02-09-2019, 06:32 PM | #1 |
SM465 with M10x1.00 thread for shift knob?
Original shift knob was aluminum and half jammed on when I bought the vehicle.
Shaft measured 0.374 and thread looked very fine so I bought a 3/8-24 nut to test fit. Did not fit. So I bought a couple of metric nuts: one was labeled M10x1.25 and the other was labeled M10x1.00. The fine threaded one fit perfectly. Now I cant find any shifter knobs with an M10x1.00 thread. I'm now wondering of the hardware store bin was mislabeled or if I do really need the M10x1.00 and they are just hard to find. Any ideas? I have a proper thread gauge somewhere and may need to dig it out.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
02-09-2019, 09:04 PM | #2 |
Re: SM465 with M10x1.00 thread for shift knob?
You can probably run a tap into the existing knob and clean up the threads.
I did that with my MY6 shift knob. The shaft was fine thread and the replacement knob (a transfer case knob) was coarse thread . Ran a tap in it with no problem. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-09-2019, 09:05 PM | #3 |
Another option would be to drill the threads out and use the appropriate heli-coil insert.
K
02-09-2019, 11:06 PM | #4 |
Never seen a metric 465 shifter
02-11-2019, 12:22 PM | #5 |
Thanks, guys. Maybe just I'm fooling myself with the M10x1.00 nut. Its dimensions are so similar to the 3/8-24 that it's not even funny. And maybe with a little more chamfer clean up the 3/8-24 will fit.
02-11-2019, 12:28 PM | #6 |
A thread gauge is what you need...that 10mm is larger than 3/8...that may be why it threads on so well.....
get a 3/8-24 die and chase the threads and you should be good...
02-12-2019, 11:33 AM | #7 |
I love this board. Excellent info.
I was concerned that if someone had swapped in a newer SM465 it might have had some metric in it, but based on your info and guidance I'll run a 3/8-24 die down the threads. I would have hated to risk doing that if it were really a metric or vice versa. I think I might already have one in my tool box. I bought a bunch when our local hardware store (OSH) went out of business.
02-18-2019, 01:33 PM | #8 |
Thanks for your help, guys!
I ran the 3/8-24 die down the shifter threads this weekend. I was careful to keep it perpendicular, which was kind of hard. It felt a little tight at first and then got easy the rest of the way down. Then I was able to spin a 3/8-24 nut up and down the threads with ease. Then I ordered a proper round shifter ball. eBay even had one with the correct SM465 shift pattern. I hope the quality is ok, because sometimes eBay is sketchy.
02-18-2019, 06:17 PM | #9 |
sweet...glad it worked out for ya
02-23-2019, 02:43 PM | #10 |
All is well. Glad I could find one with the shift pattern because I plan to teach family members to drive a stick with this truck.
02-26-2019, 09:29 AM | #11 |
A little late to the party but glad it worked out.
I had the same problem some years back when I was adding a lawn mower piston as a shift knob on an old mud truck. I fitted the 3/8 nut to the underside of the piston and then it did not work. Like you, I ended up chasing the threads and then it worked like a dream. Scott |
