Old 01-03-2019, 01:36 PM   #1
macdodd127
headers
I have a '69 C-10 with a stock 350 in it. It has headers on it now and I'm gonna replace them. Any suggestions?
macdodd127 is offline   Reply With Quote
Old 01-03-2019, 01:41 PM   #2
Doug's68SS
Re: headers
Stock Manifolds, headers are a real pain.
Doug's68SS is offline   Reply With Quote
Old 01-03-2019, 03:05 PM   #3
macdodd127
Re: headers
Yea,,,I'd thought about that since the engine is stock
Old 01-03-2019, 04:40 PM   #4
FRCvette
Re: headers
Agreed.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 01-03-2019, 07:58 PM   #5
hjewell2
hjewell2's Avatar
Re: headers
yep stock motor means stock manifolds no maintenance after install..
hjewell2 is offline   Reply With Quote
Old 01-03-2019, 08:08 PM   #6
Myoldtruck
Myoldtruck's Avatar
Re: headers
im about to go back to ram horns. I just want clean and simple.
Myoldtruck is offline   Reply With Quote
Old 01-03-2019, 08:54 PM   #7
Sawlog
Re: headers
Heedmen headers. Just put new ones on my 69 c10 with a 350. Number 5 plug takes a few minutes to get out. No clearance issues.
Sawlog is offline   Reply With Quote
Old 01-03-2019, 10:30 PM   #8
68 P.O.S.
Re: headers
If you buy cheap $99 headers, then every bad thing you've heard about headers WILL happen to you. If you buy good headers, which are pricey, you'll have no more problems than you would with stock manifolds. A thick header flange is key. For a stock engine, stock manifolds are perfectly fine. If you decide on headers, get a set of tri-y's. They build power down low, where it will be useful on a daily driver or towing rig. The 4 into 1 headers make their power in the higher rpm range, not where you do most of your driving. Splurge for ceramic coated if your wallet can accommodate that. But again, stock manifolds are just fine on a stock engine. Even upgrading to the 2-1/2" Corvette manifolds won't do much for a stock engine, other than make it a pain in the @$$ to route your exhaust and mount your accessories.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 01-03-2019, 10:53 PM   #9
Mike C
Mike C's Avatar
Re: headers
2 1/2" 'vette rams horns.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-03-2019, 11:46 PM   #10
Grumpy old man
Grumpy old man's Avatar
Re: headers
2 1/2" rams ,
Old 01-04-2019, 08:53 AM   #11
FRCvette
Re: headers
Originally Posted by Grumpy old man View Post
2 1/2" rams ,
I seen this pic a while back and this is what I did. Thanks Grumpy.
2004 SSR
2013 Silverado swb
Old 01-04-2019, 08:53 AM   #12
Firebird2077
Re: headers
Running a set of set of Summit brand headers. They have surface rust on them now. I will be cleaning them up. On a stock motor probably best to go stock exhaust. I have a pretty aggressive cam in my 350 so I went with a set of long tube headers.
Firebird2077 is offline   Reply With Quote
Old 01-04-2019, 09:12 AM   #13
Sawlog
Re: headers
These fit good. Heedmen headers
Old 01-04-2019, 10:13 AM   #14
Grumpy old man
Re: headers
Thanks , This isn't a race engine by any means just a little thumper like we built back in the 70's , It's more about trying for a nice clean appearance and a little fun to drive truck that I don't have to wrench on every weekend when it's done . I can switch plugs easily and I'm not going to the track with it .
The hardest launches it will do are in front of my neighbors house Who just built a total pro Cuda show car with a super charger with 3 chrome Holleys on a 499 sticking 3.5' out of the hood it gets about 1.5 miles to the gallon , I haven't seen him turn it loose yet ? It sounds great pretty sure it's a pegleg , It's been running the show circut pretty much lately My neighbor (his father) on the other side has a nice '47 on a S10 frame he just finished another peg leg . So this little small block with a rock chrusher and 3.73 posi should get the neighbors going in a fun way , It's a good thing to have neighbors who are interested in the same thing as you are . No one around here complains about large compressors running all day or the occasional loud engines running late at night
https://www.youtube.com/watch?v=rgFW7cBqwCM
Old 01-04-2019, 11:17 AM   #15
rjs53
Re: headers
A decent set of headers will work and help with a little power. Headmans with the ball socket end work good for me. Never have to worry about a collector leak. Don't over tighten the headers when first installed. Heat em up them go back and torque down. Use a good aluminum gasket not paper.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 01-04-2019, 11:30 AM   #16
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: headers
Headers get a bad rap because most people overtighten the fasteners and warp the flanges, or use crappy gaskets that blow out. I've installed headers on dang near every V8 vehicle I've ever owned, and have not had the problems everyone associates with headers.
I will add this though... changing spark plugs on a SBC with headers could be a new Olympic Sport. Get's a little tight, but if you take your time and know a few tricks, it gets easier over time.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 01-04-2019, 01:21 PM   #17
fdbdw
fdbdw's Avatar
Re: headers
I had headman long tubes on my old truck, never had a problem. It’s been said many times, don’t go cheap when it comes to headers
fdbdw is offline   Reply With Quote
Old 01-04-2019, 03:38 PM   #18
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: headers
Doug's headers on 2 of junkets.
No plug clearance issues. No gasket issues.
Zero maintenance basically
Old 01-04-2019, 03:47 PM   #19
BossHogg69
motor exploder
BossHogg69's Avatar
Re: headers
THIS! X2
Nothing wrong with stock manifolds either, but I have headers on every vehicle I own and have never had any problems. Either way you go, pay attention to plug wire routing and don't cheap out on crappy parts and cheap gaskets and you'll be fine.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-05-2019, 11:13 PM   #20
rockyrivermark
Re: headers
I'm running summit brand ceramic headers with no problems. Look good. No leaks.
I did use fel pro gaskets though.
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 01-06-2019, 09:28 AM   #21
Re: headers
I was wondering when we would have our next discussion on Headers vs manifolds. Headers are an effective as well as harmless mod. Effective meaning if your engine is build up bad to the bone they are the final equation for getting that horsepower producing air through the pump. Harmless meaning, while a stock motor may not see much beneficial gain, they don't hurt a thing.
As far as looks go, I like the look of headers. They both look clean (except for the factory heat deflectors), but personally I see tubular headers as being the clean option. Also the performance option, for looks. And you are ready for anything else you decide to throw at your mill.
As far as reliability goes it's a draw in my eyes. Personally, I have had more issues with manifolds than headers. Run enough of these trucks stock long enough and you would know. And the problems that 'can' occur with headers I would rather deal with than the problems I've had with manifolds.
It really comes down to what you like. You can't go wrong either way as long as you don't buy cheap crap... not that I didn't get 15 reliable years from a set of cheap headers I had to have installed in Flagstaff on my '71 Custom Camper when one manifold blew out descending the North Rim of the canyon. You would think cast iron would last a lifetime, and some seem to be. But I have to wonder about anything new made in China with what seems to be their inferior metallurgy.
Old 01-07-2019, 12:03 AM   #22
BossHogg69
motor exploder
BossHogg69's Avatar
Re: headers
Funny you say that Special-K, the one vehicle of mine that did have manifolds (they were on it when I got it) was my '65 Bel Air wagon. Drivers side manifold cracked, then I put headers on it!
Adam
Old 03-01-2020, 07:02 PM   #23
Brim
Brim's Avatar
Re: headers
Your flanges look pretty beefy,what brand headers did you use?
Brim is offline   Reply With Quote
Old 03-01-2020, 09:29 PM   #24
Myself
Re: headers
I never had issues with my cheapy Hedmans. Drove it daily for 16 years. Put gaskets on once. Never did anything with the collectors....I had donut gaskets in place.
Myself is offline   Reply With Quote
Old 03-01-2020, 10:08 PM   #25
Gleno97
Re: headers
I just installed Summit Ceramic coated headers and the have real thick flanges and fit perfectly on my 69 C20 350. Also did single barrel to 4 barrel Holley 600 and dual plane intake. Totally woke it up. Its not a dog anymore. Lots of power. Power steering is next.
Gleno97 is offline   Reply With Quote
