Closed Thread
Old 12-31-2018, 09:59 PM   #76
randy500
Re: Door Assembly...the EASY way
Roll the window down all the way and slide it back till it hits the rear of the door. Picture shows clearance to install vent window.
randy500 is offline
Old 12-31-2018, 10:07 PM   #77
randy500
Install vent window from inside as shown in picture.
Then pivot window in place while leaning the top towards back of window frame, there is plenty of room for this because the window is all the way back and the door latch has not been installed yet.
randy500 is offline
Old 12-31-2018, 10:11 PM   #78
randy500
Roll the window all the way up while guiding it into forward wing window glass run channel
randy500 is offline
Old 12-31-2018, 10:22 PM   #79
randy500
Install the door latch, handle relay and lock rod as one unit then.
Install rear window run channel as pictured, rotate counterclockwise then pivot into place (counterclockwise looking down)
randy500 is offline
Old 12-31-2018, 10:24 PM   #80
randy500
Latch and associated parts preassembled for installation.
randy500 is offline
Old 12-31-2018, 10:36 PM   #81
randy500
The proper tools with picture of screws per location. (The pictured arm rest machine screw is not correct but is close, the correct one is a tiny bit shorter with a captured lock washer)
The regulator and door latch relay both take the shortest machine screws.
randy500 is offline
Old 01-01-2019, 01:43 AM   #82
68bowtie
68bowtie's Avatar
Got specs on the bit you ise for that door latch (#4)? Those guys can be a bear.
Like the others have said I have found this thread extremely helpful as well.
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
68bowtie is online now
Old 01-01-2019, 10:40 AM   #83
randy500
Its a snap-on 3/8drive bit like this one.
https://store.snapon.com/Phillips-17...r-P631491.aspx
the picture of the one in the link is generic though, its actually much larger. My electric impact usually gets them out if it doesn't then I switch to a 1/2" drive air impact with a 1/2 to 3/8 adapter. Its really the only way to remove those screws and all the rest on the door, they are tight.
randy500 is offline
Old 01-15-2019, 12:49 PM   #84
69Tom
69Tom's Avatar
Subscribed!
69Tom is offline
Old 04-28-2019, 09:56 PM   #85
tim_mc
tim_mc's Avatar
I followed these instructions this weekend for both doors. Great instructions! I got a Craftsman #4 Phillips 3/8" drive bit from my local Sears, Item # 00944373000 Model # 44373 to handle the door latch screws. An impact driver with the #4 bit worked perfectly.
tim_mc is offline
Old 05-30-2019, 03:58 PM   #86
1bad396ss
Excellent instructions and greatly appreciated. One question - does the window felt/weather strip running in the top channel of the door back down through the rear run for the side glass require any adhesive to stay in place? I have it all in place but seems very easy for it to pop out at any time. Thought a very thin bead of adhesive and roll it up tight for the night would do the trick but don’t want to if not needed.
1bad396ss is offline
Old 05-30-2019, 04:21 PM   #87
Astro-Balls
Astro-Balls's Avatar
Please do a Video of this removal and Installation, If you can get Sophia Vergara to do the actual work on the door...
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline
Old 05-30-2019, 04:21 PM   #88
1bad396ss
Old 05-30-2019, 08:37 PM   #89
hdixon
not needed
once I placed mine into the track it stayed hope this help
hdixon is offline
Old 06-02-2019, 01:08 AM   #90
Richard2112
Richard2112's Avatar
Excellent write-up Randy. Much thanks.
I've had my new window channel kits sitting around for three years because it was never clear how they went in. Now, I don't have an excuse.
Richard2112 is offline
Old 08-22-2019, 09:21 PM   #91
BigBird05
I just found your write up on 72 glass install. It is exactly what I was looking for. Only question I have is when to install the door handle? Thanks
BigBird05 is offline
Closed Thread
