Old 11-22-2018, 12:17 PM   #1
Chilly178
Chilly178's Avatar
72 C20 front end rebuild kit.
Hello, i'm looking to rebuild the front end of my C20. I want all quality parts. I also want everything to rebuild it. I found this kit from earlyclassic.com https://www.earlyclassic.com/node/1187 It doesn't specify if it's for a C10 or C20. Does it matter? Can anyone tell me for sure if this kit is what i'm looking for? I would buy the parts individually but I don't want to miss anything.
Chilly178 is offline   Reply With Quote
Old 11-22-2018, 01:09 PM   #2
68 P.O.S.
Re: 72 C20 front end rebuild kit.
I've used the kit for power steering. It's top notch, I recommend it. You're right, website doesn't show the option. You'll have to call them to be sure.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 11-22-2018, 01:18 PM   #3
notsolo
notsolo's Avatar
Ball joints and tie rods ends are heavier for c20...Maybe Rockauto, compare C10 and C20.
notsolo is offline   Reply With Quote
Old 11-22-2018, 01:47 PM   #4
NorCalC20LWB
I had my 72 C20 rebuilt a few months ago by a reputable shop here in Sacramento. Here the parts list, all Moog I believe:
NorCalC20LWB is offline   Reply With Quote
Old 11-22-2018, 03:39 PM   #5
toolboxchev
In process as we speak of installing a complete front end component from Jegs. All Moog stuff, All price matched, All USA manufacture and complete matching parts.
I could not be happier with the service from Jegs, just specify all components must have matching manufacturing batch numbers. They will tell you they cannot do that but will try.
They did. DONE!
toolboxchev is offline   Reply With Quote
Old 11-22-2018, 04:04 PM   #6
jocko
jocko's Avatar
I could not be happier with the service from Jegs, just specify all components must have matching manufacturing batch numbers. They will tell you they cannot do that but will try. They did. DONE!
Agree, Jegs is good. Why do you request that the parts have matching batch numbers? - if it's Moog, it should be good quality batch to batch. And, if there could be a quality difference from batch to batch - the only thing specifying that all be the same batch does is to ensure that your parts are either all good -or- all bad, but you won't know, just like you wouldn't know if they weren't all matching. Not trackin why you'd ask for that, so wanted to ask - there may be a very good reason! Thanks.
Old 11-22-2018, 11:02 PM   #7
MONTE
MONTE's Avatar
I just did my c20 a few months ago. Best price I got was amazon. All moog parts, just can’t remember the exact price.
MONTE is offline   Reply With Quote
Old 11-26-2018, 10:05 PM   #8
Chilly178
Chilly178's Avatar
Got a parts list?
Old 11-27-2018, 03:17 PM   #9
68 P.O.S.
Originally Posted by Chilly178 View Post
Got a parts list?
Inner and outer tie rod ends, tie rod adjusting sleeves, upper and lower ball joints, upper and lower control arm shafts, idler arm, and pitman arm. The kit ECE sells is perfect and it's all quality Moog parts. Give 'em a call, or some simple net research like Rock Auto will get you the part numbers.
Also, while you're there, upgrade to the 9/16" lower control arm u-bolts. ECE sells 'em as well, or Dorman 13503 at most part stores. The stock ones were 7/16", and later ones were 1/2"; both had a penchant for snapping when in reverse and having the wheel cranked all the way in either direction. You may have to enlarge the holes a little with a 9/16" bit to install them.
Old 11-27-2018, 08:31 PM   #10
Chilly178
Chilly178's Avatar
Thank you this is good information. The kit I linked in the first post from classic enterprises is for a C10 if anyone cares.
Old 11-27-2018, 10:53 PM   #11
PepperTreeGarage
PepperTreeGarage's Avatar
I used the Doorman 9/16 u-bolts when I rebuilt my '72 C20 Custom Camper. I was also pleasantly surprised to find out that it had 9/16 u-bolts from the factory, so no drilling required. Good luck on your build.
PepperTreeGarage is offline   Reply With Quote
