Old 05-26-2018, 07:12 AM   #76
jjzepplin
jjzepplin's Avatar
Re: I Found the Magic Button!
Did you mean "Castor" is as positive as it can be?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-26-2018, 09:39 AM   #77
shortbed70
shortbed70's Avatar
Alrighty I’m going to see what I can do Tuesday.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-26-2018, 10:35 AM   #78
BMERDOC
BMERDOC's Avatar
Yeah. Caster needs to be as positive as possible.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 02-20-2019, 01:18 PM   #79
2500HD
2500HD's Avatar
I just completed a steering rebuild (rag joint, pitman, idler, ball joints, tie rods, upper and lower control arms, Red Head quick ratio box, pump, wheel bearings and tires) and had the truck aligned. i now have a lazy return to center and while driving straight it seems kind of twitchy. I have a lot of caster so i dont understand the lazy return to center. Is the toe supposed to be toe in or out?
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline   Reply With Quote
Old 02-20-2019, 01:21 PM   #80
2500HD
2500HD's Avatar
Early Classic 4.5/6
Old 02-20-2019, 01:43 PM   #81
BMERDOC
BMERDOC's Avatar
Going down the sheet in order, I would like to see a bit more camber. -.25° would make me happier but if you can't get there you can't get there. I question the frame angle. If its really 2° thats fine but if its closer to 0 (mine was 0) then your caster angle numbers are going to be off by the sum off the difference. Since its front steer it needs toe out. I would rather see 1/8" total (1/16 per side).
Nick Carter
Old 02-20-2019, 01:52 PM   #82
BMERDOC
BMERDOC's Avatar
I think I need to expand on that a bit more. Your toe and camber angles are a bit on the neutral side which would cause those angles to flip back and forth between positve and negative. You've gotta push them a tick more to make them stay in the range they need to be in. Confirm that frame angle was actually measured and not guessed at to confirm caster.
Nick Carter
Old 02-20-2019, 03:15 PM   #83
Steeveedee
Who Changed This?
Steeveedee's Avatar
Isn't it toe in for RWD?
As for the lazy return, how is steering force when you turn the wheel away from center? Could just be the box sector lash adjustment is too tight.
~Steven
Simi Valley, CA
Old 02-20-2019, 04:06 PM   #84
BMERDOC
BMERDOC's Avatar
Its more about front vs. rear steer (in relation to the front cross member) but for the sake of packaging you can assume most FWD will be rear steer therefore requiring toe in. Its all about keeping the steering linkage taut.
Nick Carter
Old 02-20-2019, 06:34 PM   #85
2500HD
2500HD's Avatar
Not sure about the frame angle. it does have a pretty good rake to it if that is what is meant.
Just so i understand, if the caster is 5.9 and the frame angle is 2 then my actual caster us 3.9?
I need .5 more camber (top of tire in / \) and 1/32 more toe on each side (front of tire out \ /) and as much caster as possible?
Early Classic 4.5/6
Old 02-20-2019, 06:44 PM   #86
2500HD
2500HD's Avatar
Steering force away from center is not hard at all but it does have a new Red Head quick ratio box that makes it a little stiffer. Not stiff but not pinky steer as it was before. I cant change the box for as the paperwork clearly says it is adjusted perfectly and it will void my warranty.
Early Classic 4.5/6
Old 02-20-2019, 07:05 PM   #87
BMERDOC
BMERDOC's Avatar
I would verify frame angle or at least ask the guy that aligned it. Your math is correct...sorta. If your frame angle is 0 and they plugged in 2* the printout would say 5.9* when its actually 3.9*.
-.5 camber is good (tops of the ties pointing in). 1/16 toe per side (1/8" total) for toe.
Nick Carter
Old 02-20-2019, 08:47 PM   #88
zicc1835
zicc1835's Avatar
funny I had my tires mounted and balanced yesterday at the shop i will have do my alignment at some point I discussed doing the alignment one of the mechanics there is ready to retire he and I went to the same school he is old school but is up to date with the newer technology this is going to be very helpful for me thanks so much for the info i gotta try to get it all together before he heads south
zicc1835 is offline   Reply With Quote
Old 02-21-2019, 12:17 AM   #89
Steeveedee
Who Changed This?
Steeveedee's Avatar
IMO, if the lazy return to center doesn't go away within the warranty period, I'd be talking to the builder...before the warranty is up. A billion+ vehicles have not had this problem,when new. I think that something is wrong with it. The paperwork saying that it is "adjusted perfectly" is just that, paperwork. I hope that the steering starts returning to center normally.
~Steven
Simi Valley, CA
Old 05-24-2019, 11:04 AM   #90
MySons68C20
MySons68C20's Avatar
Did you ever get the return to center figured out? I'm having the same problem with the 68 with all new parts including a quick ratio Red Head steering box. I'm going to get my 2nd alignment at a different shop next week and want to be ready.
The first shop wouldn't/didn't give me numbers. The only thing I see is 1 1/8" shim on the pass side and a 1/16" shim on the driver side.
MySons68C20 is offline   Reply With Quote
Old 05-24-2019, 08:10 PM   #91
Robznob11
Robznob11's Avatar
The return to center could be the lack of positive caster and not the box, you can trust very few alignment shops with these trucks, they dont want to take the time to unbolt add shims, tq it back up, and repeat several times getting it perfect. They usually take one stab at it and say ahhh it's good enough, many just set toe and take your money....I can tell you because I do my own alignments....it takes several hours to dial one in. Every time you Jack it up you have to reload the suspension (move the vehicle) or you will get a false reading.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-24-2019, 11:15 PM   #92
2500HD
2500HD's Avatar
No not really. i had the same guy do the alignment again. and it is better but not great. it starts to return to center and then stops about half way back. i think i need more camber to get the tires more straight up and down. i have minimal shims in the front and none in the rear. Please let us know if you get it figured out. i will not be working on the front for some time. i currently have the rear out for rear control arm bushings, Eaton posi and 3:73 gear.
Early Classic 4.5/6
Old 05-25-2019, 03:19 PM   #93
Rooster73
it ,kills me when someone comes in and hands me a sheet for the factory specs on an old ride. biasply then and radial now. 3 degrees positve was alot with biasply, these trucks with radials want at least 4 to 4.5 pos. setting camber and caster is no big time deal. all aligners the last 10 years use live caster readings and can compensate for elevated readings. i always rerun caster swing after adjusting, just a double check. rear shims effect caster more, front shims effect camber more, keeping less than a 1 degree split, more caster on right.any change in ride hieght changes all. there are so many measurements that effect how it drives, SAI, setback, thrustangle, along with camber, caster and toe.even a 20 thousand dollar Hunter aligner ends with a wrench and a brain. sorry for the rant, but after 30 years of frontend work i hear to many techs say set the toe and let it go. they should be sweeping floors.
Rooster73 is offline   Reply With Quote
Old 05-25-2019, 05:45 PM   #94
MySons68C20
The only shims are in the front.....none in the rear at all. I have an appt on Wednesday and we shall see. The good thing is the guy said it may take him a couple hours to get it done. I like the fact he's willing to take the time to do it right and give me the dang print out!
Old 05-26-2019, 01:07 AM   #95
hjewell2
hjewell2's Avatar
subd
hjewell2 is offline   Reply With Quote
Old 05-26-2019, 09:38 AM   #96
jjzepplin
jjzepplin's Avatar
Thank you! Can I bring my truck to you for an alignment?
Old 05-26-2019, 04:49 PM   #97
MySons68C20
Thanks for replying, I'll let you all know how it goes come Wednesday.
Old 01-01-2020, 04:27 AM   #98
2500HD
2500HD's Avatar
Any update MySons
Early Classic 4.5/6
Old 01-01-2020, 06:27 PM   #99
MySons68C20
The new alignment didn't change anything.....it still won't return and the alignment shop tech said its in the box. I need to pull the pitman arm and see if there is a bind in the ball joints or?
Sorry for the late reply and Happy New Year!
Old 01-01-2020, 06:50 PM   #100
Rooster73
If it were mine I would bust the outer tierod off the spindles and feel the ball joints for any stiffness or catches, kinda like checking u joints. Not saying anyone messed up but a ball joint can be ruined while pressing it in, especially the lower. Happy new year
