Old 12-25-2018, 09:34 PM   #1
Brettburwell
Brettburwell's Avatar
Talking 1971 chevy c10 restoration
Hey there this will be my first restoration of a vehicle and am pretty new to this other then im a welder by trade but the story goes my father bought this old c10 30 years ago for $50 bucks and since sat in a barn for 30 years during that time it has seen neglect and alot of animal damage until now as seen in pictures this will be a well documented post any input on the build would be very appreciated
So far the plan is to make a fleet side short bed and replace the 6 cylinder 3 on the tree with a 350 motor and 4 speed tranny
Brettburwell is offline   Reply With Quote
Old 12-25-2018, 09:42 PM   #2
zicc1835
zicc1835's Avatar
Re: 1971 chevy c10 restoration
welcome... looks like your work is cut out for you.. good luck ill be looking in
zicc1835 is offline   Reply With Quote
Old 12-25-2018, 10:41 PM   #3
Brettburwell
So i have been at this project for a while just posting pictures of progress
Old 12-26-2018, 01:43 AM   #4
Andyking1203
Looks like a decent start... good luck!!!
Andyking1203 is offline   Reply With Quote
Old 12-26-2018, 08:42 AM   #5
boynton
boynton's Avatar
Welcome. My advice, read a good while before you begin something you are unfamiliar with. There is a ton of great info on the forum. Btw your steering wheel looks great as it appears to not have any cracks. You seem to have a good plan just slow and steady. I’d add power steering and power brakes to your list of upgrades. I look forward to your progress.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 12-26-2018, 08:53 AM   #6
Brettburwell
So i built this cab cart out of some angle iron i had laying around the plan is to remove the entire floor and replace it with a one piece floor with all of the cab supports and braces . A braced my cab like this i may add additional braces but we will see yet
Old 12-26-2018, 09:54 AM   #7
boynton
boynton's Avatar
When my buddy and I did mine we braved the door openings utilizing the door hinge bolts and the door latch bolts in a Y brace and then did an X inside the cab. . It worked out well. That way we had enough room to work on the floor as we replaced the complete pan as well. I wish I had some good pictures so I could share them.
1970 SWB Step-Side
Old 12-26-2018, 10:32 AM   #8
Brettburwell
So i cut the floor out a couple days ago and got the new one in i get what you mean by bracing inbetween the hinge blocks i have had the doors on and off a couple times now just to be sure nothing moved or twisted all seems well so fingers crossed i still have lots of cab work to do cab corners outer rockers and both a and b pillers complete floor seemed quite simple to install and remove and seemed like a better option then pieceing in patch pannels
Old 12-26-2018, 02:52 PM   #9
boynton
boynton's Avatar
Nice work. The complete floor was one of the best things I did to my truck. It turned out so much better than the patch jobs we have done on other trucks. Looking good!
1970 SWB Step-Side
Old 12-26-2018, 04:35 PM   #10
Snake72
Snake72's Avatar
I did a complete floor as well, very happy I did. Piece fits well too. I then sprayed the top and bottom of the floor with Upol raptor liner to weather/water proof the new metal
Snake72 is offline   Reply With Quote
Old 12-26-2018, 04:37 PM   #11
Brettburwell
so today i put my doors back on my cab as well as both fenders to check alignment since floor replacement all seems well still have to dial doors in perfectly but still have adjustment to dial it in.
Old 12-26-2018, 04:54 PM   #12
Brettburwell
Here is a picture of my short bed fleet side box i bought they sure are getting hard to find these and sure arnt cheap
Old 12-26-2018, 07:54 PM   #13
72 tigger
72 tigger's Avatar
looks like you’re doing it right!
72 tigger is offline   Reply With Quote
Old 12-27-2018, 01:28 PM   #14
Brettburwell
Getting ahead of my self here but has anyone found a cheaper foam for a bench seat foam lmc has a set for 349 us dollars and shipping and duty as well as exchange rate for canada will cost a small fortune and my local auto parts store is pricy as well
Old 12-27-2018, 01:34 PM   #15
Brettburwell
Just did a quick rough check on doors and fender alignment all seems well other then lower fender mount holes are about a 1/4 inch low but nothing my die grinder wont fix
Old 12-27-2018, 05:54 PM   #16
Andyking1203
Nice looking starting point and work so far.. I replaced the entire floor as well, much easier I think... keep the good work up..
Old 03-28-2019, 04:44 PM   #17
Brettburwell
little more work done replaced cab corners and A and B pillers working on the rockers as of right now
Old 03-29-2019, 05:37 PM   #18
knomadd
knomadd's Avatar
Looks like you're well on your way to getting the tin worms under control. Nice work!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-30-2019, 07:49 AM   #19
Brettburwell
Just finished up the rockers both were a pain to fit im not to impressed with them but either way there in
Old 03-30-2019, 10:13 AM   #20
70 cst
70 cst's Avatar
Looking forward to seeing your progress. Great job so far!
70 cst is offline   Reply With Quote
Old 03-30-2019, 05:29 PM   #21
Brettburwell
cab is getting closer to being rust free a quick mock up of fenders
Old 04-02-2019, 10:55 PM   #22
zicc1835
zicc1835's Avatar
looking good
Old 04-03-2019, 03:24 PM   #23
68Gold/white
Originally Posted by zicc1835 View Post
looking good
LOL, in the neighborhood!!!
Job well done!!!
68Gold/white is online now   Reply With Quote
Old 04-03-2019, 04:13 PM   #24
Brettburwell
Job well done!!!
Yea im pretty limited to working space only have a one car garage
Old 12-15-2019, 12:11 PM   #25
Brettburwell
I havent posted in well over a year still working on the truck still and didnt really want to post anymore but i figured ive seen so much good info on here that maybe i could return the favor the photos here are my frame getting blasted in the spring epoxy primer and painting it black if anyone wants info about that let me know happy to share
1971, 350, c10, chevy, shorty
