Old 09-03-2018, 10:02 PM   #751
Akuzaspur
Re: What did you do to your Blazer/Jimmy today?
Installed my softopper top.
Akuzaspur is offline   Reply With Quote
Old 09-04-2018, 12:35 PM   #752
Haggar
Finally added a stereo to the Jimmy. Put a retrosound unit (Hermosa, I think) in the dash. It's too shiny, so I'm going to try to maybe cut off/use some of the faceplate from the original radio dial to cover it.
My Jimmy didn't have any speakers or interior panels when I got it, so I made up some quick rear panels from some scrap 1/4" plywood that I had. I built a heavier 1/2" plywood structure behind them to house the 6x9 JBL speakers, and covered everything in grey felt. I put some aluminum angle behind them, which is riveted to the floor to support the bottom edges.
While I was in there, I also put some some sheets of sound deadening, and then more felt over the wheelwells. The previous owner put in some bedliner which was really scratchy, and rocks hitting the wheelwells were really loud, this improved both situations.
I put in a 12" Sundown SA-12 in a box that I build behind the seat, and a couple amps under the back seat to drive it all (An old Sony xplod 50w x 4 for the front and rear speakers, and a MTX1000.1 for the sub).
I got the typical plastic kick panels for the front, which were kinda ugly. I had to space the speakers outward so I routed up some MDF rings, added sound deadening to the plastic, and then covered it all with the same felt. Matching GTO series JBL component 6.5s up front. It all sounds great, and can completely drown out the wind and motor noise at any speed
Haggar is offline   Reply With Quote
Old 09-04-2018, 05:15 PM   #753
ochre1971
ochre1971's Avatar
Nice work.
ochre1971 is offline   Reply With Quote
Old 09-10-2018, 10:46 AM   #754
jeffg1010
jeffg1010's Avatar
Installed some trim and turn signals so I can get it on the road.
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 09-19-2018, 03:07 PM   #755
billthompson
fiberglass....lots and lots of fiberglass
billthompson is offline   Reply With Quote
Old 10-07-2018, 09:59 PM   #756
3757chevy
3757chevy's Avatar
Drove to look at fall colors.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 10-30-2018, 09:28 PM   #757
raggedjim
raggedjim's Avatar
Jeff, are you sure those headlight bezels are mounted right? Something looks off to me...
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 10-30-2018, 09:29 PM   #758
mister.freeze
mister.freeze's Avatar
Wrong sides AND upside down?
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 10-30-2018, 09:33 PM   #759
raggedjim
raggedjim's Avatar
Not sure, but not right...
Roger
'70 GMC Jimmy 2wd
Old 11-01-2018, 03:38 PM   #760
SoCoC10
SoCoC10's Avatar
Pulled the carpet out of the Highlander to inspect the floors. Found the carpet was original with the carpet tag in tact. The leveling mats are there in good shape and the floors are in much better condition than I was anticipating.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 11-01-2018, 05:52 PM   #761
Chulisohombre
Chulisohombre's Avatar
Very cool
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 11-01-2018, 06:04 PM   #762
lks dcvn
lks dcvn's Avatar
^ Always a nice surprise to see things in better shape than they should be.
lks dcvn is offline   Reply With Quote
Old 11-06-2018, 06:08 PM   #763
jeffg1010
jeffg1010's Avatar
Really? Um ... maybe? They seemed to fit that way but the front clip isn't lined up so I'll have to check it out further.
Jeff
Old 11-08-2018, 11:12 AM   #764
raggedjim
raggedjim's Avatar
I think Freeze is right, swap sides and flip 180... The more rounded corners should be on the upper outside corner of each light.
Rg
Roger
'70 GMC Jimmy 2wd
Old 02-08-2019, 08:35 PM   #765
Green Monster
Green Monster's Avatar
Addition for the glove box... ideal for convertible season.
Green Monster is offline   Reply With Quote
Old 02-17-2019, 08:55 PM   #766
3757chevy
3757chevy's Avatar
That is cool . Where do I get one?
MIKE
Old 02-17-2019, 08:56 PM   #767
mister.freeze
+1!
Old 02-17-2019, 09:08 PM   #768
simicrintz
I'm bald and I want one
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 02-18-2019, 07:23 PM   #769
SoCoC10
SoCoC10's Avatar
Rescued from paint jail...
Old 02-23-2019, 02:08 PM   #770
Dale99
Soco, what tire and lift combo? Cause that's the same color as mine.
I installed new leaf springs while waiting on finding/paying/shipping a replacement rear axle.
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 02-24-2019, 03:36 PM   #771
CO71Blazer
Drove her to work, like I do every day.
CO71Blazer is offline   Reply With Quote
Old 02-25-2019, 12:11 AM   #772
3757chevy
3757chevy's Avatar
Installed a new Steering wheel after dismantling my upper column for cleaning .
MIKE
Old 02-25-2019, 08:28 PM   #773
BIG BLOCK JIMMY
BIG BLOCK JIMMY's Avatar
Installed a DIY4x crossmember, but I lied because I did it yesterday....
72' JIMMY 454
BIG BLOCK JIMMY is offline   Reply With Quote
Old 02-26-2019, 03:40 AM   #774
Chulisohombre
I looked at my blazer all sad in the garage. Alas all I did was wish for nice weather again so I could get her out of her winter cave and into the sunshine again.
Old 02-27-2019, 02:12 AM   #775
3757chevy
3757chevy's Avatar
Went to the hardware store and stopped by the car wash then took a little drive.
MIKE
