12-15-2016, 03:08 PM | #126 |
Re: Factory Correct Restoration Details
TTT for this one. Anyone have some info/input on frame sheen? What about rearends? I have a 68 that I'm getting ready to tear into and I want it to look exactly like it rolled off the assembly line in 1968
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
12-15-2016, 04:09 PM | #127 |
My 69 late year has 12 pointers on the latch
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2005 Silverado 2500hd(tow pig) Made in the USA, just like my trucks |
12-15-2016, 04:13 PM | #128 |
Cool ad I picked up for a Christmas gift. Guess the frames were originally orange, who knew..
12-15-2016, 11:17 PM | #129 |
10-26-2017, 03:19 PM | #130 |
TTT, I was doing some research on factory inline 6 grease markings and decals without much luck. Anyone have photos of a low mileage straight six truck stashed away?
10-27-2017, 10:27 AM | #131 |
Subbed
1968 C10 292/3 spd - sold 1969 K10 350/3 spd/205 - sold 1971 K5 350/4 spd/ 205 - sold 1970 K20 350/350/205 - sold 1969 K20 396/400/205 - work in process |
10-27-2017, 01:25 PM | #132 |
Taking apart my 68 gmc the other day I found that the door latch mechanism was installed prior to painting. All other door guts appear to be added after
10-27-2017, 10:28 PM | #133 |
Seems there were some variances. My latch control screws were just black phosphate.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-28-2017, 11:33 AM | #134 |
Carpe manana
The door regulator screws I've encountered are all clear zinc and installed after paint. Same for the screws that secure the latch.
10-28-2017, 11:46 AM | #135 |
Most I have seen are that way. May be a gmc specific variance? Or maybe a plant specific variance?
10-28-2017, 12:53 PM | #136 |
Carpe manana
Could be - will keep eye out for other examples. Edp coating rather than paint under the painted screws would support factory install.
10-28-2017, 01:38 PM | #137 |
A few more pics
02-24-2019, 10:48 AM | #138 |
Reviving this thread for some additional info. Trying to narrow down what the oil fill tube and cap should look like on a 1968 327 intake. Looking at Steve’s posts earlier in this thread it appears all examples he showed have the zinc plated screw in cap (similar to a radiator cap) on the oil fill tube. I have an unmolested 67 with a 307 at my house now and it has the slide on (mushroom style) breather cap for the oil fill. Is this a 67-68 variance? Any experts out there? Picture of the 67 below.
02-24-2019, 11:13 AM | #139 |
Interestingly enough, while I can't claim the pics are of untouched originals, the first is a 67 and has the cap like your 67 - but all the others are 68s and have the other cap as you've mentioned. (the last one is Reggie Jackson's ) Anyway, at least based on circumstantial evidence, it does appear that the oil fill cap changed between 67 and 68.
02-24-2019, 11:45 AM | #140 |
Maybe this will be more definitive. 67 (pic 1) and 68 (pic 2) truck data book images of the 10-30 327. Seems good enough proof for me that your assumption is correct
02-24-2019, 12:16 PM | #141 |
Ive found for my 66 that factory installed PCV equipped engines had the flat cap and the round 'vented' cap is for non PCV applications.
02-24-2019, 03:39 PM | #142 |
Yes. In 66 67 if you got the closed pcv option you got the twist cap to seal the system and the pcv valve would thread into the oil fill tube. In 68 closed pcv became standard and the valve moved to the valve cover and the tube would have the twist cap but no pcv valve. 67 back standard draft tube would have the vented slide on cap
02-24-2019, 04:12 PM | #143 |
I have been reading this and though I am not doing mine any where near factory correct , I have noticed some things that are not factory correct for my year truck.
One is the arm rest , mine actualy came with 67 arm rests , it’s a 68 truck ( GMC ) I also have a 69 mustang , I converted to electronic ignition and of course needed to find that infamise pink wire ? I could never find it , what I found was a red and green wire in it# place and it came that way from the factory. I worked at Lansing mich Olds plant and I know before that line got shut down for parts shortage , they would use what they could . Shutting down a line meant money and that wasn’t going to happen. So you never know what kind of things they did to keep the line moving. |
09-30-2020, 04:41 PM | #144 |
I looked through this thread to get some restoration details. There were a couple of references to the both the Flint and Tonawanda engine plants. To help those that come to the thread, do not forget that these trucks may have engines built in other plants. My engine, for example, was built at the St Catherines plant.
If yours is the same and you are having trouble finding cast dates, check the passenger side of the block below the cylinder head. Hard to see if exhaust manifolds are in place and the numbers are upside down. |
10-06-2020, 01:15 PM | #145 |
SWB 4x4 Collector
Factory stencil on my 72' K20 frame.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
10-06-2020, 02:33 PM | #146 |
More factory stencil. Left front frame rail. 3999903 ??
10-13-2020, 08:35 PM | #147 |
Here’s one on my dads 72 Highlander
10-13-2020, 09:38 PM | #148 |
This is a Lambrecht image taken before any restoration work. I thought it would be good to show some un-molested details.
Some of the details I was looking for: Orange paint on black rubber oil filler plugs (I always thought mine had been painted by PO) White line on vacuum lines Partial routing on TCS Orange paint on spark plug wire clips Orange paint on thermostat housing No body color on clutch linkage block off plate Obviously there is a lot of other details. I have reached out to the current owner for more pre-restoration photos and Ill share should I get some. |
10-14-2020, 09:14 AM | #149 |
I have some vac hose with the white stripe on my truck as well.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-06-2021, 04:56 PM | #150 |
The part number stenciled on the frame on my 71 GMC 133" WB. (Longhorn)
