Can anyone tell me what this is ?
My buddy is redoing a '72 1/2 ton stepside. This bracket was left in the parts bin.
It looks like it "might" be for the emergency brake cable but hes not sure and neither am I. Can anyone ID this thing ? Thanks !!!! |
laying low
![]() Join Date: Mar 2001
Re: Can anyone tell me what this is ?
Front fender lower rear mounting bracket.
Old member
I was thinking it's the power assist bracket for the ram arm.
I know the fender washers I remember had no little bolts to them just the big washer and single bolt. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I called my buddy and told him about the fender bracket and he said thats not it. As far as something for the power steering, I'll ask him about that later tonight. Where would it go if it was for the ram arm ?
Old member
Under the frame for the ram arm rod to attach to the drivers side frame. If that is what it is. This is just my guess. It looks like the one off my 64 SS Impala.
I'm with Boog. The lower fender support brackets on my 72 look exactly like that. Bolts and all.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Yes it's the fender bracket
Old member
Looking at that picture I would say that's what it is. I have never taken one off myself so I assume that's what it is.
Just so you guys know, my buddy has owned this truck for close to 30 years. He repainted it himself back in the day. This time he did a body off. Trucks painted, drivetrains in. Hes just finishing up the small things. This bracket was in one of the rubbermaid tubs. He thought it was part of the steering column but so far he cant figure out where it goes. Nothing lines up with the bolt holes.
I think I know how the fender brackets look. They go on the front pillars. His are already on. This has to be something really simple. |
![]() Join Date: May 2007
It is a reinforcement for the lower fender mount. Absolutely, positively, for sure.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
![]() Join Date: Oct 2009
No it isn't!
#15 |
#16 |
![]() Join Date: Jul 2015
#17 |
#18 |
#19 |
Roadtrip!
![]() Join Date: Feb 2003
I will agree with this.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#20 |
Thanks for all the replies guys. I sent him a text a few minutes ago telling him what you all think it is. I know he got a couple of rust free OEM fenders from a guy he knows. Im thinking maybe one of those fenders came with a bracket and he used it instead of the one from his truck.
Im sure I'll hear from him tomorrow morning. Thanks again ! |
#21 |
If he replaced the sheet metal in that area, like rocker that has the front and rear door jams, the lower fender mount bracket may have been built-in to those replacement parts. Mine were. My question is...do I need to put the mounting brackets on in conjunction with the "built-in" tabs??? I don't think I do as the fit is good and it feels real sturdy.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
#22 | |
That was pretty good! |
#23 |
The rocker panel I attached was a quick pic grab from the net...it's supposed to be
Dynacorn 1104D Rocker Panel that was being advertised on ebay. It was just similar to the one I used on my truck with the mounting hole built-in, if that is really how it's supposed to be used. My question still stands...should the mount brackets be added to the forward ear of my patch panel? Glad you liked the sig ( I borrowed it from another car site ).
