Old 12-18-2018, 04:38 PM   #1
fryed_1
71 Cummins Swap
After 3 years of running around with it, doing garbage and lumber runs, hauling kids bikes and other stuff I'm finally getting around to collecting everything I need to rebuild and make something fun out of it.
Current parts on hand are the swapped dually, my 71 and a full choppin block kit with accuair e-level. I'll start with a stripped, cleaned and painted chassis with the above upgrades over the winter and just wing it for what I want it to look like after that. I might finish the body or I might fix the few rust spots, clearcoat and call it a day or anywhere in-between.
https://www.youtube.com/watch?v=47TMU50L60o
fryed_1 is offline   Reply With Quote
Old 12-21-2018, 11:54 AM   #2
rjs53
Re: 71 Cummins Swap
Have you changed the plate in the pump, What have you done to the Cummins? I think its gonna be cool
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 12-24-2018, 06:10 PM   #3
jarrodblake
jarrodblake's Avatar
Re: 71 Cummins Swap
If it was mine I would body swap it on the newer frame and just shorten it. That way you would have a heavier duty frame that and the cumming swap is already done.
jarrodblake is offline   Reply With Quote
Old 12-24-2018, 09:02 PM   #4
boynton
boynton's Avatar
Re: 71 Cummins Swap
I look forward to he progress!
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 01-02-2019, 02:33 AM   #5
Madkidd007
Madkidd007's Avatar
Re: 71 Cummins Swap
Assuming you’re still gonna do the swap, if it was me I would find a used front suspension/crossmember from a square body dually and bolt it to your frame, keep in mind frame strength doesn’t matter too much on a 2wd being the front crossmember does a great job of tying it together. That way you also have the square body factory engine stands, now the reason for that is the angle is the same as the 1st gen cummins so all you have to do is drill some holes and use all the stock cummins/dodge engine mounts. Only issue is it’ll sit a little high for trans tunnel clearance but with mine I cut my engine side mounts and slid the engine down or you could just use square tubing to make engine side brackets.
I can post fitment pictures if you would like
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
