12-06-2018, 07:34 PM | #1 |
Pulling a TH350
I apologize if this has been covered but I did a few searches and didn’t find any definitive answers to some of my questions.
I have a 72 with a 350/350 combo witch in its present form runs and drives just fine. The problem I have is that the transmission is an oily greasy mess that seems to be leaking from everywhere. I read the other recent thread on the guy that is tacking leaks on his and it was suggested by some to just pull it and clean it up out of the truck. This is the route I think I’m going to take. I’m also thinking while it’s out I may as well rebuild it then I know what I have? So my question is. Is it a simple enough process to pull the transmission and leave the engine in place? I see no reason to pull the engine as well. Are there any special steps that I need to take? I didn’t really find a step by step process but perhaps most guys pull the whole lot engine included. Im assuming the engine will need supported somehow also? Or will it be simpler to let the transmission shop pull it if I rebuild it? I’m sure I’m capable of doing it I’ve pulled a ton of semi transmissions and installed clutches etc. I’m just lacking a few of the finer points on the smaller stuff. And secondly if I was to overhaul the transmission are there any things that I should do or ask for? Upgrades make it stronger etc etc Thanks |
12-06-2018, 08:07 PM | #2 |
Re: Pulling a TH350
First things first - 4WD or 2WD? 2WD is relatively easy. Remove the u-joint, pull the driveshaft (have a drain pan under the transmission tail shaft). I like to use 3-inch bolts as guides to remove and install the transmission. I cut the heads off and cut a slot in the end so I can remove them with a screwdriver. One on each side will do. Remove the torque converter bolts. Place a jack under the transmission with a block of wood to protect the pan. Remove crossmember bolts and drop the crossmember out of the way. Now you can slide the transmission out. The engine should be fine sitting on the motor mounts.
If we're talking 4WD, you're going to have to remove the transfer case - they're very heavy and awkward. I would definitely recommend a transmission jack if you're dealing with a transfer case.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-06-2018, 09:15 PM | #3 |
Moderator
Re: Pulling a TH350
To add content to the response from truckster....
Disconnect battery first Remove distributor cap and rotor button You will break both if the engine mounts are not perfect...) Jack up the truck so the bottom of the chassis rails is at least 14" off the ground, support with four car stands on the chassis Remove the trans pan and drain the fluid Remove the rear uni bolts and remove the driveshaft Remove the shift linkage rod from the shift lever on the trans Remove the flywheel convertor cover Remove the bolts securing the convertor to the flexplate and push the convertor back...wire the convertor back against the case with tie wire... Remove the passenger side upper trans case to engine bolt and remove the filler tube and dipstick Jack the trans up slightly and remove the trans mount to cross member bolts Remove the cross member Lower the trans support jack approx 4 inches (keep jack under trans!) and remove the cooler lines from the trans....plus the ends with plastic caps Remove the vacuum modulator pipe at rear of trans Remove speedo cable Remove lowest bolts from each side between engine and trans ad install studs as "truckster" indicated... Remove the remainder of the bolts between trans and engine.... Lower trans a little and slide the trans back to clear the ends of the studs... Lower the trans and slide out from under truck... The only reason you would want to do all this is if the trans is malfunctioning or the convertor pump seal is leaking...if the pump seal is leaking, IMO, it should get an overhaul while its out... You can pressure wash the trans fro the top and under the truck and replace most gaskets and seals without the need to R&R so long as the pump seal is not leaking... Hope this helps... "truckster" great response...just felt the need for more content and some safety suggestions etc...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox Last edited by AussieinNC; 12-06-2018 at 09:50 PM. |
12-06-2018, 09:39 PM | #4 |
Re: Pulling a TH350
Thanks. I guess I've done it enough times that I wasn't thinking in enough detail. Your response is spot-on.
12-06-2018, 09:46 PM | #5 |
Re: Pulling a TH350
Good info, I’ll be pulling my turbo 350 to swap a 2004r
12-06-2018, 09:47 PM | #6 | |
Moderator
Re: Pulling a TH350
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
12-06-2018, 09:49 PM | #7 |
Moderator
Re: Pulling a TH350
Make sure that 200R4 has been beefed up...and is setup correctly....then add am isolated cooler system for the trans...
12-06-2018, 09:59 PM | #8 |
Re: Pulling a TH350
Sorry forgot to add yes a 2wd
Great informative replies so far thanks guys that’s exactly the sort of info I’m after |
12-06-2018, 10:08 PM | #9 |
Re: Pulling a TH350
If it’s “leaking from everywhere” I’d first inspect the vent to see if it’s plugged before pulling the trans out.
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
12-07-2018, 03:29 PM | #10 | |
Re: Pulling a TH350
Trying to picture pressure washing the trans from above or below though. Better be wearing a head to toe plastic suit. Haha |
12-07-2018, 08:49 PM | #11 | |
Moderator
Re: Pulling a TH350
Couple cans of engine degreaser spray and a pressure washer that has a soap injector on it.... Yep its messy, but its fun !!!!!!
