Old 10-16-2018, 03:36 PM   #101
dsraven
Re: Starting a 52 Chevy 3100 Project.
have you done a "tire on and suspension at full compression" turning test to ensure the rubber doesn't tear a fender off when turned all the way and the suspension bottoms? with the spacers the tires do more of a sweep during a turn so they may get closer to the wheel openings than you may realize. it would suck to find that out too late.
I am sure you have done the research and found the video on scrub radius, tire size and wheel offset issues and steering included angle etc. your truck, do it like you want. as long as it is safe to drive on the same roads as the rest of us and our kids.
dsraven is online now   Reply With Quote
Old 10-16-2018, 04:55 PM   #102
28TudorAZ
28TudorAZ's Avatar
Considering I just put them on there 3 days ago and the cab and front end are still off what do you think? I guess I will see when it actually runs and drives and adjust accordingly.
28TudorAZ is offline   Reply With Quote
Old 10-16-2018, 05:58 PM   #103
dsraven
oh hey, sorry man.
bye bye
Old 10-17-2018, 03:28 AM   #104
MiraclePieCo
MiraclePieCo's Avatar
Originally Posted by 28TudorAZ View Post
Exactly. Everyone has heard. I researched it quite a bit and never found anyone who actually had the issue.
Awesome, lol - opinions are plentiful, experience is rare!
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 10-17-2018, 11:08 AM   #105
mikebte
Exactly. Everyone has heard. I researched it quite a bit and never found anyone who actually had the issue..
Crazy the stuff people make up. Porsche used wheel spacers from the factory on the 928 and it would run 170MPH. I think if used correctly you will have no issues. Correctly being the key word.
I remember 10 years ago I was telling people how an electric fan was better than a mechanical fan. You would think I was taking ways peoples kids, they would tell me how wrong I was and it was a phase. Now look. Most people speak hear say and not facts.
Keep up the good work, enjoying you build
mikebte is offline   Reply With Quote
Old 10-18-2018, 04:15 AM   #106
Jesse Z
Their opinions are typically given with dire warnings about you killing busloads of orphans and not being on the same highway with their family, lol!
Enough digression: back to the build thread please!
Jesse Z is offline   Reply With Quote
Old 10-20-2018, 12:53 AM   #107
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
Well I actually work for Porsche as a tech, 10-15mm spacers are nothing to bump out a wheel for fitment. But when you increase that to 3+inches, you are changing the geometry of the front end.
GreasyLikeaBurger is offline   Reply With Quote
Old 10-23-2018, 12:51 AM   #108
28TudorAZ
28TudorAZ's Avatar
So I got the cab back on over the weekend and welded up the firewall holes and bolted it up. Also today I had the day off and put the 2" lowering blocks on the back axle and welded up a bunch of holes on the inside and old fuel filler hole. I also ordered a steering column, steering shaft, steering joints, transmission cooler, a 16 inch fan and a pedal assembly today. This should keep me busy for a while. Not that I don't have anything to do but I like to skip around so I don't get frustrated or bored. Plus I can't put the front end back on till all of this is on there.
Old 10-25-2018, 07:34 PM   #109
28TudorAZ
28TudorAZ's Avatar
Finally got the dash ready for paint.
Old 10-25-2018, 07:48 PM   #110
joedoh
joedoh's Avatar
looks great!
Old 10-28-2018, 12:50 AM   #111
28TudorAZ
28TudorAZ's Avatar
Built the brackets for the radiator support, fan brackets and mounted the transmission cooler today.
Old 11-03-2018, 06:43 AM   #112
54ChevyLs
54ChevyLs's Avatar
Your doing some excellent work! Keep it up!
54ChevyLs is offline   Reply With Quote
Old 11-03-2018, 09:44 PM   #113
28TudorAZ
28TudorAZ's Avatar
Thanks. Got the steering column mount made up.
Old 11-04-2018, 08:36 AM   #114
8man
Nice looking dash, good work on the vents.
I got the same steering column installed with my buddy in the 48.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 11-04-2018, 05:32 PM   #115
28TudorAZ
28TudorAZ's Avatar
Got the power booster and pedal assembly put in. If you don't use the s10 pedal setup you can cut the end of the brake rod and tap it to use with aftermarket pedal assembly.
Old 11-04-2018, 10:00 PM   #116
mikebte
That's looking great! Keep it up
Old 11-06-2018, 07:53 PM   #117
28TudorAZ
28TudorAZ's Avatar
Thanks. Got the brake lines cut and took them to a shop last night and got them crimped. Bolted them on late last night. Put some fluid in and we have a pedal. Still need to properly bleed. Probably the first time in 25 years the truck had working brakes.
Old 11-06-2018, 07:59 PM   #118
joedoh
joedoh's Avatar
working brakes are a good thing! great progress!
Old 11-07-2018, 12:20 AM   #119
mikebte
Very nice, hope you make it down to Tucson in that rig. I would love to have a look once it's running.
Old 11-07-2018, 06:41 PM   #120
28TudorAZ
28TudorAZ's Avatar
Ok picked this up at a junkyard. I think I need another inch. Any thoughts? The yoke seems pretty short.
Old 11-07-2018, 09:33 PM   #121
joedoh
joedoh's Avatar
is the truck on the ground? the way the leafs lean forward on an s10 means the driveshaft will move into the trans when you lower it.
if the truck is on the ground, I would say you need a little more. I have had good luck with reg cab shortbed driveshafts, I think they are around 53", I used a trailblazer shaft on one and it was just a hair too short, I think it was 51.5"
Old 11-07-2018, 09:48 PM   #122
mikebte
Agreed, I spent some time at the junk yard but finally found a 53” for mine. It was out of a 2wd blazer and worked great. Blazers have verying lengths as well as the trailblazer.
Old 11-07-2018, 10:28 PM   #123
28TudorAZ
28TudorAZ's Avatar
It's on the ground. Its from a short bed s10. I guess I need 54.
Old 11-07-2018, 11:09 PM   #124
joedoh
joedoh's Avatar
well thats terrible, especially since my advice to use a rcsb driveshaft led you there.
but I think your tall valve cover is the culprit. I tuck my motor way back against the firewall as far as it can go, but I use the stock (low) valve cover. with a tall valve cover, the motor cant go back as far.
Old 11-08-2018, 12:55 AM   #125
28TudorAZ
28TudorAZ's Avatar
I measured it before I left and it was around 53". I didn't change out the yoke. Maybe its different. Oh well $110 to have someone shorten the old one and its aluminum. It doesn't have tall valve covers. Possibly my cab placement was 1/2 inch difference and then then my motor placement was 1/2 inch difference that would make up the extra inch.
