Old 01-09-2019, 12:34 AM   #176
Metaldoc
Metaldoc's Avatar
Re: What did you do to your truck today.The 3rd chapter
Making filler pieces from scratch
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Old 01-09-2019, 12:59 AM   #177
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Originally Posted by davischevy View Post
If you rotate the shaft in the A-arm before you install it, it will move fore and aft within the A-arm to center it.
I ended up benching the bushings onto the control arms without the shafts, and then reinstalled them with the shafts mounted. You can't help be off more than a pinch center. For the most part I put equal turns on the bushings all the way through, and they wrenched on fairly smoothly. Couldn't tell you what 90 and 100 ft. pounds is using a crescent wrench, but they're probably close. I'll let the alignment gang work that one out.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-09-2019, 10:03 PM   #178
66clow
66clow's Avatar
Originally Posted by kcmarkd View Post
Sorry for the delay in getting to this. Since that post, we have had 14" of snow, downed trees, Christmas road trip, then 8" of rain and flooding. Oh, and the old engine in the truck started knocking (joy).
Anyway, got to it tonight. The whole process worked out much better than I feared. My goal in all of this is for the drip edge to be weather tight, not looks.
Before the Christmas road trip, I had sprayed on a coat of 2K Epoxy primer that I got in a rattle can from Advance Auto (who knew?). Primarily because the 3M instructions indicate to apply this on a 2K primer or bare metal. This will be the beige color in the pics below.
Along with the 3M 8307 Self Leveling and the 3M 8308 heavy body, I also ordered the 3M gun (3M P/N 8571).
Attachment 1852632
I started with the vertical portions of the drip edge and laid down a pretty thick bead of the 3M 8308, starting right at the top of the upper curve. Then I simply used a gloved finger to smooth it out, trying to press it into the seam without squeezing it out. I left the beginning of the bead pretty thick, so it will act as a dam for the self leveling 8307.
Attachment 1852629
I also had a spot at the upper right corner where there was about a 1/8" gap between the roof skin and the rest of the metal that I filled with a small bead of 8308. Once both sides were done, I let it cure for about an hour, then took the 3M 8307 and got after it. Starting on one side, I began filling the drip edge, and worked my way around to the other side. The 8307 is definitely thinner than the 8308 and leveled out nicely.
Attachment 1852630
I then let that cure for about an hour, then masked off the cab and sprayed a coat of basic white rattle can primer over the newly sealed drip edge. Nothing fancy.
Attachment 1852631
Is the 8307 too thin to run down the sides? Looks great, will be doing this.
66clow is offline   Reply With Quote
Old 01-10-2019, 04:43 AM   #179
OL SKOOL
OL SKOOL's Avatar
Originally Posted by RodnRudy View Post
And a few more of the rust repair and speaker hole.
Nice work on the patch panels. I have the exact repair to do on my door. How do you get the edge bent over to go over the inner door. I can see from the speaker hole pic looks factory perfect. I have to admit i'm kind of a stalker for your vermillion red truck. Thanks
OL SKOOL is offline   Reply With Quote
Old 01-10-2019, 07:27 AM   #180
Metaldoc
Metaldoc's Avatar
I finished up welding up the patch for the ugly speaker hole in the door this afternoon Also I picked up this nice E brake cover at the swap meet this morning. Thanks Todd, nice meeting you.
Nice work, you've done this before. That blue E brake cover doesn't match your color but it does mine. I wouldn't even put it on just give it away to someone with a blue truck. I have a blue truck. Can you take some pics of the other side of it so I can decide to make one or keep looking.
Thanks man.
Old 01-10-2019, 11:28 PM   #181
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
My good friend Robert was on his way to have his buddies restored. I asked if I could trade him my 68 console cushions for his 67. I replaced the rotted ply wood, give them a little scrub, added some Gorilla tape & a flash coat of Fawn Beige lacquer. Good enough for a 67 driver.
http://67-72chevytrucks.com/vboard/a...1&d=1547176723
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 01-11-2019, 12:24 AM   #182
Metaldoc
Metaldoc's Avatar
[QUOTE=Canuckvetter;8440909]My good friend Robert was on his way to have his buddies restored. I asked if I could trade him my 68 console cushions for his 67. I replaced the rotted ply wood, give them a little scrub, added some Gorilla tape & a flash coat of Fawn Beige lacquer. Good enough for a 67 driver.
Hell ya nice score and nice reconditioning.
Old 01-11-2019, 12:33 AM   #183
Metaldoc
Metaldoc's Avatar
Got all my filler pieces done
Old 01-11-2019, 12:40 AM   #184
Canuckvetter
Are you going to paint them black or body colour?
Old 01-11-2019, 01:39 AM   #185
Metaldoc
Metaldoc's Avatar
I've been playing on 3D paint with the two colours and I'm leaning towards black. The blue pulls away from the engine and makes it look small. I'm going to paint the under side of the hood which will brighten the look
Old 01-11-2019, 09:56 AM   #186
SoCoC10
SoCoC10's Avatar
Installed a Saddle Cheyenne Super seat cover from Larry @ Truck World.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 01-11-2019, 01:15 PM   #187
tdangle
tdangle's Avatar
Looks great. What is the link to them?
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 01-11-2019, 01:40 PM   #188
SoCoC10
SoCoC10's Avatar
Larry is old school. No link because there's no website. His PayPal is an AOL address. PM me and I can help you if you want to buy Truck World products.
Old 01-13-2019, 03:17 PM   #189
TruDom
finishing the fine tuning of everything before inspection/registration... so close to cruising!
TruDom is offline   Reply With Quote
Old 01-13-2019, 07:07 PM   #190
RodnRudy
RodnRudy's Avatar
Like the truck!
I didn't get anything done to mine as I was busy running the snow thrower Sat. and today. Winter has finally arrived in Central Indiana
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 01-13-2019, 07:14 PM   #191
Metaldoc
Metaldoc's Avatar
Must suck to have snow, It's a good thing I live southern Ontario Canada, we don't have any. So I spent the day in the shop. New LED bulbs in 5050K color is perfect. Doesn't need a dimmer looks just right.
Old 01-13-2019, 08:11 PM   #192
zicc1835
zicc1835's Avatar
Beautiful truck
zicc1835 is offline   Reply With Quote
Old 01-14-2019, 09:46 PM   #193
Drew94st
Drew94st's Avatar
Rainy day in San Diego. Prepped hubcaps for black paint.
Drew94st is offline   Reply With Quote
Old 01-14-2019, 10:44 PM   #194
Kevin7723
Kevin7723's Avatar
I changed out the door lock cylinders with new ones so that my doors could actually lock. Before the rain hit here I was also able to install the new repo wiper arms and wipers along with my parking brake handle
Kevin7723 is offline   Reply With Quote
Old 01-16-2019, 12:40 AM   #195
71CHEVYSHORTBED402
Installed the oil pump and pan, and detailed some spots missed underneath. I was concerned about settling, because the POR15 is heavy. But in hindsight, it have been better to rotate the block when I originally brushed the paint on.
I installed the battery clips at the 2nd and 4th 5/16" bolts from the front, and the transmission lines retainer 3rd from the front. I'm not 100% sure that's what is was from factory, though suspect it is.
EDIT: And yeah they're two different colors. Two completely different situations. The guy who painted the pan took a paint sample, and he's the best for many miles. But two completely different situations. I brushed three coats of engine enamel on the block. The pan was sprayed with automotive paint, primer'd and clear coated. The oil pan looks darker to me, someone else says lighter, but then I'm shade blind.
I tried brushing the pan, and came close before I (*^)^ed with it. Then I proceeded to strip it. I wasn't planning to brush the valve covers anyway, so yeah, the valve covers vary as well. I'll try to enjoy it with the black and Ochre, and some engine compartment specials.
Call me crazy, but somehow the shade variance is lost when it's right side up, and the valve covers were sprayed with the pan.........Hmm. Maybe I'll spin it sideways, see what happens then
Tony
Old 01-16-2019, 03:56 AM   #196
tino0217
Installed upper shock absorber brackets. Took about n hour n 20 minutes per side but I'll sleep better knowing it's done. No pictures but if your truck needs it , do it
tino0217 is offline   Reply With Quote
Old 01-16-2019, 08:28 AM   #197
Mts67C10K20
Mts67C10K20's Avatar
Started stripping engine for removal
Next will be some engine bay cleaning and some paint
Before the new engine goes in
Mts67C10K20 is offline   Reply With Quote
Old 01-17-2019, 10:50 AM   #198
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
Out with the old 3 on the tree column and in with new to me tilt for 4 speed. I made this tilt out of a auto tilt by shaving off the indicator and gear lever.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-17-2019, 11:37 AM   #199
SoCoC10
SoCoC10's Avatar
Tear down complete on the 71 K10 Cheyenne. Going back to the original Hugger Orange on Saddle she came from the factory with.
Old 01-17-2019, 04:25 PM   #200
Redneck Rydes
Redneck Rydes's Avatar
Put lowering spindles and a 4 inch shackles in rear. Building this one for the wife,so we can cruise and go to some shows this summer
Redneck Rydes is offline   Reply With Quote
