02-02-2019, 01:20 PM | #376 |
Re: "Crewcab Jake" the 84 to 74 conversion
Haha, nope. Just realizing that most of my task lighting is previous century technology. Chassis is looking good! Your systematic approach always wins out. Have a good weekend.
02-02-2019, 11:58 PM | #377 |
Happy to be here
My late night session was productive. I got the passenger side of the frame and crossmember painted and ready to finish the suspension installation.
We installed the Ridetech lower control arm and hung the coilover shocks in place.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-04-2019 at 10:58 AM. |
02-03-2019, 12:08 AM | #378 |
Happy to be here
With the tubular A arms in place we could hang the spindle. Ridetech uses the CPP modular spindle as part of their kit. The modular design allows stock rotors and calipers to be used.
I plan to upgrade to bigger rotors and calipers in the future. I can make those changes without changing the spindle.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-04-2019 at 10:59 AM. |
02-03-2019, 12:12 AM | #379 |
Happy to be here
I cleaned and painted the C10 brake rotor and caliper that I'm running for now. I added new soft lines to ensure everything was at it's best. I had to cut the hardline to get the C20 brake line free. I'll pick up new fittings and flare the line to get back in business
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-04-2019 at 11:00 AM. |
02-03-2019, 12:27 AM | #380 |
Happy to be here
One side down and one to go. The drivers side is the "wet side" due to oil and power steering leaks. Consequently the layers of grunge were much thicker.
The old crossmember bracket was the first thing to attend to. I worked through the layers of nasty and sheared the rivets off.
02-03-2019, 12:31 AM | #381 |
Happy to be here
I bolted the new bracket in place so I could get an accurate scribe line. The mock up is crucial to getting an accurate scribe line.
02-03-2019, 11:06 AM | #382 |
I read through all 16 pages last night. Like always, very nice job. The one thing I was really curious about was the whole sponsorship thing. I won't ask about that though, as you already addressed. Your work makes me want to get a squarebody
02-03-2019, 04:43 PM | #383 |
Happy to be here
thanks for following along. Your support and input is what keeps me motivated.
02-03-2019, 09:36 PM | #384 |
Happy to be here
Before I shut down last night I put a coat of paint on the frame. The bottom side of the crossmember was really nasty on this side. The section from the body mount to the suspension is good to go now.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-04-2019 at 11:02 AM. |
02-03-2019, 09:52 PM | #385 |
Happy to be here
Chris and I got an early start today. We realized the steering box had to come off. The frame on this side was a wet oily mess that had to be stripped. It took a lot to work my way through it.
I'm glad we did it because I discovered the power steering hose from the pump was loose. I have several leaks to chase down . I may have eliminated one from the long list.
02-03-2019, 10:07 PM | #386 |
Happy to be here
With a few coats of Krylon covering everything, it was time to get the drivers side put together. The crossmember brace goes on first. The upper arm comes next.
02-03-2019, 10:21 PM | #387 |
Happy to be here
The lower A arm comes next. The factory U bolts hold them in place. They take two nugga, nuggas to get tight.
The coilover assembly can be hung in place. Ridetech uses Fox brand adjustable shocks wrapped with a coil designed specifically for the application.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-04-2019 at 11:03 AM. |
02-03-2019, 10:25 PM | #388 |
Happy to be here
Now that the arms are hung, the CPP modular spindle comes next. The modular spindle narrows the track width to help tuck taller tires.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-04-2019 at 11:04 AM. |
02-03-2019, 10:28 PM | #389 |
Happy to be here
While waiting for parts to dry decided the front frame brace needed some love. Heres what I started with
02-03-2019, 11:43 PM | #390 |
Very nice. What did you use to clean the left side frame rail? It came out looking new.
02-04-2019, 01:09 AM | #391 | |
Happy to be here
After that I wipe clean with brake cleaner and scuff it down with Scotch Brite pads. One last wipe before I cover with primer or paint.
02-04-2019, 01:11 AM | #392 |
Thumbs up...
02-04-2019, 09:53 AM | #393 | |
Garage wrench
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
02-04-2019, 11:10 AM | #394 | |
Happy to be here
Despite my skepticism about the primer built in, it does work on raw metal. The key to getting a good finish on any paint job is prep. I sand and scuff the surface it ensure adhesion. I also feather out any rough edges on existing paint.
02-04-2019, 10:43 PM | #395 |
Happy to be here
I love it when I can access a panel to clean it up. The front cross brace and bottom of the core support fit that category. I was able to clean those panels and the inside of the frame rails fairly easy. I'll pull the bumper and get the end section of the frame rail once I get new brackets.
02-06-2019, 11:11 PM | #396 |
Happy to be here
The past two nights my work schedule hasn't allowed me any shop time. Tonight I went straight to the shop and got started.
The steering box, and drag link had a good half inch of grease caked on them. It took a couple of hours with the wire wheel, Scotch Brite and brake cleaner to get the parts clean. After a blast with the pressure nozzle I wiped the parts clean and prepped for paint. I decided to go with VHT Cast Iron on the pieces to have a bit of contrast.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-08-2019 at 12:54 PM. |
02-07-2019, 11:41 PM | #397 |
Happy to be here
This morning before loading my truck for the day, I put final coats of paint on the steering box. Chris stopped by on his way home from work and hung the box in place.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-08-2019 at 12:55 PM. |
02-07-2019, 11:51 PM | #398 |
Happy to be here
I got home later and followed his lead. I hung the remaining steering linkage and tie rods. I cinched all the castle nuts down and aligned the cotter pin holes.
02-07-2019, 11:57 PM | #399 |
Happy to be here
With the steering linkage in place I turned my attention to a shipment that came in today. I had ordered a set of hood hinges from Eddie Motorsports.
This is my second set and once again these are a work of art.
02-08-2019, 12:16 AM | #400 |
Happy to be here
Ok, fun was over now it's back to work. Farmer Fred didnt check any option boxes when he ordered Crewcab Jake. Its going to be my mission to correct that.
One option I always add to my builds is a tilt column. Its amazing how one or two clicks of a tilt column can improve driving comfort dramatically. The exterior had years of grime to clean off and at some point it had been repainted flat black. I stripped it to the core and started over.
