Old 03-06-2019, 01:23 PM   #326
Metaldoc
Metaldoc's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by 66clow View Post
Never ending sanding and body work. 😭
Confucius say " Paint job is only as good as the prep job."
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Old 03-06-2019, 05:19 PM   #327
cornerstone
cornerstone's Avatar
Originally Posted by zicc1835 View Post
maybe you and I are refering to the same thing Im talking about the blue apparatus you can barely see inside the bed , I have one that lifts the cab that you attach to the engine hoist(i have successfully moved my cab solo) Im wondering if there is something you can use to put inside the bed to lift with no damage ....looks like thats what he did/has /used??
This is what I used in conjunction with the hoist. It was 89 bucks through Northern tool.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-06-2019, 06:11 PM   #328
Metaldoc
Metaldoc's Avatar
No more hand cranks P/W and P/L done
Old 03-06-2019, 09:28 PM   #329
zicc1835
zicc1835's Avatar
very much appretiate your response Auto Body Tool Mart has them for 300.00 + didnt want to spend that much
thank you
zicc1835 is offline   Reply With Quote
Old 03-07-2019, 10:28 AM   #330
BugzC10
BugzC10's Avatar
Nice and clean....were are the window & lock switchs mounted?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 03-07-2019, 11:27 AM   #331
Metaldoc
Metaldoc's Avatar
Micro switches that control relays
Old 03-07-2019, 02:18 PM   #332
Chris_oz
Chris_oz's Avatar
Not so much to the truck....For the truck
20' wide x 30' long and 12'6" high under rafters.
Enough room for a 4 post hoist and the Chev
Roof and wall sheets go on this weekend if its not raining.
Chris_oz is offline   Reply With Quote
Old 03-07-2019, 09:52 PM   #333
weq92f
Cap, rotor and plug wires...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 03-08-2019, 09:29 PM   #334
SlowGreen71
Junior Member
Shortened her up a little and changed over to 73-87 style engine mounts. Still need to finish welding the inner sleeve and smoothing the cuts for the motor stands but it’s all in.
SlowGreen71 is offline   Reply With Quote
Old 03-08-2019, 10:48 PM   #335
89AKurt
89AKurt's Avatar
I took my "new" truck to the mechanic to check all the fluids, and look over everything. When the differential oil came out, I heard "oh $#it". So I took pictures today.
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 03-08-2019, 11:21 PM   #336
cornerstone
Is it trashed or can the spacer just be pushed in and make sure the tolerances are all in spec??
Nevermind, I found the answer on your personal thread... Thats a bummer.
Brian
Old 03-08-2019, 11:29 PM   #337
rjs53
Nice job!
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 03-08-2019, 11:29 PM   #338
89AKurt
89AKurt's Avatar
Yea, he just pushed it back in.
Sorry, couldn't resist. It was all taken apart, cleaned, new bearings, seals, and new brakes shoes because what was on was cracked, and all new spacers. I posted a series of photos on my thread.
1968 Long Bed
Old 03-09-2019, 10:35 AM   #339
BugzC10
BugzC10's Avatar
Bummer...could you hear the rear end singing when you drove it?
Old 03-09-2019, 11:17 AM   #340
89AKurt
89AKurt's Avatar
Not really, the transmission makes noise, there was water in the oil but no metal. Yes, when I was going downhill and turning right around curves, it howled. As you can see, the pinion gear was hitting the carrier (correct the terms if I got it wrong).
Here is a short video (on Facebook, sorry), showing how loose it was.
https://www.facebook.com/10000846199...4929899799056/
1968 Long Bed
Old 03-09-2019, 07:51 PM   #341
RodnRudy
RodnRudy's Avatar
Yanked the engine out of Old Red today to hopefully solve a vibration problem I've had since I put the crate GM engine in 10000 miles ago. I'm going to have it bored 30 over and put new pistons, rods and have everything balanced.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 03-09-2019, 09:16 PM   #342
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Got my Final Mock up done...hope to get her back in an plumbed mid week...
bad6772 is offline   Reply With Quote
Old 03-10-2019, 03:33 PM   #343
BugzC10
BugzC10's Avatar
Got her a blankie....
Old 03-10-2019, 03:54 PM   #344
siggyfreud
siggyfreud's Avatar
What products did you use for the windows and doors? I see someone on this forum used to make a 67-72 specific power door lock kit, but they don't appear to be around anymore.
siggyfreud is offline   Reply With Quote
Old 03-10-2019, 06:35 PM   #345
Metaldoc
Metaldoc's Avatar
The windows were 91 chev truck motors and the lock are swap meet. All the switches and relays are hobby store. My own design beyond that.
Old 03-10-2019, 06:45 PM   #346
Metaldoc
Metaldoc's Avatar
Painting the inside of the hood to finish the engine bay
Old 03-10-2019, 10:12 PM   #347
fdbdw
fdbdw's Avatar
Dumped my sniper EFI back to carb, so glad to be done with that POS. Starts and runs every time now.
fdbdw is offline   Reply With Quote
Old 03-10-2019, 11:18 PM   #348
Abomb
Well, the new project spent a full week in my shop, new wheels cylinders, hoses and shoes, new heater core, new thermostat and water neck, new pressure and temp gauges, new choke cable, new exhaust hanger, carb cleaning...I was really hoping to drive it to work tomorrow, but couldn’t get the brakes to gravity bleed...so, it’ll have to wait until I can get my 14 year old son to come down for a leg work out while I bleed the wheel cylinders.
Abomb is offline   Reply With Quote
Old 03-11-2019, 12:30 AM   #349
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Polished this up with Pro Honda. Comes in a spray. Beyond my expectations, it took out some tuff areas with ease. I could brighten it up some more, but why bother. May have painted it, they look amazing painted, but seems they "breathe" easier without it.
$1550 to have this rebuilt. It's shifted smooth since the day I got it, but 140K miles, and an occasion of abuse, it was due.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-11-2019, 01:06 AM   #350
cornerstone
I finished welding up the unnecessary holes in the firewall and started the body work. Now I get to learn firsthand why everyone gets sick of sanding.
Brian
