#776 |
Re: 61K10 build
Funny, I was gonna post up my sound floor covering i just put in, and a third set belt. Ya, why i didn't do it in the first place lol! Changed out my stock steering wheel for more room.
I like working on stuff as I'm retired. alway's been a gear head. will post up some pic's later, and thanks for the thumbs-up.
1961 chevy K10 my build is------------61K10 build |
#777 |
Re: 61K10 build
Kimble - I have read through your build start-finish. I admire your work and love the truck!
Several posts back and a couple of years ago, you mentioned finding bronze bushings to replace the hub needle bearing for a disc brake swap. Oilite 1-1/8id x 1-5/8od x 1". Can you verify the size of the bushing? According to Oilite that bushing is not standard size and needs to be custom made, but it looks like you found the bushing on ebay. Thank you!
Brett | 1966 K20 - 292/SM420/T221 |
#778 |
Re: 61K10 build
I posted wrong? I think maybe oilite ff1618-01 flange 1-3/8 x1-5/8 x1- flange is 2"" od and 1/8" thick. I have another complete new set as the ones i installed on my axle were all used except rotors. I will remeasure and post up
#779 |
Re: 61K10 build
the prior post is the right part #. you can turn down the stub axle shaft a few thou and use the needle bearings. I wanted to go back to 100% stock if need be.
#780 |
Re: 61K10 build
just a little up-date about the sound mat stuff. It does have a smell and it's not sweet lol. hope it will air out this spring as it's been shut up.
#781 |
![]() Join Date: Mar 2013
Re: 61K10 build
I'm excited to retire and go into full time restos........40 years from now.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#782 |
Re: 61K10 build
TJ--You have a good start on all the knowledge required lol! I assume your new job will help also. I started like you when i was young and it's a never ending learning experience. Never too old to learn something new or a better way to do something.
How's your new job? Take care----------kimble
#783 | |
Re: 61K10 build
Thought I had my career path chosen, but I may be doing something else soon. Hard to make large purchases wondering if your gonna get laid off or fired everyday. haha Now thinking of fire department or getting a diesel tech associates and getting into semi trucks. ![]()
#784 |
Re: 61K10 build
Hey 61K10 I really like the truck man!
What cb radio is that you have in there? Looks like a newer radio shack but I could be wrong?
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
#785 |
Re: 61K10 build
Hey TJ! You need to make a video of your new truck!
#786 |
Re: 61K10 build
St6guy--good eye. It's a R/Shack 40 channel? can't remember. It's not working as my cable to my old wip mount doesn't fit. I'll get to it someday lol.
#787 |
Re: 61K10 build
Yea I'm really into the radio thing and when I see radios in other peoples trucks they really catch my eye LOL.
I'm all so a big fan of all most every thing radio shack sold. It's to bad they are not really around anymore. ![]() I got a realistic trc 427 in my 98 c1500 and a trc 473 that's going to replace the midland in my 65 c20 sometime soon. ![]()
#788 |
![]() Join Date: Oct 2013
Re: 61K10 build
Kimble,
What is new with you and your truck? I have gone and purchased another 1966 GMC 4WD Suburban, with a lot of great help from a friend who found it. He also has totally facilitated the purchase. Les |
#789 |
Re: 61K10 build
Hi Les, just saw your post. Another haha. You have enough projects already. Glad you saved another one. Not much with my tk. Bough another trans (67 420) has the reverse sw in the shifter plate. Feels like it has a shorter throw, probably not but it shifts smooth. Now just need enough ambition to switch them out.
take care Les----------Kimble
#790 |
Re: 61K10 build
Kimble,
66 GMC Suburban, just arrived this week, friend brought it to me, needs work. Been resting since 1993 or 95 outside, with front clip off. It has 25 plus years of dirt on it. Drive train/suspension looks to be original, body modified for big A.. tires. Thinking will start out keeping Dana 44 Closed knuckle 3.54 GMC gears. Any suggestions on maintenance to conduct before driving? Rolls very easy. Just starting to check it out. First goal is to get it driving as, before any major mods. Photos Apple sideways. Les Last edited by aotte1; 05-18-2020 at 02:01 PM. |
#791 |
Re: 61K10 build
pretty nice Les--get it safe first as you know. Maybe change the axle oil and ck wheel bearings. Just depends if how much you're going to drive it. Hows the rest of your projects?
I found a nice vacuum gauge for mine so dash gauge panel needs to come back out. kimble
#792 |
Re: 61K10 build
Kimble,
Nice find on the vacuum gauge, will look nice. Any thing lubrication wise, need to do on the closed knuckles. Looks like their may have been a type of seal covering the inner part of the closed knuckle? My other project are move slowly, some faster then others. Many of them are resting currently. They are all completed pretty much except for the body parts. The 66’ C20 CC is furthest along body wise. Les |
#793 |
Re: 61K10 build
Les on the closed knuckle make sure there is lube in them and run it in 4wheel to lube the knuckle bearings. There is gaskets on the knuckle itself, kinda like a wiper, most weep. That should get you started.
kimble
#794 | |
Re: 61K10 build
