Old 02-09-2019, 10:04 PM   #1
Jennandrand
Info on passenger bucket seat lift lever
Installing utility buckets that PO had removed in favor of a bench...all the holes line up, no problem. Then I notice that because the seat folds forward, there are no fasteners holding the rear of the seat down. The lift lever and spring are present on the back of the seat, but appears to be missing part of the mechanism because the lever doesn’t disconnect the seat from anything and there’s nothing putting tension on the spring, it’s just sitting in a bracket. Will post pics of my own seat tomorrow, the pic below is a reference to show the lever I am referring to. Any insight as to what this is supposed to look like?
Jennandrand is offline   Reply With Quote
Old 02-09-2019, 10:11 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Info on passenger bucket seat lift lever
There s/b a bracket bolted to the floor, with a hole in it to latch the lever that is bolted to the seat. I'll try to post up a pic tomorrow
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-10-2019, 02:56 AM   #3
Classic Bowties
Always on the hunt...
Could the missing/needed floor bracket be the below type circled in red? Mel
Classic Bowties is offline   Reply With Quote
Old 02-10-2019, 08:41 PM   #4
Jennandrand
I assume that the bracket mounts to the floor so that the pointed piece (circled) sits in it. So what does the lever connect to?
Old 02-10-2019, 08:43 PM   #5
Jennandrand
Here are photos of my actual seat. One shows the spring mechanism, obviously missing some kind of part. What does the lever actually release from?
Old 02-11-2019, 12:35 AM   #6
Landondale
Looks like you’re missing the pin that actually locks the seat down. It’s circled in the pic above. It is linked to the lever and is under spring tension. It sits perpendicularly to the pin that you have circled. Once the vertical pin is in the floor bracket, the one you’re missing latches under the floor bracket locking the seat in place.
Landondale is offline   Reply With Quote
Old 02-11-2019, 10:42 AM   #7
mister.freeze
mister.freeze's Avatar
I have all that... PM.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 02-11-2019, 05:12 PM   #8
Landondale
It is missing the pin that runs through the spring that is attached to the lever via compression pin. It latches in the side of the floor mounted pice to secure the seat in the closed position.
Old 02-11-2019, 05:17 PM   #9
Jennandrand
AHHHH ha. thanks for the pics....now to find the parts!
Old 02-11-2019, 07:36 PM   #10
Classic Bowties
Here are a couple more pictures of two different passenger side 71 K/5 utility bucket rear bracket setups for you to check out. Mel
Old 02-11-2019, 08:52 PM   #11
Jennandrand
In case I need to figure out a way to reproduce this...so there is a rod running through the spring (circled)? If I were to make the part, could I just make it a pin that runs through the spring inside the bracket, or is the rest of the rod on the end functional somehow?
Old 02-11-2019, 09:52 PM   #12
1rippen6
Look at post #7 mister_freeze says he has everything to pm him. The rod has a loop so you can release it from the side and don't have to reach behind the seat.
1rippen6 is offline   Reply With Quote
Old 02-13-2019, 02:04 PM   #13
mister.freeze
mine is like post #4 without the loop
Old 02-13-2019, 07:00 PM   #14
YoungPup1977
[QUOTE=mister.freeze;8463510]I have all that... PM.[/QUOTE
I have some too... 5 sets
YoungPup1977 is offline   Reply With Quote
Old 02-13-2019, 10:40 PM   #15
Classics Fan
So does anybody know what year or option came with the seat release lever with the hoop, allowing the seat to be released from the side? That’s a nice feature. My 71 Jimmy Super Custom doesn’t have it.
Classics Fan is offline   Reply With Quote
Old 02-13-2019, 11:17 PM   #16
1rippen6
I think all utility buckets had them sport buckets don't.
