09-06-2018, 02:46 PM | #276 | |
Re: Two is easier then one 1965 GMC S/W/BB build
10-02-2018, 03:13 PM | #277 |
To be current and up to date.
more coming |
10-02-2018, 03:16 PM | #278 |
as of this morning, you are now up to date |
10-02-2018, 03:26 PM | #279 |
Very nice. I like those front inners. Looking good
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
10-03-2018, 09:54 AM | #280 |
A video of our shop/ tools and even some Big Block Chevy accessories we are selling off.
Walking through our shop. |
10-03-2018, 11:04 AM | #281 |
That is nice. Cool tools. Is this your main occupation?
10-03-2018, 11:48 AM | #282 |
10-09-2018, 08:59 PM | #283 |
Are we the first to use the rear wheel tubs to build front ones?
10-10-2018, 09:37 AM | #284 |
It's the first time I've seen it
10-10-2018, 10:20 AM | #285 |
10-16-2018, 07:56 AM | #286 | |
I'm just glad to be here!
I'll say yours are the first I have seen since I did mine...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
10-17-2018, 10:25 AM | #287 |
A little further along.
10-17-2018, 10:27 AM | #288 |
Forward inner wings are fabbed and ready to weld in. We are starting the inner panels as well.
10-17-2018, 10:28 AM | #289 |
10-17-2018, 12:01 PM | #290 |
Unfortunately no. I had a computer crash and lost a ton of build pics of that truck...
I will say, yours are a ton more involved and should look a whole lot better than what I had. Mine were functional, but lacked the look I was hoping for...
10-17-2018, 03:32 PM | #291 |
Lot of work in fabrication
10-27-2018, 08:41 AM | #292 |
Love this thread.
10-27-2018, 08:42 AM | #293 |
Your build is what got me to join this forum! Can’t wait for the next installment of photos and updates. Amazing skills fabricating metal is something I wish I had learned when I was younger.
I enjoy following yours. |
10-29-2018, 10:36 AM | #294 | |
Dang nice of you to say. Greg and I have made a lot of progress on finishing off the front clip and should be moving on to building the new core support and mount the large aluminum cross flow radiator Greg purchased. |
11-08-2018, 07:59 PM | #295 |
Building the sheet metal for the engine compartment is challenging. The plan is to make it look like it was a factory creation. Lots of intricate multi compound curves and planes all forming what the factory could have done with a large stamping press. Lay out is time consuming.
We use a construction laser to project the finish point of one parts plane onto the curved part it will be married to. |
11-18-2018, 07:52 PM | #296 |
Fab work is looking great. The engine bay is more wide open now. It's hard to tell from the pictures, but is there enough room for full turning radius through the full suspension cycle? I didn't catch it if you already mentioned it.
11-19-2018, 02:45 PM | #297 | |
Yes we tested full lock clearance. We removed the shock, removed the spring and remounted it, then we disconnected the sway bar. Mounted the tire and raised the lower control arm with a floor jack until it hit the limiter (This shock has a built in bump stop.) Once we had the wheel at full compression we swung it through its arc and had a full hand of clearance everywhere. |
11-23-2018, 02:10 PM | #298 |
Really good stuff you two!! Eagerly awaiting more updates.
01-09-2019, 01:34 PM | #299 |
A little video to update where we are as of this morning. We got kind of held up over the holiday.
https://www.youtube.com/watch?v=yJqe0s5AKZs |
01-15-2019, 05:53 PM | #300 | |
that truck is wild man, couple questions for you.... where did you get those red truck covers? what hinges do you plan on using for the hood? fantastic build tho, the title of this build is "two is easier than one" still panning on building the other too? |
