Old 01-15-2019, 09:22 PM   #301
Robert Haas
Re: Two is easier then one 1965 GMC S/W/BB build
Originally Posted by slimjim66 View Post
that truck is wild man, couple questions for you....
where did you get those red truck covers?
what hinges do you plan on using for the hood?
fantastic build tho, the title of this build is "two is easier than one" still panning on building the other too?
The covers are from California Car Covers.
Using billet hinges in the stock locations, that is why we had to go full custom on our wheel tubs and still retain the standard mounting position. However the new hinges use gas struts so we were able to fill the spring wells.
As far as the second build, well the plans is still in place but to be honest this truck has taken so many turns and changes that it became a full frame up custom and the Race Truck will sit patiently in the background for another year or two.
One thing has changed. I was planning on building my own chassis for the Race truck but after building this chassis on Greg's truck I will farm the chassis out to Rob @ No Limit engineering. we have chatted about what I want and he is confident we can have a roller able to pull 2 g's lateral and handle the 1,000 HP program I will be shoving into it.
Robert Haas is offline   Reply With Quote
Old 01-15-2019, 09:35 PM   #302
Robert Haas
Don't know why but here let me show you what we have been doing.
Greg designed and laid out the inner panels that mount above the wheel tubs and I took pictures of him doing the work,
first thing is make a cardboard pattern complete with notches and the bead roller pattern,
check
now do that twice and after 200 test fits and trims, transfer that to some 16 guage steel.
Check;
Now cut it out and chase it around the bead roller, then brake it on the brake
check
now fit them and tack weld them in.
checkmate
Old 01-16-2019, 11:40 AM   #303
jhrusk
Looking good
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 01-16-2019, 12:36 PM   #304
slimjim66
that's awesome, good work. you make it look easy
slimjim66 is offline   Reply With Quote
Old 01-16-2019, 12:55 PM   #305
Robert Haas
core support and radiator shrouds next.
Old 01-16-2019, 03:37 PM   #306
Duncan K
Great job on the sheet metal! Super clean and custom!
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 01-16-2019, 04:28 PM   #307
AJCK87
Beauty work there Robert! Wishing I had a bead roller to do work like that! Very professional job. Makes me look at my budget build some times, if I’m doing it justice. But I figure I saved it from the field, and being a redneck wrenching in the driveway isn’t so bad, I’m having fun anyways. I can see you guys are as well! I’m watching, keep up the good work
AJCK87 is offline   Reply With Quote
Old 01-16-2019, 04:57 PM   #308
ibrown50
ibrown50's Avatar
I agree with AJCK87, this build makes mine look like ametuer and budget but the quality is inspirational, I love it
Getting old sucks.............but it sure beats the alternative
ibrown50 is offline   Reply With Quote
Old 01-19-2019, 09:06 PM   #309
Robert Haas
core support built today, will skin it tomorrow. Hood mocked up with the Billet Aluminum hinges from Eddie Motorsprts.
Old 01-19-2019, 09:10 PM   #310
Robert Haas
New core support frame, taller and wider then the OEM. Now allows a massive crossflow radiator from Be Cool to nestle right in.
We built a wooden mock up of the radiator to allow me to build around it without damaging the ultra spendy aluminum piece.
Old 01-19-2019, 09:15 PM   #311
Robert Haas
Now we un-boxed the radiator and test fit it, the cap penetrates the top cross-member but is reinforced with a piece of 12 Gauge stainless steel exhaust pipe. Will be trimming the top to flush out with the tin we are building that covers the top. (More on that later)
Old 01-19-2019, 09:20 PM   #312
Robert Haas
So for the first time in many many months we set the truck on the ground. This is the first time the front sheet metal has all been on the truck in 17 months.
Nothing is actually bolted up or adjusted. this was about confirming all the modifications worked with one another,.. and yes, they all do. We also are starting to get some preliminary ride height set ups now that the majority of weight is going back on the truck.
Old 01-20-2019, 06:23 PM   #313
jhrusk
Wow. Great job Robert. Nice work. That truck is going to be so nice.
Old 01-21-2019, 12:23 AM   #314
Robert Haas
Thank you
Old 01-21-2019, 11:07 AM   #315
Robert Haas
Core support
Old 01-21-2019, 11:08 AM   #316
Robert Haas
Old 01-21-2019, 11:10 AM   #317
Robert Haas
Old 01-21-2019, 12:53 PM   #318
ibrown50
ibrown50's Avatar
The core support turned out really well, it’s almost a shame to cover it up
Old 01-22-2019, 11:24 AM   #319
jimmythompson1964
jimmythompson1964's Avatar
I need a bead roller...that is some good looking work guys
jimmythompson1964 is offline   Reply With Quote
Old 01-22-2019, 06:06 PM   #320
Robert Haas
thank you
It is turning out to be a pretty handy addition to the shop.
Old 01-22-2019, 09:31 PM   #321
kdad
WOW!!!!!!
Totally subscribed. Kinda wish I still lived in Gilroy so I could sneek over for a peek...
The entire project is looking great! please keep up the posts and pictures we all love em.
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039
She may not be the prom queen but at least she puts out..
kdad is offline   Reply With Quote
Old 01-23-2019, 12:04 PM   #322
Robert Haas
We did install a partition curtain between the clean side of the shop and the fab side. Now that we are into sheet metal we will be using body fillers and shooting primer so needed to protect the "clean" stuff.
Old 01-23-2019, 12:25 PM   #323
kdad
Never thought I would say this about a shop but " I love what you have done with the curtains" LOL
Old 01-24-2019, 12:22 PM   #324
Greg B
Good one...
Greg B is offline   Reply With Quote
Old 01-30-2019, 09:03 PM   #325
Robert Haas
Further progress on the core support.
Greg is running a Vintage Air system so today we got the condenser integrated.
