01-12-2019, 08:48 PM | #51 |
Re: New project : 72 Suburban
Had to make some repairs to the spare tire well before I started on replacing the right rear lower quarter
01-12-2019, 08:57 PM | #52 |
Fitted the new lower rear quarter and welded it up today
01-12-2019, 11:08 PM | #53 |
The Older Generation
Luckily you didn't have to go too far out to find good metal on the spare tub. Quarter is looking good. LockDoc
01-14-2019, 03:54 PM | #54 |
Truck looks really good. Are you leaving the paint alone and matching it the best you can?
01-14-2019, 10:52 PM | #55 |
Looking good!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
01-18-2019, 11:02 PM | #56 |
Yes, matching the white on bottom the best I can for now. Next winter I will probably focus on painting the inside and doing the interior. Then the next year start to get it ready for paint
02-02-2019, 07:57 AM | #57 |
Finished grinding down the lower rear quarter on the passenger side and shot a coat of rust preventer on, now it is ready for mud
02-02-2019, 08:14 AM | #58 |
Started on the rocker and floor repair on the passenger side. This is the worst section as far as rust on the entire vehicle. The post between the doors needs to be reattached but with a little fab work it shouldn't be to awful bad just time consuming
02-02-2019, 08:27 AM | #59 |
Inner rocker and cab support mount on passenger front are roughed in. This weekend with a little luck the A-pillar and fab work on front of the B-pillar should be complete
02-03-2019, 02:30 AM | #60 |
Looking good!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
02-12-2019, 10:13 AM | #61 |
low n' slo
looks good...any more updates?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
02-24-2019, 08:49 AM | #62 |
Had to fab a B-Pillar for the passenger front door
02-24-2019, 04:03 PM | #63 |
Inner rocker and some patch work in the middle are tacked in. A-Pillar has been installed so I can move on to fitment of the outer rocker
02-24-2019, 04:16 PM | #64 |
A small portion of the original rocker was still intact so I saved it and rebuilt that portion. Then I started to fit the truck rocker around it that the PO had already purchased for the vehicle to try and make it look somewhat factory
02-24-2019, 04:25 PM | #65 |
Made a patch for the front portion of the passenger floor section and it is now tacked in and ready to be welded
02-24-2019, 04:41 PM | #66 |
After fitting the rocker for the final time and installing the door I noticed it was off. So after taking a few measurements of the rocker and the bottom of the door, the rocker is 3/8 of an inch narrower than the door. I split the rocker and the PO also purchased a set of slip fit rockers as well so I trimmed the slip fit rocker to make up the distance, tacked it in place and checked it with the door for alignment. All looked good so I welded it in place and filled in the gaps where needed
02-26-2019, 04:29 AM | #67 |
Nice work. Thanks for sharing the pics!
03-03-2019, 03:31 PM | #68 |
Repaired a section of the inner panel behind the front portion of the right rear quarter panel
03-03-2019, 03:42 PM | #69 |
Repaired the lower portion of the right rear inner wheel well
03-03-2019, 04:03 PM | #70 |
Fabricated an A-pillar for the post on the third door
03-03-2019, 08:56 PM | #71 |
Looks good keep up the progress
03-04-2019, 12:41 AM | #72 |
Lots of work for sure. Looks good though, so keep plugging away on it... LockDoc
03-04-2019, 01:58 PM | #73 |
That is some nice fabrication work going on there!
03-09-2019, 09:31 PM | #74 |
Today I started on the inner rocker for the 3rd door. Used a passenger side inner rocker piece and shorten it down to fit the opening for the 3rd door
03-09-2019, 11:49 PM | #75 | |
Looks like that worked out pretty good after the mods. It's a good thing you are able to do this stuff yourself or you would have a ton of money invested in metal work.... LockDoc
