Old 11-30-2018, 06:33 PM   #1
macdodd127
shorty spark plug
I want to replace my spark plugs,,,I have a SB 350. I running headers on the block,,,any suggestions as to what might be a good plug?
macdodd127 is offline   Reply With Quote
Old 12-01-2018, 11:51 AM   #2
davepl
davepl's Avatar
Re: shorty spark plug
I had a box of shorty header plugs and they were NOT that much shorter. The only thing that worked for me was ceramic boots. One had to be custom ground to clear the header, but that's the ONLY way I was able to stop burning through boots, etc.
Otherwise, Accel makes them if you want to try them. Aka "truck" plugs for some reason, they're yellow and a few mm shorter.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-01-2018, 12:44 PM   #3
geezer#99
geezer#99's Avatar
Thread on shorty plugs.
http://67-72chevytrucks.com/vboard/s...Bspark%2Bplugs
Old 12-01-2018, 01:16 PM   #4
davepl
davepl's Avatar
Punchline: the shortest plug in that thread is the Accel I referred to. I didn't even know about the intermediate ones!
Old 12-01-2018, 05:33 PM   #5
OregonNed
OregonNed's Avatar
Accels work great for me.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 12-01-2018, 08:05 PM   #6
jradford
I had the same problem when installing headers on my sb 350. Bought a set of high temp braided boots and slipped them over the plug boots. No more problems. They are rated to 1200 deg. Summit and several other manufacturers sell them. Work great.
jradford is offline   Reply With Quote
Old 12-02-2018, 03:36 PM   #7
macdodd127
Ok,,,,got a set of accel shorts, whats the best gap for them when running headers?
Old 12-03-2018, 12:38 AM   #8
jradford
Depends on your ignition. Are you running an HEI or the original distributor? I wouldn't think plug gap would change from standard to shorty plugs. Iridium plugs come pre-gapped and should not be regapped.
Old 12-03-2018, 08:26 AM   #9
macdodd127
I'm running HEI with headers,,,stock 350 SB.
Old 12-03-2018, 11:47 AM   #10
OregonNed
OregonNed's Avatar
.045 seems to be the consensus on other gap threads for HEI
Old 12-03-2018, 12:42 PM   #11
macdodd127
I checked with my mechanic,,,,he said 35 to 40 would be fine. They were set at about 36, installed them,,,,runs great.
Old 12-03-2018, 01:03 PM   #12
jradford
I run .045 with an HEI on a 72 350. Runs great. .045 is pretty much standard for the HEI converted 350 from what I hear. It would probably run with .035-.040 if that's what you want to run. Try it both ways and see how it runs and what it does to your mileage.
Old 12-03-2018, 01:04 PM   #13
68 P.O.S.
Stock points is 0.035, HEI is 0.045
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 12-03-2018, 02:44 PM   #14
gearheadperkins
gearheadperkins's Avatar
Accel here .. works great for me..
1972 Chevy C10 400sbc 4sp
Matthew 4:19
And he saith unto them, Follow me, and I will make you fishers of men.
gearheadperkins is offline   Reply With Quote
Old 12-03-2018, 04:13 PM   #15
macdodd127
So far , so good, plugs set around 36/38. Four barrel kicks in great,,,smooth.
