass fitting or any flare type of joint. How I usually go about it when I am either bending a premade length of steel tubing with tube nuts already installed, or creating a new inverted flare on a piece of steel tubing is: first use a tubing cutter. Take a rat tail file or round chainsaw file and ream the i.d. of the tubing. Then take a fine cut flat file and put a slight chamfer or bevel on the o.d of the tubing.(really only necessary for double flaring of lines.) Then put a thin smearing of high pressure wheel bearing grease on the conical flaring die.(also in tube bending channel if making a bend, it allows smooth operation of the bender and flaring die.) Onve the flare is made wipe with a rag, grab a piece of 1500 or 2000 grit paper and use your finger tip to work the flare smooth,wipe again and your done. On double flares I put a little water on the sand paper to help cut the seam joint down a little faster. But same result. Oh, and now I ALWAYS put those store bought premade pieces into my flaring block and "seat" the flaring die to ensure the flare is concentric. Meaning just enough pressure to ensure it's even. Or another suggestion if it's possible, is to make the flare nut joint up by hand then rotate the tubing into the joint, once you cant turn it anymore back it and the nut off a 1/4 turn then the tube a 1/4 turn beyond that and retighten by hand. I do this a couple of times at different spots on the tube. In my opinion, ever since I began doing these simple quick things, i have yet to have a leak. It's also important to use 2 wrenches when tightening a flare joint and as long as the wrenches are the correct size, dont be afraid to put some torque into it. If you start rounding the nut off, then you dont have the right wrench or the tube nut is cheap.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
02-04-2019, 10:57 AM | #47 |
