01-19-2019, 11:52 AM | #51 | |
Re: Blazer got some color today
I ordered them through Summit. Hopefully they will be ok.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
01-19-2019, 12:04 PM | #52 |
It has worked out pretty well. Much easier on the feet and legs than standing on concrete. I've pulled and installed several motors and the cherry picker has not ruined any tiles. I have ruined a couple though and they can be changed out in a minute. Mine have the open type weave and fluids will go underneath to my drain. Little tiny parts, if you drop them, are probably lost for a decade, especially if they are stainless and non magnetic. They can be cleaned up with just about anything. I use a mop and strong mixture of spic and span or Awesome. You can even use paint thinner or brake cleaner on it and it won't be hurt. If I ever move, I can take it up and take it with me if I wanted to do so. I don't leave a jack stand sitting with a vehicle's weight on them without some plywood underneath as the legs on my stands are too sharp and they will cut into the tiles after awhile (that's how I ruined a couple tiles).
01-19-2019, 12:07 PM | #53 |
Looking D@mn Good , I'll wait to see this done.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
01-19-2019, 02:11 PM | #54 |
It is the only time in my life that I have driven 85 MPH on ice and snow, with the clothing they now provide it is rather comfortable
01-22-2019, 08:30 AM | #55 |
Well, one of the four drums arrived from Summit. It doesn't have the knockout on it for brake adjustment. The other 3 are due tomorrow. Their customer service indicates that they will take care of me. I will see. In any event, finished up the rear brakes, installed new shocks, and a new steering damper cylinder.
01-29-2019, 08:12 AM | #56 |
I ended up drilling and filing adjustment slots in the drums. Brakes finished. Drained transmission, transfer case, and both differentials and filled with new lube.
01-29-2019, 09:01 AM | #57 |
Ran into the same problem with my drums, didn't think of drilling, just kept beating on the slots, they finally gave way, with a BFH
Truck looks awesome with the detail of assembly Looks like you figured out the problem with the union on your rear brake lines
01-29-2019, 01:53 PM | #58 |
Thanks Jim. I couldn't even find drums that had the knockout stamping outline in them anymore. Had a "technical expert" at Summit tell me just adjust them from the back. At that point I decided to ship them back on their dime and order a different brand (Summit's were Bendix) through Advance. They too didn't have the knock out stamping in them so I just gave up and made my own adjustment slots. I had previously checked with my local NAPA and they had some drums, which may or may not have the stamping, but were located at the manufacturer in Kansas City ( I think). So if I wanted to pay the shipping and twice the price of Summit's or Advance's drums, I could order them - not. As to the union, I changed copper washers and ground down their diameter slightly so they would fit into the very very slight recess on either side. Time will tell but so far, so good. If I could have found the thicker washers like were used when it was built, I wouldn't have run into this problem. Aftermarket copper washers are less than 1/2 the thickness of the originals.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 Last edited by rsavage; 01-29-2019 at 02:00 PM. |
01-30-2019, 01:02 AM | #59 |
Looking good!
Jeff 1972 Blazer CST 2wd- My son Sam's Project "S" Project "S" 1970 Suburban - SOLD "One Bad Burb" Photobucket Album 1986 C30 Crewcab - 63K original miles, original paint Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP... |
01-31-2019, 01:10 PM | #60 |
Looking great!!!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
02-01-2019, 07:01 AM | #61 |
Thanks much.
02-06-2019, 08:34 PM | #62 |
Put most of the dash together, got the tires mounted and balanced. Mickey Thompson Degan 38 tires, sized 32" X 11.50" X15 on series 62 wheel vintiques 8" X 15". Haven't decided if I am going to run them bare or with hubcaps.
02-07-2019, 01:22 AM | #63 |
The truck looks great! Love the rim and tire combo.
02-07-2019, 07:42 AM | #64 |
Thanks much. Probably going to be pretty noisy.
02-07-2019, 09:48 AM | #65 |
Proprietor of Dale's Corner
Looks great, a little noise never hurt anybody.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
02-07-2019, 10:27 AM | #66 |
That front brake line looks a little tight, do they have anything longer or is your suspension flexed all the way out? Just seems a little short. Um...awesome job by the way!!
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
02-07-2019, 10:59 AM | #67 |
Ski-me,
That's hanging from my lift. Those are standard length and I believe it has a 2" spring lift from a previous owner. May have to change them out again. Once I fire it up, I'll move it to a place where I can flex the suspension each side and see where I am at.
02-08-2019, 01:12 PM | #68 |
Keep the top off and the tire noise won't even register!
Ton's of fun every time I drive mine around! Wil
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
02-13-2019, 07:50 AM | #69 |
I bought a softopper for this one as I had one previously on my 71 Blazer and really liked it. I could roll up the side and rear windows and had the open air feeling while keeping the sun from baking me and the seats. The original top is hanging from the joists in my barn and I have no intention of restoring it but will keep it.
02-13-2019, 10:53 PM | #70 | |
So, I decided to never put my hardtop on! Wil
02-14-2019, 02:49 PM | #71 |
Looks GREAT! Best stock color by far, great choice.
MCB - Matt's Classic Bowties 5360 Gateway Plaza Dr. Benicia, Ca. 94510 925-828-5555 www.mcbparts.com Email: forums@mcbparts.com Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts Hours: Monday to Friday 8am - 4pm Pacific We ALWAYS enjoy talking to our customers! We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking! |
02-15-2019, 07:21 AM | #72 |
Thanks much Matt.
