Old 11-23-2018, 01:35 PM   #1
Toro
Toro's Avatar
SWB truck bed steel in a Blazer
The wheelwells and bed floor are pretty rough in my '72 Blazer. Has anyone ever used the bed from a SWB? I know there would be some mods for the gas filler and seat mounts, but otherwise would it work?
Toro is offline   Reply With Quote
Old 11-27-2018, 07:54 PM   #2
69-72
69-72's Avatar
Re: SWB truck bed steel in a Blazer
SWB Will not swap over. It will need to be shortened at the front and a donor front piece from a Blazer floor would need to be welded on.
I did this with a LWB bed floor. I took a section out behind the wheel wells to make it the right length and shortened the front and added the front piece on.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 11-27-2018, 08:03 PM   #3
psuedopimp
psuedopimp's Avatar
Mine was toast from the rear of the wheel wells. I used a long bed and shortened it.
psuedopimp is offline   Reply With Quote
Old 11-28-2018, 01:39 PM   #4
Toro
Toro's Avatar
How exactly did you go about changing it? Did you have to take the body off the frame, or were you able to cut out the pieces and put the new ones in? My front piece is good almost to the wheel wells. Are either of you using the rear seat? Did you transfer the mounting pieces over to the new bed?
thanks
Jon
Old 11-28-2018, 02:21 PM   #5
69-72
69-72's Avatar
You pretty much need to take the bedsides off and remove the bed floor to do it. Some of the cross members are interchangeable. The rear seat seatbelt mounting plate that’s under neath can transfer over if it’s still in decent condition. Once you start taking things apart you find lots of other rust to fix. It depends how much you want to get into it and what the end goal is with the truck
Old 11-28-2018, 03:07 PM   #6
Toro
Toro's Avatar
I’m ok and prefer to do it the best I can. I didn’t realize you could take it apart that far with the body still on. How hard is it to remove the bedsides? I’m sure there are other threads about it. I don’t have the space to take off the whole body, which is why I wanted to know how to change things out if possible. How many sets of body mounts go through the bed floor? I want to change the body mounts so this might be something to do at the same time.
Old 11-28-2018, 03:19 PM   #7
DaHos
DaHos's Avatar
FYI: Blazer specific cargo floor is available.....
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 12-08-2018, 10:15 AM   #8
psuedopimp
psuedopimp's Avatar
The blazer specific bed is a great option but I couldn’t afford that so I found another way.
I cut the bed in the blazer where the floor began to be solid. It may not be the best method, but I removed the bed while still on the frame and with the bedsides attached. It wasn’t very easy. I then laid the old bed next to the new (old trash trailer I found for cheap with solid floor). I had to transfer bed supports and shorten the new bed accordingly. It will make sense when they lay next to each other. Then I squeezed it back in with the bed sides on. Again probably not the easiest way
Old 12-08-2018, 10:44 PM   #9
Toro
Toro's Avatar
Did you cut straight across, left to right? I'm looking to do the same with mine, I don't want to take the bed sides off. I'm thinking an additional cut, back to front would make it easier to get the floor out/in under the bed sides. I'll basically be patching around the good steel I have.
Old 12-08-2018, 10:59 PM   #10
psuedopimp
psuedopimp's Avatar
Here are a few pics I found from when I did it
Justin
1970 Blazer in progress
Old 12-09-2018, 05:52 AM   #11
GMCPaul
It can be done on the Blazer and before the Blazer cargo floor became available it used to be the only option. But honestly it's easier to remove cargo floor and do the work, you need to reuse your rear Blazer bed support it's very different from the truck though some have reworked truck rear bed supports to work. It's really rather basic to do as it just needs cut to proper length and then bed rear support moved over to new floor and modify truck intermediate bed supports as needed or swap over intermediate supports from original Blazer floor.
If you remove all bed floor mounts and remove bed side bolts then cut welds at rear support the bed sides can be spread out and raised and the floor can be removed. It is easier over all and faster doing it this way in my opinion.
Paul Sr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 12-09-2018, 11:58 PM   #12
Toro
Toro's Avatar
Paul,
Do you have any photos of the "welds at rear support" you mentioned needed to be cut? I'm trying to visualize the area you're referring to.
Old 12-10-2018, 12:46 AM   #13
GMC-YA68
GMC-YA68's Avatar
Nicely done my friend!
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
