Old 05-21-2016, 09:33 PM   #151
Geomarq123
Re: First hand experience with changing to the NBS master cylinder WOW!
Found this thread as I was swapping the rear discs on my 97 k1500. Then did the master cylinder, and figured I'd change to the right combination valve. Now I'm stuck, can someone help?
How can I plumb the new combination valve into the abs unit? The diagram shows what I have..the combination valve bolts and directly takes fluid in and the abs unit has three valves out...two valves for the front, one rear. The correct disc/disc combination valve has two ports in three out. The old is two in, two out. I've never liked the abs on this truck..should I discard? What's the proper way to disable the Abs?
Geomarq123 is offline   Reply With Quote
Old 05-22-2016, 08:16 AM   #152
speedygonzales
speedygonzales's Avatar
This issue should have it's own thread. People are going to come here looking for changing the master cylinder information.
Repost it as a new post.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 05-26-2016, 01:24 PM   #153
hatzie
Moderator
hatzie's Avatar
Originally Posted by speedygonzales View Post
Yep just don't let the reservoir get too low.
Oh and always buy new fluid and if there is any fluid left over in the bottle, toss it. Don't keep it laying around. It draws moisture right through the plastic container sides.
Metal cans won't but try finding brake fluid in metal cans.
Metal cans is the only way I buy it. Who knows how long the plastic bottles have been hanging around at the warehouse... Just say no to brake fluid in plastic bottles. Plastic bottles with foil lined caps and vacuum deposition metallized insides would probably do the job but they are trying to wring the last 1/8th penny of profit from any sales.
Brake Fluid I can buy locally in metal cans...
Pentosin DOT4 I can get both Super DOT4 and low viscosity DOT4 LV locally at Bond Auto Parts. DOT4 LV is a 1-2 day turnaround to order it in Super DOT4 is on the shelf. I believe Pentosin is available on-the-shelf at AutoZone for you folks in the city.
Name:  Pentosin DOT4 LV.JPG
ATE DOT4 Type 200 and SL-6 are not as common to find on the shelf but the local NAPA franchise can and will get me the low viscosity SL-6, that I run in my LS4 Impala and VW, in 2-3 days. I have no problem stocking several metal cans because it keeps. They have several local folks with MGB and other semi-antique British cars that use this stuff too.
Name:  ATE Type 200.jpg
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-04-2016, 10:24 PM   #154
satisfied
I have a 96 C1500 Burb. Will the switch out using the MC 2002 Siverado with rear disc brakes be compatible with my truck with rear drum brakes?
satisfied is offline   Reply With Quote
Old 06-05-2016, 09:30 AM   #155
speedygonzales
If it looks like this:
Then yes
Incidentally mine is shot already
Pride and joy
Old 06-05-2016, 12:59 PM   #156
Keith Seymore
Keith Seymore's Avatar
I would say no.
If you have disc/drum brakes then you need a disc/drum master cylinder. I wouldn't think a disc/disc master would have the right design considerations for your setup.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-08-2016, 09:50 PM   #157
satisfied
Speedygonzales,
Is your NBS MS already shot? A 1999 would have drum brakes as well.
Old 06-09-2016, 06:20 AM   #158
speedygonzales
fluid leaking past the seals. It's been suggested the lines have to be reversed, will try that this weekend with a replacement unit.
Pride and joy
Old 06-12-2016, 06:03 AM   #159
68C15
blood type; Retumbo
68C15's Avatar
I'll be watching for your update. I don't have a newer truck in the shop otherwise I'd follow the lines and see which is which
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-12-2016, 07:57 PM   #160
speedygonzales
I looked for any published indication that the ports were reversed on the GMT800 MC. Could not find any.
The reservoirs both old and new seem to have bigger portions on the front. Even if they don't it makes no difference. I did not reverse the lines.
Still crappy brakes compared to everything else on the road but better then it was when it had the original MC.
Pride and joy
Old 06-19-2016, 09:00 PM   #161
Eman85
I've read thru this thread as a fix for my Chevy truck. I was a GM tech from the 70's up until these trucks were new. They always had the soft pedal from day.
The original MC had a step bore so it did make a difference how the lines were attached, plus since you had frt. disc only the reservoir for the frt. is larger. the reason for this is that disc brakes are self adjusting in the the piston moves out as the pad wears and the space is taken up by fluid. On a straight bore MC the only difference in ports would be if you had a MC from a frt. disc vehicle. The NBS MC is for a disc/disc vehicle so it doesn't matter how you connect the lines.
Eman85 is offline   Reply With Quote
Old 03-04-2018, 09:10 PM   #162
SquareOne
Another Co-Sign to this upgrade
I did the NBS upgrade this afternoon after the drum brake wheel cylinders failed and I had to replace those and bleed the system anyway.
WOW! Night and Day. If you're on the fence, you're wasting your time. This is one of the easiest and quickest upgrades you can do.
I got lucky and I got the MC from a friend who was doing a hydroboost conversion on his 2001 NBS, so it didn't cost me a thing. I know that there is a piece of mind that comes with buying one new but I never hear about stock MCs failing that often so I decided to err on the side of saving money and we with the used unit.
The pedal feel and response is significantly better than the original equipment. I feel it now brakes just as good if not better than the wife's 2015 sedan.
SquareOne is offline   Reply With Quote
Old 03-04-2018, 10:06 PM   #163
SquareOne
Old 03-05-2018, 08:45 AM   #164
mountie
mountie's Avatar
Square One is a perfect example why us truck owners are here....
To make our cool trucks better!
I did the MC upgrade 2 years ago, because I learned it here.
'70 GTO Midnight Blue
'88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany.
'93 Cadillac STS Black
'93 Mercedes SL 500 Teal
'86 Yamaha FZ750 - 15,000 RPM
'86 Yamaha FJ1200 - Criminally Fast
2016 Ferrari 488 GTB, I drive it - don't own it.
'05 GMC Yukon XL , SLT 4wd ( just purchased 2018)
mountie is offline   Reply With Quote
Old 03-05-2018, 07:03 PM   #165
speedygonzales
Stop wasting your time changing pieces to get better brakes!!!
All of this is a waste of time.
Trust me I started this thread. In addition to changing the master cylinder I also changed my front calipers to 2 piston and rotors to slotted type.
None of this works as well as the way the brakes should be from the factory. But I'll tell you what does! I just came in from doing it.
It's called the "automated bleed procedure".
I was poking around a few threads mentioning that nothing works until people did this. Some even said most GM's are this way. Without it you're wasting your time.
But what the hell does bleeding the ABS have to do with the normal brake operation. I"m sure I'm not the only one that said that and did normal brake bleeding procedure. I don't know and was skeptical until I did it.
See my new post for a little more information.
Pride and joy
Old 03-05-2018, 07:36 PM   #166
mountie
mountie's Avatar
I'll gladly check that out.
Old 03-17-2018, 02:08 PM   #167
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Getting ready to do this and a couple things are bugging me.
1) Everyone buys a NBS MC with application for a truck with rear disc brakes. All GMT400's had rear drums. Does it not matter?
2) Anyone done this on a truck with rear ABS only (94 down)? There is hardly any length of line between the ABS setup and the MC on the older trucks. The 95 up have the ABS stuff a ways from the MC on the fender so that makes things easier. All pics I've seen are 95 up.
Thanks in advance.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 03-17-2018, 04:15 PM   #168
Tom
driving is in my blood
Tom's Avatar
That's been answered many times in this thread. The vast majority of people doing this are not doing rear disk brake swaps along with it. Its works great.
Old 03-17-2018, 05:14 PM   #169
arrg
Thanks in advance.
I did it on my 1988. It was a royal pain to bend the short lines. They didn't turn out very straight and I really had to tighten them down more than I should have to get them to stop leaking. I will likely replace them with some Nicopp line at some point because I don't like how they turned out.
1988 Chevrolet C1500 RCSB
arrg is offline   Reply With Quote
Old 01-20-2019, 12:53 AM   #170
hb32
hb32's Avatar
Accomplished this today as well and do not notice a huge difference. Lots of dark fluid on the bleed and reservoir on the old mc was really dirty. Going to wait a week and try another bleed. Thanks to the op for the part numbers and tutorial.
Life is too short to drive a boring vehicle.
hb32 is offline   Reply With Quote
Old 01-20-2019, 09:32 AM   #171
speedygonzales
Waste of time
Do the automatic bleed process. Best 3 minutes time spent every time.
Pride and joy
Old 01-20-2019, 12:11 PM   #172
hb32
hb32's Avatar
Re: Waste of time
Spent an hour searching for the “ automatic bleed process “ and could not find it.
Old 01-20-2019, 03:15 PM   #173
hatzie
Moderator
hatzie's Avatar
Re: Waste of time
Old 01-20-2019, 03:36 PM   #174
hb32
hb32's Avatar
Re: Waste of time
Originally Posted by hatzie View Post
Thanks for the info. Unfortunately I don’t have a scanner so looking at alternative methods. I just took it for a drive and it is noticeably different then yesterday, after slamming on the brakes to activate the ABS. Will try that a couple more times and bleed again.
Old 01-20-2019, 04:09 PM   #175
hatzie
Moderator
hatzie's Avatar
If you want to do an auto bleed that's the way it's done.
A Tech2 clone is $259. I own one. They work.
GM VXDiag is around $110 and it comes with Tech2Win and TIS2000. You need a Windows laptop to go this route and those aren't free. The NAO 33.004 Tech2 BIN file is available on the Tech2 Wiki if it's not shipped with the VXDiag tool.
The Snap On Solus tools can be had used for just under a grand.
AutoEnginuity can do it as well but you need a laptop and the cost is right around $500.
There are probably a handful of other tools in the $500 on up range that can do it on some but not all ABS systems.
The nice thing about the T800 master cylinder is the round three tab cap that takes one of the leak free pressure bleeder adapters...
Motive 1107
SPX Kent Moore J-35589-A
1988-1999, brakes, mushy, obs
