Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 10-01-2018, 05:36 PM   #26
gup1972
Re: 1969 C50 crew cab build
Well here are a few more pics of progress.
gup1972 is offline   Reply With Quote
Old 10-01-2018, 05:37 PM   #27
gup1972
Found another mistake. If you ever build a frame for a C50. The drop amount from the top of the frame to where the front clip sits across the frame rails is 4.25". Not the 3" I somehow measured off the C50 when it was fully assembled. Other than that, everything on the frame seems to work well.
Old 10-01-2018, 05:39 PM   #28
gup1972
If anyone is interested in WAS running and driving C50 without the cab and front clip let me know. Everything is there except the cab, front clip, and radiator.
Old 10-01-2018, 08:55 PM   #29
jdl71
jdl71's Avatar
Whereabouts?
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 10-10-2018, 06:33 PM   #30
gup1972
Near Union, MO.
Old 10-13-2018, 02:07 PM   #31
gup1972
Here is the front end after cutting another 1.5" off the top to fix my mistake. I will make a 3/16" plate that I will weld inside the frame rail to beef it up. My jeep frame is the same height and thickness on the front and I have beat the tar out of it and never had an issue. The extra 400 lbs of the diesel won't be a problem for a road driven vehicle.
Old 10-13-2018, 02:09 PM   #32
gup1972
With any luck I will get the top plates made and welded on today.
Old 10-13-2018, 05:47 PM   #33
CarolinaHD
Moderator
CarolinaHD's Avatar
Nice fab work keep it up! This is what I want to do long term with my 67 c50.
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 10-13-2018, 08:13 PM   #34
gup1972
Got it all sewed up tonight. Looks like where I was 2 weekends ago! Will try the front clip again tomorrow when I get some help from a buddy. The next step is to remake all of the rubber body mounts out of polyurethane.
Old 10-13-2018, 08:16 PM   #35
gup1972
Now to settle in and listen to the Mizzou vs Alabama game. Hopefully they can stay within 18 points and cover the spread!
Old 10-14-2018, 05:51 PM   #36
gup1972
Mizzou got spanked...
Got the front clip on and have the mount for the front grill all measured out and ready to mill. For the front cab mounts I used the factory C50 brackets. I bought a body mount kit for a C-10 from energy suspension (3.4108G) and the bushings marked "4010" are a perfect fit. The back cab mounts are 3.50" tall and will have to be made. Hold on to your shirt when you go to buy 3" diameter 85A polyurethane!!!! Expensive stuff.
Old 10-14-2018, 07:33 PM   #37
sweetk30
sweetk30's Avatar
why not do like the off road guys do and make a spacer block out of aluminum ? if you have the right size bushing minus its height .
lots of guys doing this for 1" -1.5" body lifts these days .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-23-2018, 09:45 PM   #38
gup1972
Got the 2nd cab this weekend. It needs rockers and corners. The crossmembers and underneath are very nice. One of the nicest cabs I have ran across in a while. A neighbor of mine had it. I got lucky on this one!
Old 10-23-2018, 10:19 PM   #39
Getter-Done
Getter-Done's Avatar
Looking good.
I like your progress.
Looks like you have a great Plan.
I am watching because my cab is at the sandblast Man's place.
After that will be my CC journey.
84 Chevy K-20
Old 11-03-2018, 04:28 PM   #40
gup1972
Haven't had much time to work on it lately. Busy, busy like everyone else now days. I included a pic so everyone can see how the clearance I had to redo on the frame for the front clip worked out. Measure twice and cut once, right?? Not in my shop I guess...
Old 11-03-2018, 04:29 PM   #41
feller
feller's Avatar
So is this going to be a 2 cab conversion? In other words no burb? I'm excited to see this
feller is offline   Reply With Quote
Old 11-03-2018, 04:32 PM   #42
gup1972
a couple more pics
Old 11-03-2018, 04:35 PM   #43
gup1972
That's the plan anyway. I have no body work experience at all but I think I can get it figured out. Not sure how I am going to mate the cabs yet. After deer season I will start cutting the back of the 1st cab off and the front of the 2nd cab off. Then we will see what it is going to take.
Old 11-03-2018, 08:49 PM   #44
feller
feller's Avatar
Awesome!! I am in the no body work club too, but I have thought it over quite a bit, Especially since I have 4 cabs setting in my barn. I had to call a friend to talk me out of cutting 2 of them to pieces last week Haha
Old 11-03-2018, 10:54 PM   #45
gup1972
Lucky you! I wish I had 4 cabs to work with. I have looked long and hard for these 2 cabs. There is this guy in Hermann MO that I went to look at some parts at. He had at least 6 perfect cabs...and I mean perfect. He also had 3 primo Blazers. Dude wouldn't sell anything. I guess he just wanted to brag and tease me. I don't blame him, I am sure he has a lot of time in finding them. But why advertise and then not sell.
Old 11-03-2018, 11:27 PM   #46
6BT 56
6BT 56's Avatar
This looks like a great build . Can I ask why you didn't want to use the original frame ? I would guess there plenty strong ? Keep up the great work . I'd love to build a reg cab truck like this with a big flat bed .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 11-04-2018, 02:35 PM   #47
gup1972
The original frame had several fire truck items that had been welded on and cut off over the years. It probably would have been fine but would have required a BUNCH of cleanup, etc. I really have no reason other than I wanted to I guess. In hindsight I would probably be much further along than where I am.
Old 11-12-2018, 12:11 PM   #48
*Subject2Change*
Question. I bought a 69 c50 and Im going to swap in my 79 K3500 DRW axles in. Any idea how close the spring perches are to a 3500 axles? I dont have my hands on the c50 yet.
*Subject2Change* is offline   Reply With Quote
Old 11-16-2018, 02:36 PM   #49
gup1972
The frame width on a C50 is 34" to the outside. Not real sure what the perch width is on a 3500DRW. It will depend on the spring mounts you choose to use to mount the springs to the frame. It's easy to cut the perches off and weld a new set on when you get all shackles and springs, etc mounted to the frame.
Old 11-16-2018, 05:57 PM   #50
*Subject2Change*
I'm picking my c50 up Sunday and the k3500 parts are at a friends house so its hard to plan. My 60 front perches are 32 so were def in the neighborhood. Thanks for looking.
