11-20-2018, 07:07 PM | #101 |
Re: What did you do to your truck today.The 3rd chapter
67 short beds , I have a few to build , lt Green 292/3 speed hurst floor shift / 3.73 posi / 2-4 drop / buckets/ consol /air /ps/pb, Yellow 350 4 speed rock crusher floor shift hurst ps/pb/air/ 3-5 drop / 3.73 posi/ , Black ,red interior 292 tri power 4 speed floor shift/ consol /3.73 posi / ps/pb/air/ Not sure on the rest of them yet color wise .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
11-27-2018, 06:21 PM | #102 |
I drove it to work, then the gas station, then home. It's pulling daily driver duty this week while the new Ram is at the body shop.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
11-29-2018, 07:59 PM | #103 |
Got the passenger wires loomed up and length-calibrated for the headers!
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
11-29-2018, 08:41 PM | #104 |
What kind of looms are those?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
11-29-2018, 11:02 PM | #105 |
Working on filler panels!
11-30-2018, 02:59 PM | #106 |
Good question...They came with the truck and have no markings other than a chevy emblem. They are quality though as the parts that hold the wires are all metal and they slide together nice and tight. No brittle plastic here!
These are the type that bolt to lower BBC valve cover and hold the wires just above the headers. -klb
11-30-2018, 03:10 PM | #107 | |
11-30-2018, 03:16 PM | #108 |
Found what I have... They are not cheap but... they are quality like I said...
Proform 141-638 Linear Spark Plug Wire Loom https://www.amazon.com/Proform-141-6.../dp/B000CMH2GG -klb
11-30-2018, 03:22 PM | #109 |
The loom back on the truck...
11-30-2018, 03:26 PM | #110 | |
11-30-2018, 07:39 PM | #111 |
Drove it 91 mile round trip to get a new washer and dryer. (there goes my truck budget)
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
11-30-2018, 07:51 PM | #112 |
Happens to me all the time. Just when I get some $ put away for my truck, it just seems to disappear
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
11-30-2018, 10:28 PM | #113 |
Moderator
Put a chrome bumper and guards on my
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
11-30-2018, 11:14 PM | #114 |
Junior Member
12-01-2018, 09:53 AM | #115 |
Went to start mine for the first time in about 6 weeks. I had to make some repairs to the electrical in that time as the external regulator harness was chaffed so I installed the solid state regulator and a new pigtail. Fixed the tail light wiring and painted the inside of the housings gloss white for some better light reflection and new lenses. Perfect let's start it...NOPE! Heavy fuel smell, leaking from a crap connection where PO had cut hard line at the pump and put in a piece of rubber hose to connect the two. OK got that done and new line ordered. Get home from work the next day to a puddle of fuel on the driveway from under the cab. Truck had two saddle tanks back in the day and removed before I got it. But the hard lines from them to the selector valve were still in it with the valve. In-cab tank was plumbed to the valve still and the rubber line from the tank to the selector valve hard line was rotted and leaking. Ripped it all out in 30 minutes and installed a new line with a metal canister filter between the tank and the hard line inside the frame. Just in time for a torrential downpour and two more days of work with rain...I just want to start it now and make sure I have all the fuel line good.
Of course rain still pervades here in NorCal (we need it bad though) and I discovered this truck had 5/16" fuel lines for the 350 from the factory so new hard lines and sender ordered to replace the old ones and hopefully prevent any starvation (has Edelbrock carb/intake on it). I'm going out on limb though and guessing the fuel pump will need replacing (Merry Christmas to me) since that's my luck. If I don't get it running as is, it will remain a driveway queen until after Christmas. I feel mission creep coming on as the radiator and heater core are also suspect, those hoses look really shady right now and it's pouring outside once again.
1971 Custom/10 - 350/3 speed, Orange/White roof |
12-07-2018, 08:14 PM | #116 |
The painter sat on these a while, but some things are worth the wait.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-07-2018 at 08:26 PM. |
12-07-2018, 08:26 PM | #117 |
Why didn't he fix that dent ?
12-07-2018, 08:28 PM | #118 |
Just kidding
They look great !
12-07-2018, 11:57 PM | #119 |
........Cuz there's another just like it on the other side?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
12-08-2018, 12:35 AM | #120 |
Installed this beauty today. It’s a shame if not really visible when the truck is all assembled.
12-09-2018, 02:27 PM | #121 |
Well yesterday actually, I ran up to Cooper Restorations and picked up a few odds and ends for my 68. So I guess you could say I did something "for" my truck instead of "to" it. LOL Here's a link to Jeffs web site hes a good guy to do business with.
https://www.cooperrestorations.com/
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
12-09-2018, 03:44 PM | #122 |
12-09-2018, 03:44 PM | #123 |
Nice bro
12-09-2018, 03:47 PM | #124 |
Ouch
12-09-2018, 10:26 PM | #125 |
Who Changed This?
Drove it over to the "local" pick-your-part to see if I could find a replacement seat. No joy. The wife wanted to know why I don't just put it back to stock looking. $97 for a decent replacement, or $900 for the factory look, plus my labor. She understands that sort of economic decision!
