11-12-2018, 01:59 AM | #2301 |
Re: What did you do with your truck today, Part 3
Since all my wiring worked perfectly, I began the task of bundling it up and securing it. First step was mounting my dimmer switch to the floor, then enclosing exposed wires in split tubing.
For securing the wires I found these awesome little self-mounting zip ties. They are like a conventional zip tie but with a snap-fit mount at the base that plugs into a 1/4" hole - no clamp, screw or bolt required.
1951 Chevy Panel Truck |
11-12-2018, 02:53 AM | #2302 | |
My big thing is the rust, I am going to spend some time with it and see. The front panel, pretty sure I am going to by a new one. Then I have to see about that tail gate, I did it nice 35 years ago but it has cracked some, we will see. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
11-12-2018, 03:43 AM | #2303 |
...but if you see them every day with their clothes off you start to take them for granted... NOT!
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
11-13-2018, 12:22 AM | #2304 |
I got the rest of the parking brake parts sandblasted, along with all four lower fender braces and will get them primed over the next few days.
I can't believe all the sand I wasted up until a few weeks ago when I started re-using it. I do all the blasting over a concrete area behind the garage, use something to block it, in this case an inner fender. I sweep it up, filter it through a screen clamped to the bucket with vice grips and wham, I am using it over and over and over! Brian
11-13-2018, 11:20 AM | #2305 |
Today is still young but yesterday, hauled ~1,000 lbs of gravel up to the retaining wall I'm back filling. It creaks and pops a little under the load but goes, stops and steers just fine.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
11-13-2018, 11:43 PM | #2306 |
At the muffler shop today, I got a complete exhaust system installed but I'm not happy with it. They installed the pipes much too high, running them too close to fuel and brake lines, wiring and the floors. Looks like I'm going to have to have a confrontation with them tomorrow. On the bright side, it sounds killer! But now I can hear all the other rattles!
Then when I got home my door bumpers were waiting in the mail. $3.99 from Jegs Ebay store with free shipping - what a deal! It took a few minutes to install them, cause I had to remove my striker plates, then reinstall and readjust.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 11-14-2018 at 01:39 PM. |
11-13-2018, 11:54 PM | #2307 |
Is that the truck in your Over My Head build thread?
11-14-2018, 12:08 AM | #2308 |
One of these days I'll figure how to post pics. Got the front end off the truck today. Ready to lift the cap off tomorrow. Found out that the front suspension has been messed with. The cross beam is not straight to the frame and one side is missing two leafs of the spring combination.
11-14-2018, 02:40 AM | #2309 |
Got all the parking brake stuff ready to prime tomorrow morning.
Brian
11-14-2018, 06:09 AM | #2310 |
I'm continuing to work on wiring, probably for about 3 hours a day on average. I've started by building up my relay panel on the bench because I don't want to be soldering under the dash any more than I have to
The American Autowire "Highway 22" kit is great, but I'm on my own lot of times because my circuits are not on their page. I've got 11 relays that they don't know about, for instance, but I wouldn't have it any other way. Now if I could actually settle on the wire colors BEFORE I pick up the soldering iron...
11-14-2018, 09:58 PM | #2311 | |
11-14-2018, 10:43 PM | #2312 |
11-15-2018, 12:25 AM | #2313 |
You guys are bruthas from different muthas!
I got my five minutes in today before 7:30 AM. Got out to the garage and primed my parking brake linkage and a seat I repaired for my son. I left it with heat lamps on it and came home at lunch to put them out in the sun. Brian
11-15-2018, 08:58 PM | #2314 |
11-15-2018, 09:41 PM | #2315 | |
11-15-2018, 10:13 PM | #2316 | |
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) Last edited by DransportGarage; 11-15-2018 at 10:18 PM. |
11-15-2018, 10:39 PM | #2317 | |
11-15-2018, 11:19 PM | #2318 | |
https://www.youtube.com/watch?v=faLn-SjVfwY He preferred crimps, but he was also selling high-dollar crimpers, so I dunno. I think it's all in the tooling, or, as you said, in the soldering methods. I also know there are a lot of solder flow circuit boards out there that work well in the 12 volt range and below. There is a also lot to be said for hi-tech crimping with great tooling, but most of us don't have that around the house. Here's another video where the guy has tried both, likes soldering because of the way it looks, but says he's seen more fails with crimps. https://www.youtube.com/watch?v=H0i3CAELaC8&t=190s Note that butt crimps were used, and neanderthal pliers. Sooo... IMHO, good practices make the difference, regardless of which way you go.
11-15-2018, 11:59 PM | #2319 |
Got out there and boxed up the parking brake parts for storage until assembly. Pulled apart the brake linkage bracket and pedal parts, think I am going to have them powder coated. But if I need something to do I will sand blast and epoxy prime pieces too to get something done.
Brian
11-16-2018, 10:45 AM | #2320 | |
As for the solder vs crimp, I have found many problems with crimped connections, and can't remember any with soldered connections. |
11-16-2018, 11:33 AM | #2321 |
As I said in post #2318, "IMHO, good practices make the difference, regardless of which way you go." My problem is, I don't have the high-dollar crimpers to do a good job. I have those one-size-fits-all "neanderthal crimpers".
11-16-2018, 11:44 AM | #2322 | |
https://www.harborfreight.com/9-1-2-...ool-36411.html |
11-16-2018, 06:54 PM | #2323 |
Get these, best money I've spent.amazon.$40.00
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
11-16-2018, 07:55 PM | #2324 |
Installed my AC vents. Ran my Ebrake release threw it on the driver's vent.
11-16-2018, 09:15 PM | #2325 |
It's great to see those little widgets appear on your ride as you work on it, isn't it?
