03-01-2019, 08:03 PM | #1 |
What is everyone’s favorite rust encapsulator?
I have used Bill Hirsch miracle paint and Por 15 in the past with varying success. I really want to coat hard to get areas and floors in the Blazer I’m doing. Any reviews would be greatly appreciated.
03-02-2019, 05:05 PM | #2 |
Re: What is everyone’s favorite rust encapsulator?
I’ve used por 15 as well. Seems to last if prepped correctly. I’ve heard it doesn’t hold up to sunlight without a topcoat.
Kirk 72 Blazer CST 4wd highlander |
03-02-2019, 09:38 PM | #3 |
That is very true, no UV protectant. I found out the hard way here in sunny south Florida.
03-03-2019, 05:04 PM | #4 |
I used rust x about a year ago on a frame. So far, so good but the truck has been kept inside too.
03-03-2019, 09:51 PM | #5 |
Thanks, I’ll look into that.
03-04-2019, 11:03 AM | #6 |
I've used with excellent success "Rust Bullet." As long as the metal is sound (i.e. large chucks of rust scale and dirt are removed with a scraper or wire wheel), I have not had it fail on any rust repair. It is nasty stuff. Once you open the can you have to use the whole can.
03-04-2019, 05:23 PM | #7 |
Thank you for the review. I have never heard of it and will look into that. That’s what I found out with miracle paint if you didn’t use it all at one shot. If you put the lid back on you can’t ever get it back off. So what I have done to combat that is put kitchen plastic wrap over the can and put the lid back on.
03-04-2019, 06:07 PM | #8 |
Here's good reading, although I don't have much experience here in calif.
https://garage.eastwood.com/eastwood...-vs-converter/ On the ships we used to just "pin-hole" the heavy rust with little pointed hammers and then apply phosphoric acid directly on after that. Did that help? I didn't think so, just running my fingers.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
