Old 01-01-2019, 01:14 AM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Plans for your trucks this year?
Me, I'm going to replace my new correct oil pan bolts, because the bolts for the timing chain cover are too short with a on-piece gasket, same with the rears. Another lesson learned. I suppose I could install a cork gasket, but nah, I'll use ARP bolts. A little irritating, I like correct bolts But a matching set will have to work. At least they're black and a better bolt, the others are clear.
Other than that I hope to have my chassis done by spring. Then I face the reality paint prison may be too long, which means plan B. Plan B has a reputation, and he charges for it too. It's another 7K to get him motivated, and I haven't even asked. Thing is he'll get it done. He's even my nephew.........
He did these for me recently, $200, which was a deal. But I know better. 16K minimum. The bed is already done less paint, and the rest is a nice start. I'll get a dry run and the moldings installed for it. Then I'm looking at 2020 to finish. Takes me so long
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-01-2019, 02:28 AM   #2
rjs53
Re: Plans for your trucks this year?
Its a little early, but ill try. I plan on having it drivable by may. I've about finished the wiring and I hate wring. Gonna need wheels and tires, but working on a seat first. Burnouts by May, that's the goal.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 01-01-2019, 02:59 AM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Fix the rusted cab supports and rockers.
Old 01-01-2019, 04:53 AM   #4
dagnabbitt
dagnabbitt's Avatar
Lowering my 1970 SWB step by 4/6 and adding disc brakes, hopefully. I have a lot of things on my list, but that would make it more enjoyable to drive at least.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-01-2019, 05:51 AM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
Get it back together and drive it!! I hate cabin fever
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-01-2019, 07:22 AM   #6
Boog
laying low
Boog's Avatar
^^^^^ that!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-01-2019, 11:28 AM   #7
A whole lot more than last year. I'm not even going to say what I hope to get done. Kind like a new years resolution. Don't want to set myself up for failure. I could make a list of what the '72 needs and see what's checked off a year from today. The big things needed are repair rockers/one corner/new body mounts/window seals & anti-rattle on the body and seals in engine/trans/t-case. Tunes would also be nice.
Old 01-01-2019, 11:56 AM   #8
Boog
laying low
Boog's Avatar
You got any plans for the 67 stepper Tim?
The cab and engine/trans are back on the frame right?
Boog
primer is finer
Old 01-01-2019, 12:38 PM   #9
Lancialonnie
My freshly rebuilt 700r4 transmission is installed and tomorrow I take the driveshaft in to be shortened and re-balanced. It will be back on the road next week but as this is my first 700r4, I have a lot to learn about getting it setup. I went with a local shop to build it and a mechanic I have know for years is doing the install and both are very experienced with this swap. I sure hope it helps my gas mileage!
Lancialonnie is offline   Reply With Quote
Old 01-01-2019, 12:48 PM   #10
CG
BlahBlahBlah
OMG, already putting the pressure on! Ok I did make a few trades yesterday on some parts and some whole trucks. And made arrangements for storage and shipping. So If I can keep this up ... OK, I wont be able to do that. No biggie though, I think I have the most fun just moving stuff around =)
Old 01-01-2019, 12:57 PM   #11
Daffy84
When I changed the oil in the fall I found coolant but I haven’t had the time to mess with it. So I need to hunt down the problem.
1972 Chevy Cheyenne Super - 454 BBC
1995 GMC C1500 SLE - 350 SBC
1984 Cutlass Supreme Brougham - 1979 350 SBC
Daffy84 is offline   Reply With Quote
Old 01-01-2019, 01:03 PM   #12
70cst
70cst's Avatar
Simple - Drive it
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-01-2019, 01:06 PM   #13
toolboxchev
I would agree 70cst! I plan on keeping mine, driving it and getting more and more things addressed this year.
Blessed be the one by John! This is definitely a gooder day!
toolboxchev is offline   Reply With Quote
Old 01-01-2019, 01:10 PM   #14
Knight72
Get it running and driving before Christmas.
72 C10 lwb fleetside aka Big Rhonda.
Still plugging away.
Build thread:
http://67-72chevytrucks.com/vboard/s...42#post8247142
Knight72 is offline   Reply With Quote
Old 01-01-2019, 02:30 PM   #15
clay68c10
clay68c10's Avatar
Fix the rockers, corners, and cab supports.
Rust repair on the door bottoms.
Mock up the engine and transmission and make a crossmember for the TKO500.
Get the parts and build the Vortec headed 383.
Mount the rear tank and mod/fit the bed floor accordingly.
Paint the frame so maybe I can attempt to assemble this pile of parts.
Man, I better get my butt to work
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-01-2019, 02:32 PM   #16
68Stepbed
68Stepbed's Avatar
Swap from carb to EFI, rebuild trans with new close ratio planetary, get faster at autocross!
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-01-2019, 04:41 PM   #17
red211
Finish the disc brake conversion. Get front end back together. Get engine running and drive it. Missed last summer by dragging feet and don’t want to miss a second. Will be installing 4speed but will need to build a console at that time so if the three speed makes it through another summer behind the v8 then 4speed is next winter project. If it breaks that will move up on the list.
Not sure how to turn pic, that makes Me dizzy. Sorry guys.
red211 is offline   Reply With Quote
Old 01-01-2019, 04:47 PM   #18
ApacheNick
Rebuild the transfer case, find a proper bench seat, and hopefully find some driver quality doors and a better box.
All fairly simple(hopefully) stuff really, but I want to get my 61 done before I go too crazy with this one. Two trucks torn apart = nothing gets done ever.
Nick
1961 Apache short stepside 4X4 SBW 348/4 speed
1960 Apache C-20 long fleet custom cab BBW 283/4 Speed
1967 rust bucket Olds Cutlass with a 455
1972 GMC K-15 350/4 speed long fleet
ApacheNick is offline   Reply With Quote
Old 01-01-2019, 04:58 PM   #19
Boog
laying low
Boog's Avatar
turn
Boog
primer is finer
Old 01-01-2019, 05:14 PM   #20
red211
Thanks Boog, I have been deep in the K20 pic thread and forgot I was on the 67 side. Mine is a 63 so sorry for the invasion.
Old 01-01-2019, 05:23 PM   #21
ho70
ho70's Avatar
had the 402rbuilt last year and the rear seal leaks......put a wood bed in and was given a wrong board (driver side with holes) and they still haven't sent me proper one (since July-classic -industries) gonna put in a new wire harness and fix the mistakes.
ho70 is offline   Reply With Quote
Old 01-01-2019, 06:00 PM   #22
Tdub16
To finally get to see it in July and drive it. Then just start the long process of fixing it up.
71 C10
Tdub16 is offline   Reply With Quote
Old 01-01-2019, 06:14 PM   #23
rjs53
What do you mean finally get to see it?
2003 Dodge 2500
1969 C10
Old 01-01-2019, 06:25 PM   #24
DA71Grande
DA71Grande's Avatar
Originally Posted by 70cst View Post
Simple - Drive it
Dewayne what bed cover do you have on your truck?
Doug
71 Sierra Grande C25
16 Sierra 2500HD All Terrain
23 Chevy Tahoe Z71
https://paypal.me/digdug7131?locale.x=en_US
DA71Grande is offline   Reply With Quote
Old 01-01-2019, 06:48 PM   #25
tim71
tim71's Avatar
Plans for 2019:
1. Drive truck way more often (only managed approx. 400 miles last year)
2. Repair leaking rear main seal
3. Replace HEI distributor with a small body HEI
4. Lower the truck down to stock height (ok, maybe stock plus 1"zero rate)
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
